ES9023 / WM8804 S/PDIF DAC Group Buy - Page 64 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 7th January 2013, 12:01 PM   #631
Originally Posted by jean-paul View Post
50 to 70 mA depending on the type of XO used. So you will need a 200 VA transformer for the power supply
dw1narso, family comes first so don't feel sorry. I am glad you like the DAC. AFAIK I sent you my own DAC then. It should be a very good sounding version with BG caps ?!
I build v 2.6 - first Impression are that It Is a very good at that price and size but still I preffer my pcm63 dac - more analogue sound
already bought 6 VA transformer
would you please tell us what Is exact output voltage that PSU V1 pcb output - Is not It better to be a little higher than 5 V
where do you recommend to place BG caps and what type In order of Importance
Old 7th January 2013, 01:48 PM   #632
diyAudio Moderator Emeritus
jean-paul's Avatar
Please wait a few days and leave it powered on. Then compare with PCM63. ES9023 needs some time to sound just right.
Please use a 5V DC power supply. The MIC5205 are LDO's that drop 165 mV max. at 150 mA current. So you need approximately 3.8 V as a very minimum at the input of the 3.6 V reg.... Measure what the voltage is at the input of the 3.6 V regulator if you like. If it is 4 V or more it is fine.
The BG caps are described elsewhere. I use BG NX HiQ at the closet spots near the chips. I ordered 1 uF Wima MKS2 for the charge pump and will try those if I get the opportunity.
It's only audio. Member of the non modular PCB design committee
Old 7th January 2013, 02:46 PM   #633
thank you for reply will use exactly 5 Vdc before build PSU v 1
I am very happy that I now can play 24 bit 192 kHz
about BG non polar I read older post that It Is benefit to use high value 100 - 560 uF at ES9023 pins
Old 7th January 2013, 03:39 PM   #634
jean-paul's Avatar
Hi I read a lot too but it is true. Larger values electrolytic caps like 100 uF at that spot make the DAC perform somewhat better. Please mind that the bead in series in our DAC makes things even slightly better. Use low ESR caps and keep wiring short. Please don't use 470 uF with long wires for instance.
I use 47 uF BG NX HiQ for decoupling the power pin of ES9023 in most of my DACs as larger values don't fit (don't exist in NX as well ) and I liked the 47 uF BG better than larger values of other brands (like 100 uF 25 V Pana FM I frequently use).
In my most recent V2.6 I use BG 100 uF N series and 1 uF N series for decoupling the negative pin. Haven't listened to that one yet. Syklab is the one that pointed me in that direction. He tried that combination.
Despite the voodoo like proportions, myth and vague information around BG I still think NX HiQ are the best. Too bad they are so hard to find. In V3 we try new caps as BG are rare now, even fakes seem to be around and prices are like prices of bread in WW2. We will disclose in detail what we tried after prototypes of V3 are tested.
Old 7th January 2013, 04:33 PM   #635
do you use smd bypass when you try BG
that site Is a must Electrolytic Capacitor Shoot-Out - AudioKarma.org Home Audio Stereo Discussion Forums
Old 7th January 2013, 05:07 PM   #636
syklab is offline syklab  Mongolia
My First version:
Both C10,C11 I use ECPU1C105MA5 PPS 1uf 16V
C12 BG 1uF NX
C9,C32 changed to 2.2uf large file cap (MusicCap) ans have mount them off board
C8 changed to Oscon 470uf 25V
My second version, I changed the :
C10 BG 1uF NX
C31 Oscon 100uf 16V
C10B Oscon 100uf 16V
C12 BG 1uF NX
C14,C15 RealCap 6200pF (sold out on 4200pF)
C8 changed to Tant 47uf 10V
To me, C9 and C32 made a big different. try it if you have time.
Cheers
Old 7th January 2013, 05:44 PM   #637
jean-paul's Avatar
Hi syklab, I found Wima MKS2 1 uF in 2.5 mm pitch (same as electrolytic caps) and will try those for C9, C11 and C32 but focus is on V3 for now.
ECPU1C105MA5 PPS 1uf 16V is a very good choice. I prefer those over MLCC/ceramic caps.
Still I would use 4700 pF for C14 and C15.
Old 12th January 2013, 08:13 PM   #638
palmito is offline palmito  United States
palmito's Avatar
Originally Posted by unixdeveloper View Post
Yes, the whole S/PDIF section can be ignored and i2s input can be fed to the DAC. Please take a look at the build guide...
Does this mean I do not need to solder the following components:
R1, R2, R3, R4, R5, R6, R10
C1, C2, C3, C4, C5, C6, C7, C7B, C30
Q1
U1, U7
and MC, since dac will be used in async mode
but keep R7, R8 & R9?
Old 13th January 2013, 10:33 AM   #639
palmito's Avatar
Q1
U1, U7
Never mind, I somehow missed syklab's post (ES9023 / WM8804 S/PDIF DAC Group Buy ) answering this question... with photos...
Old 17th January 2013, 06:21 PM   #640
mickie is offline mickie  Germany
JP,
..do you mean you paralleled those two for the negative voltage?
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2451 Today 01:04 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 08:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 09:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
Copyright 1999-2017 diyAudio
