Group Buys Members group buys
Joachim Gerhard Filter Buffer for ES9022
Old 10th February 2013, 01:40 PM   #471
syklab is offline syklab  United States
Originally Posted by EUVL View Post
Not a bit overkilled for consumption of less than 20mA ?
Patrick
That was for driving the op-amp IV originally and just handly to use it for the JG buffer.
Old 10th February 2013, 01:42 PM   #472
qusp is offline qusp  Australia
qusp's Avatar
@ Fran, the above is not a shunt, its a super-regulator type, the series version
Old 10th February 2013, 02:01 PM   #473
VT67 is offline VT67  Belgium
VT67's Avatar
Originally Posted by syklab View Post
I am using this super reg to power the buffer.
I also have one of those lying around. Does that regulator really need such a big heatsink?
Old 10th February 2013, 02:53 PM   #474
Not really, may be sufficient to just use one of this heat sink.
Old 10th February 2013, 03:04 PM   #475
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I am using a shunt,but I have not gotten my 9023 DAC pcb yet..
Regards Åke
Old 10th February 2013, 03:10 PM   #476
EUVL is offline EUVL  Europe
The active circuit is a cascoded JFET follower.
The follower JFET (BF862 upper) is cascoded and see a constant Vds pretty independent of output voltage.
The lower is a cascoded current source.
As such, the circuit has good PSRR.
For my "kitchen radio" (otherwise known as Sisters' Series), I just use 7815 / 7915.
For a slight upgrade a LT1763/LT1964 on 78xx/79xx pin compatible PCBs.
Or the XEN miniature Cap multiplier.
Even if you wish to use a shunt, your CCS current does not need to be more than 35mA.
A boostered TL431 would do.
Patrick
xen-audio.com
Old 10th February 2013, 04:59 PM   #477
shoom is offline shoom  Europe
Hi Fran
i'm using salas shunts
Old 10th February 2013, 07:58 PM   #478
I just realised that the current values quoted in post #469, 470, & 476 were not well defined.
According to our record, the JFETs that Fran has have Idss of around 14mA.
So thet figure of 28mA he was referring to in post #469 was for one PCB, or two single-ended channels.
And I was misled by the phase he used "on each leg".
So the numbers I gave in post#470 and in #476 were for one channel.
Thus, for 2 single-ended channels, or one PCB, the max current consumption can be about 50mA.
If you then choose to use a shunt regulator, the current source should be delivering minimum 60mA.
(Some of you will of course argue that even 55mA is sufficient.)
Sorry for causing any confusion,
Patrick
xen-audio.com
Old 11th February 2013, 09:36 PM   #479
woodturner-fran is offline woodturner-fran  Ireland
EUVL - you are 100% correct, that is for 2 channels. 28mA for each polarity.
I thought I'd throw up a pic of my almost finished build. I'm using EUVLs 9022 dac (run on batteries) and the filter run from the salas shunt (the old hypnotise B1 boards butchered a bit). The other bits are for charging the batteries.
I had a bad mistake. When I reassembled everything I had no sound and DC offset from the DAC. I fried the 9022 - easier to do than you think with the batteries. After some advice and instructions from EUVL (thanks again!) I managed to remove the dead 9022 and replace it.
All is good, and I can tell you it sounds great with a shigaclone transport.
Fran
Old 11th February 2013, 11:54 PM   #480
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That looks wild !
Anyway, when it sounds good it is good.
Joachim Gerhard Filter Buffer for ES9022Hide this!Advertise here!
Anybody using the new ESS Vout DAC (ES9022)? jkeny Digital Line Level 605 20th July 2014 07:36 PM
ZDL thread by Joachim Gerhard jamikl Multi-Way 14 21st July 2011 06:10 AM
ESS Sabre ES9022 announced sjalloq Digital Line Level 2 3rd September 2009 03:18 PM
OPA627 as a Filter/Buffer? D_GR8_1 Chip Amps 7 10th November 2004 12:17 AM
Filter for buffer carlmart Chip Amps 8 1st June 2004 07:57 PM
