Group Buys Members group buys
ES9023 / WM8804 S/PDIF DAC Parts GB EU Only
Old 3rd September 2012, 08:17 PM   #121
korben69 is offline korben69  France
Finally I've received my ES9023 PCBs this afternoon, little boards : 80 x 50 mm only.
Dear Emeritus would you please point me the correct way to solder the polarized Tantalums caps ?
(C19, C22, C26, C29 and C8 for SE and C19, C22, C26 and C8 for BAL)
I've scanned the PCB and highlight concerned Tantalum caps footprint.
Thanks for your "enlighted" advices
Old 3rd September 2012, 08:27 PM   #122
Finally I've inquired a bit and the result seems OK for C19-22-26-29, please confirm.
I need some help about C8.
Old 3rd September 2012, 09:36 PM   #123
pchw is offline pchw  United States
That's correct. If you are in doubt, one small trick (that's what I did) - measure the pads to the ground, there should be continuity between ground and -ve pad.
C8 is after the inductor (L3), so it can be the same parts as in the BOM which is non-polarized. Regardless, the above trick will tell you the correct orientation quickly.
- Fred -
Old 3rd September 2012, 09:45 PM   #124
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Wrong, C8 was changed to a 4.7 F 10 or 16 V tantalum cap as the regs don't like too low ESR caps at their outputs. Phil, you are right about the polarity. They are correct in the picture in post #122 but C8 is orientated the opposite way so + to the upper side. Normally I would have orientated all the same way but we started with non polarized caps in which case it would not have mattered.
It's only audio. Member of the non modular PCB design committee
Old 3rd September 2012, 09:47 PM   #125
And the polarity for C8 is ?
Old 3rd September 2012, 09:50 PM   #126
Yeah, but C8 is not right after the reg. It is C19 - L3 - C8. Are you saying L3 is not enough to decouple C8 from the reg? Anyway, I have no problem with using the 1uF film cap as in the BOM.
Edit: so the revised circuit is C19 (4.7uF tanlaum) -> L3 -> C8 (4.7uF tanlalum), i.e. C8 is changed from the 1uF film to 4.7uF tantalum.
- Fred -
Old 3rd September 2012, 09:59 PM   #127
Great Jean-Paul, thanks.
BTW the attached pic should be correct.
GB members will receive C19-22-26-29-8 (SE) or C19-22-26-8 (BAL) Vishay/Sprague 4.7F/10v Tantalum caps, according to ordered versions.
Second pic shows Tantalum SMD cap, white line indicates "+" polarity side.
Phil
Old 3rd September 2012, 10:27 PM   #128
jean-paul's Avatar
Thanks for telling me what is in our design It was repeated a few times that 4.7 F tantalum is better for C8. It is not a major difference but still. But as always YMMV, I invite you to try it out.
Edit: so the revised circuit is C19 (4.7uF tantalum) -> L3 -> C8 (4.7uF tantalum), i.e. C8 is changed from the 1uF film to 4.7uF tantalum.
Apart from the original spelling errors this is correct.
Old 3rd September 2012, 10:35 PM   #129
jean-paul's Avatar
Phil
Please let everyone read this.
Old 3rd September 2012, 10:37 PM   #130
Abusus non tollit usum, Moderator Emeritus
ES9023 / WM8804 S/PDIF DAC Parts GB EU OnlyHide this!Advertise here!
ES9023 / WM8804 S/PDIF DAC Group Buy unixdeveloper Group Buys 683 16th July 2015 08:33 PM
Case for "ES9023 / WM8804 S/PDIF DAC Group Buy" rvrazvan Digital Source 3 27th July 2014 09:37 AM
O2 amp parts GB, EU Jokener Group Buys 794 13th May 2014 08:36 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 12:10 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 01:43 AM
Copyright ©1999-2017 diyAudio
