Group Buys Members group buys
Paradise phono stage
Old 24th March 2013, 01:08 AM   #1011
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise phono stage
Ungie, yes, yes, yes and no.
Paradise Pre-reg PSU PCBs
Old 24th March 2013, 08:28 AM   #1012
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by Benedetto View Post
Hello J.
But what is the reason nobody shows up with
a center tapped, real symmetric, MC-cart ?
To me, as an immaculate fool, this should be possible.
Not ?
Wuld it present benefit over the floating configuration?
OF course It is possible just need 6 pins on cart 6 vires on arm...
Is it practical and cost efective solution? I mean if making balanced Cart has advantages some one could charge a K or 2 more and sell it.
I am shure they would and have investigated this if just for the novelty fact and the money making doors that this oppens
What is appening with strain gauges Cart?
Old 24th March 2013, 10:41 AM   #1013
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
The problem would be to make all 4 coils the same.
A small percentage of difference in the impedance would destroy the common mode rejection.
I think floating balanced is a good compromise.
Microphones in studios and life are connected that way and out of good reason.
OK, the cables may be much longer there and the environment is harsher then a high end home altair.
Anyway, so far the balanced input Paradise is not ready.
We have some trouble with the servo.
Old 24th March 2013, 12:42 PM   #1014
RollE2k is offline RollE2k  Sweden
What would even be the benefit of having a center-tap ground reference vs a floating coil?
Old 24th March 2013, 12:49 PM   #1015
Partly it is a matter of definition.
Real balanced has two independent out of phase outputs referenced to ground.
Nobody i know of has build it so i can only speculate.
Anyway, mostly i get dead quiet results with single ended too.
On my turntable though balanced is more quiet concerning hum.
That is because my Spiral Groove Centroid tonearm is from Carbon and does not shield the inside wires. The turntable is a big piece of metal though and it is earthed so it provides some shielding. It is just that i get even better results with balanced.
Old 24th March 2013, 12:50 PM   #1016
Cartridge floating, input balanced, of cause.
Old 1st April 2013, 09:29 AM   #1017
hesener is offline hesener  Germany
For all the group buy participants: PCBs and heatsinks are ordered, I expect to ship out beginning of may.....
Paradise documents are here: Link list
Old 8th April 2013, 07:46 AM   #1018
Short update: Heatsinks have arrived....
Old 3rd May 2013, 08:56 AM   #1019
Short update: The parcels are out the door, expect them to arrive in the next couple weeks. Unfortunately, as experience shows, the transit time is somewhat unpredictable. In Germany it can be a couple days, but for the US it can be 2 weeks.
Should they not arrive within a reasonable time, send me a PM and I will track it down
happy bastling!!
Old 22nd June 2013, 06:34 PM   #1020
Still after a spare set of boards with parts if possible. Please pm me
Paradise phono stageHide this!Advertise here!
12az7a phono stage-12ay7a line stage tubenut33 Analog Line Level 1 23rd July 2011 10:44 PM
New Phono Stage Lee35210 Pass Labs 7 19th February 2009 02:30 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Copyright ©1999-2017 diyAudio
