Group Buys Members group buys
Paradise phono stage
Old 5th August 2012, 03:13 PM   #241
Birger is offline Birger  Germany
Birger 1 x Set Germany
Old 5th August 2012, 07:46 PM   #242
ungie is offline ungie  Canada
Anyone have any leads on where to obtain the required Toshiba FETs for this build? Everything else is fairly easy to get!
Old 5th August 2012, 08:25 PM   #243
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I got mine from Spencer Toshiba 2SK170BL for sales
I suggest you send him a PM
RC
Old 5th August 2012, 09:00 PM   #244
pdul is offline pdul  Denmark
eorosemiconducter on ebay, when he returns from vacation
Old 5th August 2012, 09:05 PM   #245
Do anyone have an idea of how a Dynavector karat 17D 2 will work with this phonostage? 0,15mv 32ohms
Old 5th August 2012, 09:06 PM   #246
Ideal load 100 ohms
Old 6th August 2012, 08:56 AM   #247
hesener is offline hesener  Germany
Hi, you can use J107 although the pinout is different, you will have to twist them around a little bit, see attached picture....
the upper (marked) pin is the drain, followed by gate, then source (on the K170). To use a J107 which has a pin sequence of drain-source-gate, two pins need to be swapped.
Paradise documents are here: Link list
Old 6th August 2012, 09:36 AM   #248
der_yeti is offline der_yeti  Germany
Originally Posted by carsten.witt View Post
carsten.witt (Carsten)@der_yeti, i update the sheet with your request
THX Carsten!!
Old 6th August 2012, 01:17 PM   #249
I'm going to assume here that the K170 and J310 specified on the BOM are actually 2SK170 and 2SJ310, Toshiba parts? The substitutes listed (J107 and J109) would be Fairchild parts? Is there a specific grade of J107 and J109 that are required?
Old 6th August 2012, 01:32 PM   #250
kompakt is offline kompakt  Germany
Hello!
Kompakt one set germany.
Thanks and regards
Seyed
Paradise phono stageHide this!Advertise here!
12az7a phono stage-12ay7a line stage tubenut33 Analog Line Level 1 23rd July 2011 10:44 PM
New Phono Stage Lee35210 Pass Labs 7 19th February 2009 02:30 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
