ES9023 / WM8804 S/PDIF DAC Group Buy - Page 67 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 31st May 2013, 11:25 AM   #661
jcga is offline jcga  France
added myself on the group buy
Best from France
Jean Claude
Old 31st May 2013, 12:37 PM   #662
billyk is offline billyk  United States
billyk's Avatar
Best from France
Jean Claude
Good Morning,
This GB has been closed for some time. Hopefully you mean this ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest
Billy
Old 9th June 2013, 09:58 PM   #663
Hi!
Is this group buy is closed? The first post says "Subbu's DAC V3 GB is still opened & Alive" but it is edited 25 of may.
BR Christian
Old 10th June 2013, 11:38 AM   #664
atupi is offline atupi  Romania
Still open ! Put your name on the spreadsheet and wait for the magic moment when you will be asked to pay .
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 10th June 2013, 12:59 PM   #665
Sorry for previus message. This is the right thread where the Gb is still open.
Old 13th June 2013, 10:30 PM   #666
kopczas is offline kopczas  Poland
Hello.
I found this project for the first time. It looks interesting but I have few questions about pcb and schematic which i wasn`t able to find:
how much improvement gives separate power supply for each section : 2 for WM8804 and other for ES.
does the PCB for this project has separated ground plane for DGND and AGND?
Old 19th June 2013, 02:44 PM   #667
Hi kopczas
Schematics are provided to GB buyer's, SPDIF PCB is now published.
Have a look there for the SPDIF version : "Subbu DAC V3 - ES9023/WM8804 SPDIF & Power Supply PCB" Group Buy
I hope the I2S version to be available soon.
There are 5 LDO used (3.3 & 3.6v) MIC5205 for each section of the DAC.
Difficult to say how much improvment they give, and compare to what ?
I can say this DAC sounds pretty good, such as V2.6 does
About separate ground plane (D & A) I prefer designers to give you the answer.
Phil
Old 19th June 2013, 03:19 PM   #668
Hello korben,
is was thinking about externa,l complitly independent discrete power sources (with separate rectifiers) like super teddy reg etc.
Ok, I will ask somewhere else about separate groud planes(it`s one of the most important things; for me it`s obvious D & A ground should stand alone).
Thank you for your answer.
Old 19th June 2013, 03:44 PM   #669
kopczas
Have a look at the PSU module that fed the DAC and BTW the 5 onboard MIC5205.
Jean-Paul has designed this device to act as a pre-reg, using LM723 (low noise chip).
Phil
Old 24th June 2013, 09:12 PM   #670
Has any measurements of this power supply been done?
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2437 Today 01:34 AM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 08:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 09:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
Copyright 1999-2017 diyAudio
