Paradise phono stage - Page 101 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 20th March 2013, 06:11 AM   #1001
hesener is offline hesener  Germany
For the new group buy, all subscribers have been contacted - if you didnt get a message then PM me
happy bastling
alfred
Paradise documents are here: Link list
Old 20th March 2013, 06:15 AM   #1002
Joachim Gerhard's Avatar
I came up with another solution to make the Paradise balanced input ( work in progress )
so now 4 boards are not needed any more. When i get it working, i plan to make a small additional board that sits on top of the Paradise input section.
Old 21st March 2013, 09:24 PM   #1003
Benedetto's Avatar
Go 4 it !
Despite the fact i don't need it.
preregulatorpeterE-MAIL
Old 21st March 2013, 10:21 PM   #1004
You never know, the story has to go on.
Old 21st March 2013, 10:45 PM   #1005
Benedetto's Avatar
If,
and only, if,
one day, a true symetric cartridge make its
way into existance, i may change my point of view....
Old 22nd March 2013, 12:38 AM   #1006
Banned
Originally Posted by Benedetto View Post
If,
and only, if,
Sorry Could you explain this as far as I know is just a coil moving against a magnet and has 2 pins for each coil camming out...
Old 23rd March 2013, 11:30 PM   #1007
ungie is offline ungie  Canada
Anyone receive RN65 parts for the 330R resistors? These will not fit in the footprints. Also, I received RN55 for the RIAA parts. I thought these were supposed to be RN65?? I also received 4pcs 2k RN55. Any idea what these are for?
Oops...meant to post this in the Paradise PARTS thread.
Old 24th March 2013, 12:56 AM   #1008
A moving coil is not balanced but floating, sure.
Stil, when we use a so called balanced input common mode noise is suppressed and second harmonic goes down.
That should lead to zero hum and less distortion at the cost of 3dB more hiss with the same amount of input devices run on the same bias.
Old 24th March 2013, 01:04 AM   #1009
Benedetto's Avatar
Hello J.
But what is the reason nobody shows up with
a center tapped, real symmetric, MC-cart ?
To me, as an immaculate fool, this should be possible.
Not ?
Old 24th March 2013, 02:07 AM   #1010
studeb is offline studeb  United States
studeb's Avatar
Hello J.
Not ?
Ask AJ van den Hul, or J. Carr. why not.
I think due to the paucity of balanced input phono stages.
Are you going to ground both channels together, or keep each seperated?
12az7a phono stage-12ay7a line stage tubenut33 Analog Line Level 1 23rd July 2011 11:44 PM
New Phono Stage Lee35210 Pass Labs 7 19th February 2009 03:30 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Copyright 1999-2017 diyAudio
