Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 12th September 2012, 02:14 PM   #511
Cosmetics added to Spreadsheet :
https://docs.google.com/spreadsheet/...yd0NadlE#gid=0
More to com with links about PSU and pricing.
I'll organize Parts GB for EU (DAC + PSU parts)
Phil
Old 13th September 2012, 08:23 PM   #512
Hi All
Have a look there :
ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest
Phil
Old 15th September 2012, 09:25 AM   #513
So i completed assembly, connected the psu and i get total silence.
I examined the board and found a tiny strand of copper (i guess from the cable i used to connect the psu and dac) connecting pin 9 pin10 of wm8804 and c3. I removed it but still silence. Did i fry the IC?
Old 15th September 2012, 10:06 AM   #514
Hi skouliki
Post pics, it will help troubleshooting.
What are your source & PSU ?
Old 15th September 2012, 10:47 AM   #515
Hi Korben.
My psu is a Salas V1.0 and my source is a Pionner PD D6 J. I have attached a pic. Any suggestions are welcome
Old 15th September 2012, 11:00 AM   #516
diyAudio Moderator Emeritus
jean-paul's Avatar
Normal procedure while/after assembling: measure the voltages of the regs first and then solder chips... Use desoldering wick.braid to remove excessive solder. Clean the board. Then check for soldering shorts with a magnifying glass and continue...
Procedure when things are done differently and it does not work: check the PCB for shorts (between pins of ICs) with a magnifying glass and please measure voltages of regs and check if the XO gives pulses with a scope.
You have a big chance that the WM8804 is fried but I keep my fingers crossed for you.
It's only audio
Old 15th September 2012, 11:28 AM   #517
I had similar problem.
I gave the salas more current and it solved the issue.
Also, I suggest that you clean the pcb. there seems to be a lot of residual flux.
hope this helps.
Old 15th September 2012, 11:33 AM   #518
jean-paul's Avatar
The hint we gave repeatedly long ago is to feed it 5 V DC 250 mA. I know the quality of Salas regs but I doubt if they make a significant difference here since the Subbu DAC has 4 onboard regs which do the work. They would make a difference if they would be small onboard versions (is that possible ?) but the PCB would be several times larger then. Small size and short tracks do matter in this design.
Thanks necplusultra, you are right about the flux. I see it so often that I stopped bothering
It's only audio
Old 15th September 2012, 11:47 AM   #519
Thanks for the tips guys. I will follow your suggestions and report back.
Old 15th September 2012, 12:25 PM   #520
Skouliki
I'll post tmorrow in the evening a pic with voltages on my working DAC.
I wrote "my" as the measures were taken from my built
They could be close to yours.
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 1289 12th June 2013 04:48 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 08:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 09:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
