Group Buys Members group buys
F5T Premium kit GB
F5T Premium kit GB
Old 18th December 2012, 09:39 PM   #321
sts9fan is offline sts9fan  United States
dK 845 - V3 (2) , PSU (2) - Yes
RusselC - V2, PSU - Yes
Dane - V2, PSU - Yes
mkoerner - V2 (2), V3 (1)
mordikai - V2 (2), PSU - yes
mordikai - V3 (2), PSU - yes
sts9fan - V2, PSU - yes
Naturlyd - V2 (2), V3 (2), PSU - yes
Wijgers - V2, PSU - no
SRMcGee - V3, PSU - yes
skunark - V3, PSU - yes
Tytte71 - V3, PSU - yes
Bugzbunny - V3 (2), PSU - Yes
Kvorning- V3(2), PSU -Yes
wjh - V2, PSU - yes
backefel - V2, PSU -yes
Lo_Tse - V3, PSU - no
RKH - V3, PSU - no
fudce - V3, PSU - yes
PKI - V2, PSU - no
mortron - V1/V2 Std, PSU - yes
I had to make a change. I also fixed it in the spreadsheet.
Old 18th December 2012, 11:33 PM   #322
Lo_Tse is offline Lo_Tse  Canada
Originally Posted by theguy View Post
Buzzforb,
I see you've consolidated the V1/V2 columns: was going to ask about that.
I've specified a zero tax and shipping rate in that sheet for now; will add shipping column to orders sheet.
One other thing I noticed is that lo_tse's custom order comments and price has been over-written with the calculated order price; don't know whether you or lo_tse changed this.
Here's what he/she had originally:
- $125 (kit price) + $64 (2 sets of FETs) + $24 (16 diodies) =$213.00. I added extra components (see column L). My total price will be $213 + $44 = $257.00. Please double check my calculation.
- would like to get 2 x CL30, 2 xCL60 thermistors, 4 extra diodes, and one more set of FETs ($6.0 + $6.0 + $32.00 = $44 extra)
theguy,
Thank you very much for keeping track of things and managing the spreadsheet. I have updated my order in the sheet (again!) and I will remind Buzzforb about my extra order when he collects funds.
Old 18th December 2012, 11:58 PM   #323
OK, got it: wasn't understanding how the factor applied.
One question:
- if I do that multiplication on 25V, I get 32V, which is the rail voltage specified in the manual for V1/V2 main board schematics: so far, so good
- however, the manual refers to a rail voltage of 48V for beefed up V2 PSU, but this may just be example calculation: not really following how this PSU section fits in
Since the PSU for the amp is a capacitor filtered one, the output voltage will be secondary voltage (an rms value) x 1.414. E.g. 25 secondary x 1.414 = 35.35 V => this is the output voltage. However, one also has to consider voltage drop over the diode/rectifer bridge (~0.6/0.7 v per junction). And do not forget that we are using a CRC filter, there will be voltage drop across the resistor. Depending on the current bias set for the output FET's, the drop will be total current draw multiply by the reisitor value. E.g. if the total current draw is 4 amps, the drop will be 4 x 0.1 ohm = 0.4 V. Lastly, when the load is heavy and draw a lot of current , the voltage will sag a bit too.
Overall, prepare to lose 2-3 volts of the output voltage. Anyway, whether you are using 31V or 30.5V is no the end of hte world.
I hope these info helps.
Old 19th December 2012, 12:39 AM   #324
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Secondary voltage times 1.3 is a very good estimate for Class A. Vdrop in this PSU will be minimal, as we will have a very small equivalent R of about .05omhs. That was main point of paralleling so many .47R resistors in the article. In theory, passing 50A will drop only 2.5V. Don't worry about it too much, as most folks wont leave a couple of watts very often.
...Shape the sound , Man!
Old 19th December 2012, 01:16 AM   #325
buzzforb's Avatar
I have most of my info pulled together. Will contact suppliers tomorrow to confirm qty available. Closing of the GB will happen some time tomorrow if all goes as planned. Emails will go out then.
Old 19th December 2012, 01:53 AM   #326
buzzforb's Avatar
Need some help. Could non US based GB members check to see if you can source 2SC 4793, so i don't have to pick an alternative.
Old 19th December 2012, 09:34 AM   #327
backefel is offline backefel  Sweden
It doesn't seem like the big companies carries it (Maplin, Radioshack, Farnell, Elfa, Conrad or Rapid).
Mouser did carry it, but won't have it in stock until March.
However, TME seem to have 4k+ pcs in stock and they source cheap Indel and Talema transformers as well.(I've never bought anything from them before but maybe someone else has some input on the store?)
EDIT:
AKSA mentioned in an old thread that MJE15030 might work as well as a replacement. It might be easier to source.
Old 19th December 2012, 10:03 AM   #328
lehuy173 is offline lehuy173  Viet Nam
In F5 schematic, I cannot find 2SC4793.
Old 19th December 2012, 11:18 AM   #329
I've found 2sc4793 in F5 turbo V3. There is 2sc4793 in v2 kit part, isn't there?
Old 19th December 2012, 11:30 AM   #330
buzzforb's Avatar
lehuy173,
Not trying to be ugly, but please take the time to read the article. It explains evrything very well, much better than I could. If you still have questions, I will be more than happy to answer them. I have solved the bjt issue, as I have found that I had 50 leftover from last Gb. so no issue there. Emails will go out later today to confirm all the info I have for everyone. Hopefully the parts can be here at the beginning of the year, and then it will just be a matter of waiting on the PSU boards. For those not getting them, kits will go out immediately.
F5T Premium kit GBHide this!Advertise here!
FS: Audiosector amp - chassis and premium kit Colin Swap Meet 1 29th October 2009 04:15 PM
My Vifa/Scan Speak Project - Solen Premium kit conscious Multi-Way 7 3rd December 2007 08:43 PM
AudioSector LM3875 dual mono premium kit. nodiak Swap Meet 1 16th October 2007 06:38 PM
FS: Audio Sector Premium LM3875 Kit Firebottle Swap Meet 2 23rd July 2006 08:46 AM
NIB BrianGT LM3875 Premium GC kit. Tony D. Swap Meet 9 1st September 2004 04:43 PM
