Group Buys Members group buys
Paradise phono stage
Old 11th October 2013, 09:36 PM   #1121
BenY is offline BenY
Thanks to all who commented about the issues i raised..
Originally Posted by quan View Post
Wholeheartedly agee. The Teflon caps did make a difference. But the power supply makes a bigger changes . It is the sum of all parts that leads to the Holygrail
With all the changes additions and progress that went into, Which is the prefered supply configuration for it ?? "The holygrail"
Old 11th October 2013, 09:54 PM   #1122
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise phono stage
Thommy pm me I can send you my source list for all parts.
Paradise Pre-reg PSU PCBs
Old 12th October 2013, 07:40 AM   #1123
hesener is offline hesener  Germany
Originally Posted by RollE2k View Post
By the way - when matching with the circuit in the guide, i always see the voltage (mV) rising slowly while having the multimeter over the parallell 1K resistors, even and backs when removing the multimeter. i take it the value from the start is the value i want, and that the multimeter in some way makes the the voltage rise during measuring?
Yes, I noticed that too. This is due to the transistor heating up during the test. The safe way would be to wait until the value changes no more, and then take the reading, but that will take a while. (I did take the first stable readout, after a second or so, and match that way - I admit I am a little lazy.....)
Paradise documents are here: Link list
Old 12th October 2013, 07:48 AM   #1124
Beny, I think that with the "standard" configuration (Paradise with Benedetto's prereg) you should be very happy. As mentioned by many here, the most important factors are the precise gain matching of the input stage transistors, input bias adjustment, and most precise matching of the RIAA components, all of this as identical as possible between the channels. NExt comes the chassis and cabling (mostly to avoid hum and noise issues), then the power supply and then you can think about boutique parts etc etc.
One modification I heart about but have not tried it yet, is to shorten one of the LEDs of each of the four shunt regulator LED strings, so that the supply voltage comes down to 16.2V. This allows you to use 24V batteries to supply the Paradise (24V is not sufficient otherwise, you need at least 26V). It is said that battery supply improves over the pre-reg, but that may also have to do with the (noise) quality of the grid voltage).
Yes, I bought the copper-teflon caps, and they do sound nice, nicer than what I had before (and I admit my ears may not be up to the task to hear the last, subtle, almost mythical differences), at an estimated 7500% higher price than Wima FKP2. Decide for yourself.....
Old 12th October 2013, 08:14 AM   #1125
Folks, why not discuss this in the "Paradise builders" thread - Paradise Builders
This thread is for the group buy. Don't mean to spoil the party, but over there its where it should be.....
Old 12th October 2013, 09:03 AM   #1126
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Originally Posted by Joachim Gerhard View Post
What also makes a big difference who is in the room.
Last year @ Krefeld Ał Audio-Fair, i had the chance
to peep two guys (one of them a rather famous producer
of expensive valve equipment) who induced real different
hum to the setup by just standing behind it, complaining
if it could be a result of one of them beeing a vegetarian.
In fact he was humming louder.
preregulatorpeterE-MAIL
Old 27th October 2013, 02:33 PM   #1127
df_genius is offline df_genius  United Kingdom
Any idea when there might be another GB for these boards please?
Old 28th October 2013, 08:28 AM   #1128
mcds is offline mcds  Tuvalu
The next group buy will take some time as the board will be redesigned to incorporate the Calvin buffer, probably early 2014. The group buy after that - 2015 - will include a volume control, the 2016 one will allow for a few line-level inputs.
Joachim will then have a thorough re-think and the 2017 group buy will be for a digital phono stage.
Old 28th October 2013, 08:47 AM   #1129
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Actually on another forum ( Frickelfest Forum ) we are working on a phono stage with digital EQ. It is called Pandium.
Old 28th October 2013, 10:49 AM   #1130
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Analog input stage -> AD converter -> add digitalite + dither + jitter -> DA converter - > filter everything -> buffer the whole results
RC
Paradise phono stageHide this!Advertise here!
12az7a phono stage-12ay7a line stage tubenut33 Analog Line Level 1 23rd July 2011 10:44 PM
New Phono Stage Lee35210 Pass Labs 7 19th February 2009 02:30 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
