Group Buys Members group buys
Joachim Gerhard Filter Buffer for ES9022
Old 12th February 2013, 01:05 AM   #481
EUVL is offline EUVL  Europe
Fran,
If you would forgive me I want to say I like your previous woodwork.
It was spceial, elegenant, and minimalisitic, in the spirit of XEN.
But as Joachim said, sounding good id ultimately what matters.
Patrick
xen-audio.com
Old 12th February 2013, 07:49 AM   #482
woodturner-fran is offline woodturner-fran  Ireland
I liked it too - and I don't much enjoy making chassis! But once there are mains voltages involved an open frame isn't good enough. Small fingers....
Ah I'll use it for something else...
Fran
Old 12th February 2013, 08:37 PM   #483
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally Posted by VT67 View Post
I also have one of those lying around. Does that regulator really need such a big heatsink?
Which regulator are you using?
Old 13th February 2013, 12:37 AM   #484
TheShaman is offline TheShaman  Europe
Coffin used to offer these. They seem to have a new website here.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 16th February 2013, 10:07 PM   #485
enjoybiking is offline enjoybiking  United States
18mH coil DCR seems higher on this but it shows stock and would be priced well, CAN it be used in this circuit?
AIUR-04-183J-ND Digikey
AIUR-04-183J Abracon Corporation | AIUR-04-183J-ND | DigiKey
60 ohm max DCR is WAY higher than the stock on in this design
Old 16th February 2013, 10:35 PM   #486
It is inferior to the Fastron P09 as proposed here, which in turn is also inferior to the 07MFG we specified :
http://www.diyaudio.com/forums/group...ml#post3354644
> Can it be used ?
There is only one way to find out -- just try.
Patrick
xen-audio.com
Old 17th February 2013, 12:14 AM   #487
Here a screenshot of the data summary of the 07MFG 18mH as listed by Mouser.
The SRF is at 525kHZ, almost double that of the others.
Patrick
xen-audio.com
Old 17th February 2013, 02:40 AM   #488
Default SRF
Patrick
So SRF is pretty important. The below would also then be ? too far below spec? I could change out the coils in Summer. BUT if they will cause distortion... maybe I just wait. I can try a few...they would ship in just days, but I'm not ready with a board.
I would volunteer to sort and ship the proper coils for the USA, but it seems like 14 weeks to possibly get some. I have a great LCR meter.
I'll have Curryman's boards for USA folks too [they are handy for me even without the buffer you see...a good es9023 board with regulators and 50Mhz oscillator]. Happy to make this easier for folks this side of the pond -- good coils seem rare.
RL181S-183J-RC
Inductance: 18 mH Tolerance: 5 % Maximum DC Current: 21 mA Maximum DC Resistance: 17 Ohms Operating Temperature Range: - 55 C to + 105 C Self Resonant Frequency: 0.19 MHz Q Minimum: 100
Old 17th February 2013, 03:47 AM   #489
Default SRF and what CAN we get?
Patrick
I think of my deceased Father, in the 50s he ran a small town grocery store. Later when I was alive we'd go shopping, he'd have the newspaper ads along... and gripe "eggs are $0.38/dozen {USD} but they don't HAVE ANY".
I'll help with this situation but I can't buy 500 or 1 {the coils}. I have not tried direct contact with the maker [some of you probably HAVE].
I gather the 18MH coil forms a LPF at a very high Z-input to the FETs. I am not an ENGR. I cannot "see" if the buffer is unity or has gain, and I apologize for not reading the entire thread. I gather that SRF...could it have sub_harmonics? Not sure the issue with SRF. I think I understand low DCR always nice. Series R of the coil wire changes slopes? My mind thinks Acoustic Reality Crossover tweeter coil.
I will be sourcing Daniel's Es9023//JG buffer board to USA, to help the DIY cause{SO fun}, they will not cost much. I ordered them to have I2s es9023 boards around for my own mods and builds, if I like the JG buffer, well, the artwork will be there thanks to Daniel and Joachim.
- The other Patrick
Old 17th February 2013, 07:32 AM   #490
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
The buffer is near unity gain. High self resonance of the coil helps to make the filter work
( drop aliasing products ) up to very high high frequencies where is not much energy any more. A low self resonance of the coil will change the slope of the filter. The coil looses inductance there, first there is a minumum ( actually an inductance maximum ) and then the coil gets capacitive so there is a rise in frequency. It simply does not work like a theoretically perfect coil any more over the resonance frequency.
First i had objections to use a ferrite coil but i testet the sound of the Faston compared to a very expensive Sowter coil and got a very satifying result. It sure does not sound hard or distorted. Quite the contrary, smooth and liquid and that was what i wanted.
I found the "untreated" ESS DAC a bit on the brittle side and that effect disapeared with my filter-buffer.
Joachim Gerhard Filter Buffer for ES9022Hide this!Advertise here!
Anybody using the new ESS Vout DAC (ES9022)? jkeny Digital Line Level 605 20th July 2014 07:36 PM
ZDL thread by Joachim Gerhard jamikl Multi-Way 14 21st July 2011 06:10 AM
ESS Sabre ES9022 announced sjalloq Digital Line Level 2 3rd September 2009 03:18 PM
OPA627 as a Filter/Buffer? D_GR8_1 Chip Amps 7 10th November 2004 12:17 AM
Filter for buffer carlmart Chip Amps 8 1st June 2004 07:57 PM
Copyright ©1999-2017 diyAudio
