Group Buys Members group buys
Joachim Gerhard Filter Buffer for ES9022
Old 2nd March 2013, 10:14 PM   #521
EUVL is offline EUVL  Europe
I suggest you take a closer look at how I did the ES9022, as different from others.
Pictures of both sides of the PCB have been published, so it is not difficult to see.
http://www.diyaudio.com/forums/digit...ml#post2458181
And you can try to mock up what I did with some SOIC16 adaptor boards, and a lot of P2P in air.
The same circuit done with different layout and different choice of components can sound totally different.
One of the guys who have my 9022 will testify to that, as he has heard two versions of 9022 done differently, with totally different results.
Patrick
xen-audio.com
Old 3rd March 2013, 03:55 PM   #522
GaryB is offline GaryB  United States
Default question about filter
Patrick,
I just put together another ES9023 DAC (Subbu / JP board + their PS) and one of the JG filters from the group buy. It's still burning in but after running all night, it sounds quite promising. Thanks again for making the boards available.
I did have a question about the design. I notice that there are some small 10 ohm resistors at the power supply input - R7 and R8. Could you comment on the benefit of these vs. hooking up the filter directly to a well regulated power supply?
Thanks,
---Gary
Old 3rd March 2013, 05:02 PM   #523
They help to isolate the left & right channel.
You can try to use 0R resistor or even wire jumper to see what you like better.
Patrick
xen-audio.com
Old 4th March 2013, 03:25 AM   #524
Patrick,
Thanks - that makes sense.
On another topic, can I ask about your user name - EUVL. Are you working on that the advanced litho technology that goes by that name?
Old 13th March 2013, 07:22 PM   #525
gogowatch is offline gogowatch  Hong Kong
Progress update of 2nd GB.
Matching of BF862 and MMBFJ111 finished. Soldering will soon start. Hope I can deliver in April.
Thanks again for your patience.
WK
xen-audio.com
Old 14th March 2013, 10:43 AM   #526
atupi is offline atupi  Romania
What is the voltage needed to power this buffer ?
Old 14th March 2013, 11:37 AM   #527
Stixx is offline Stixx  Germany
Stixx's Avatar
The schematic says +- 15V... but I'd like to know myself whether there is a certain range for the supply.
Old 14th March 2013, 06:19 PM   #528
Output voltage swing is about +/-3V.
Cascode voltage for the BF862 (Vds) is about 5V. Idss for the BF862 is 12~25mA.
The J111/J174 can take max 30V Vds, but dissipation is limited to around 250mW.
At below 5V Vds, capacitances for JFETs becomes too non-linear.
So you now have all information needed to calculate max/min rail voltages.
BTW all the above info can also be found in standard datasheets.
Patrick
xen-audio.com
Old 14th March 2013, 07:18 PM   #529
enjoybiking is offline enjoybiking  United States
Default Voltage range
The designer, and at least one other, has tested the filter buffer with 2 x 9V batteries
http://www.diyaudio.com/forums/digit...es9022-44.html
Old 19th March 2013, 08:19 PM   #530
Patrick,
I did the experiment of replacing the 10ohm resistors with wire jumpers and in my system, I think it's an improvement. It feels like the low end is a bit less confused in complex passages and the overall "ease of listening" improved somewhat. I think I'll keep it this way for a while.
---Gary
Joachim Gerhard Filter Buffer for ES9022Hide this!Advertise here!
Anybody using the new ESS Vout DAC (ES9022)? jkeny Digital Line Level 605 20th July 2014 08:36 PM
ZDL thread by Joachim Gerhard jamikl Multi-Way 14 21st July 2011 07:10 AM
ESS Sabre ES9022 announced sjalloq Digital Line Level 2 3rd September 2009 04:18 PM
OPA627 as a Filter/Buffer? D_GR8_1 Chip Amps 7 10th November 2004 01:17 AM
Filter for buffer carlmart Chip Amps 8 1st June 2004 08:57 PM
