Group Buys Members group buys
Joachim Gerhard Filter Buffer for ES9022
Old 24th January 2013, 05:36 PM   #431
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Can I use the JG Filter buffer with an ES9018 dac?
Old 24th January 2013, 10:45 PM   #432
woodturner-fran is offline woodturner-fran  Ireland
Isn't the 9018 current output?
Old 25th January 2013, 02:13 AM   #433
ES9018 USB DAC - Hi-Resolution System
According to this, both.
Old 25th January 2013, 03:06 AM   #434
qusp is offline qusp  Australia
qusp's Avatar
you could use this buffer, but it wouldnt be a very good choice IMO. performance is significantly lower in voltage output.
current sources typically have reasonably high output impedances, current output dacs typically have higher output impedance than the es9018/12/16, which is quite low; (195ohms in 2 channel/stereo mode) so if you present the dac with a next stage input impedance that is even a few ohms, you are already outputting voltage as well as current due to ohms law. and if that input impedance is higher than 195ohms, its ALL voltage, no current.
there is no 'current mode' or 'voltage mode' as some like to put it, only grey areas in between. there is a point where it effectively puts out all current (~3.9ma x 4 per channel at standard operating voltages in stereo balanced) and there is a point where its all voltage (with significantly reduced current)
Old 25th January 2013, 03:07 AM   #435
Catal is offline Catal  Italy
Is it too late for ordering 4 stereo boards?
Frank
Originally Posted by gogowatch View Post
Thanks for your responses to my PM.
Batch 2 GB status update can be found here,
https://docs.google.com/spreadsheet/...jl6SXotbTd2dGc
WK
PS: I screwed up the Google spreadsheet URL in the PM. Please ignore it.
Old 25th January 2013, 03:15 AM   #436
hochopeper is offline hochopeper  Australia
If wanting to use this with ES9012/8 I would have an active IV stage THEN the filter/buffer board.
Old 25th January 2013, 03:24 AM   #437
qusp's Avatar
why? any decent IV would remove the need for the filter/buffer, so you would be just adding noise, THD and complexity.
not because its a bad design, it isnt, but because its extraneous circuitry and anything added after whats needed adds noise, THD etc.
Old 25th January 2013, 03:36 AM   #438
EUVL is offline EUVL  Europe
That I do not agree I am afraid.
Any IV stage merely converts the current signal to a voltage by the proportional constant R_iv.
It does not necessarily have any additional filtering to remove the digital noise.
Some IV circuits also have an additional RC filter. Our SEN is a good example.
This is actually equivalent to the built-in resistor of the 9022 and the external 4.7n film cap.
So any current-out DAC which uses a first order low pass in the IV circuit can still benefit from the passive filtering Joachim designed.
And because the passive filter is high impedance, you do need a buffer.
Hence this circuit.
Whether you like a simple RC filter, or the additional filtering as preferred by Joachim, is another matter.
My 2 cents,
Patrick
xen-audio.com
Old 25th January 2013, 03:41 AM   #439
qusp's Avatar
I guess it depends on how you define decent. I consider that a decent IV circuit provides an optional low pass filter by default. if I wanted more than RC, I wouldnt add an entire additional buffer, just modify the existing integrated filter.
Old 25th January 2013, 03:45 AM   #440
You choice.
I personally like passive filters, as Joachim is using here.
Patrick
xen-audio.com
Joachim Gerhard Filter Buffer for ES9022Hide this!Advertise here!
Anybody using the new ESS Vout DAC (ES9022)? jkeny Digital Line Level 605 20th July 2014 07:36 PM
ZDL thread by Joachim Gerhard jamikl Multi-Way 14 21st July 2011 06:10 AM
ESS Sabre ES9022 announced sjalloq Digital Line Level 2 3rd September 2009 03:18 PM
OPA627 as a Filter/Buffer? D_GR8_1 Chip Amps 7 10th November 2004 12:17 AM
Filter for buffer carlmart Chip Amps 8 1st June 2004 07:57 PM
