ES9023 / WM8804 S/PDIF DAC Group Buy - Page 69 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 24th January 2014, 04:05 PM   #681
Stale25 is offline Stale25  France
Dac available ?
Old 14th June 2015, 02:51 AM   #682
zany is offline zany  Australia
Default Late to the party...
This project got sidetracked... life... back in the saddle. First smd project - enjoyed working with these little critters. Finished the boards except for receiver and dac chips. Waiting for chassis... will test voltages before chips are soldered. JP, just noticed your comments re ceramic output caps will replace later. Any comments welcome.
Old 16th July 2015, 05:10 PM   #683
aradan is offline aradan  Singapore
Hi there.
I have just got a v3 ES board from a fellow member together with a kit.
But it looks like there was no documentation available.
If somebody still has the build guide and Bom etc... Would be great if you could share the info to build this interesting project
Old 16th July 2015, 07:33 PM   #684
diyAudio Moderator Emeritus
jean-paul's Avatar
Somebody shared the stuff of V3 against my wishes but since it is already there:
https://5ad7b68329ae8ddd591c555bf9da...bu%20Dac%20V3/
Please take note yours is a V2.6 which has different part numbers but it is very similar. It seems you soldered C32 in reverse ! I recall the + being wrong on the PCB. Measure it to be sure and replace the cap in case I am right. The pin it decouples has a negative voltage. Replace C8 for a tantalum 10 F 10V or 16V. + to the upper side of the PCB. The ceramic caps after the MIC regs might make the regs oscillate, please use tantalums there.
After much investigation we also found out that it does not sound optimal without chips BTW how will you be soldering those on the board now ?
It's only audio. Member of the non modular PCB design committee
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2436 Today 04:49 AM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 08:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 09:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
Copyright 1999-2017 diyAudio
