ES9023 / WM8804 S/PDIF DAC Group Buy - Page 31 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 4th August 2012, 07:38 PM   #301
pchw is offline pchw  United States
The notch is the top, pin 1 is top left on the PCB, i.e. the pin near C18 and R13.
The chip should be mounted with the "50 Mhz" letters on the edge side of the pcb, the ACV letters should be on the inner side of the pcb. Go back to a few page, Syklab has a picture that show the correct orientation of the OSC.
Good luck!!
- Fred -
Old 4th August 2012, 08:09 PM   #302
This is why I like diyaudio! you guys are the best!!! Q2 was wrong.... I'm listening to Michael Hedges pumping thru my DV336se (modded) to my Sennheiser HD650. sounds great... cant wait till it breaks in!!
forgot... thanks syklab and pchw for all your help!
many thanks to Subbu and JP for giving us this DAC.
*back to listening to music*
Old 6th August 2012, 02:04 AM   #303
Congratulation, and my turn to seek help :-)
I am getting no sound from my dac, but all voltages at the chip's
pins appeared to be on the spot. Any tip on how to test the WM and ESS
chip is dead or alive?
Attach a photo of the board to borrow another pair of eyes to see anything wrong.
TIA,
- Fred -
Old 6th August 2012, 02:21 AM   #304
syklab is offline syklab  Mongolia
Hi TIA,
Are you measuring from the regulator output pin or from the pin 7 and pin 19 from 8804 and
pin 5 on 9023?
Old 6th August 2012, 02:52 AM   #305
I checked from the 8804 and 9023 pins. I also followed the schematic to check the connectivities from each pin to the other components to make sure the pins are soldered solidly.
In the case of in need of replacing the 8804 and 9023, any suggested techniques to make this easier? This is my first solder my own smd project as well, so I can use all advise that I can get :-)
- Fred -
Old 6th August 2012, 07:43 AM   #306
Has anyone tried using the twisted pear s/pdif transceiver's i2s output feeding to this DAC? I followed the silk screen for a balanced DAC minus JP2 and the components in the *optional section. But I dont get any output, I'm looking to test the board and make sure everything is kosher prior to adding the additional components.
And yes.. all the voltages at the regulators(IN/OUT) measure as expected, using my unbalanced version as reference.
thanks in advance
Old 6th August 2012, 02:01 PM   #307
ByronInPortland's Avatar
Default did I miss the power supply group buy?
I haven't been keeping up on this thread. Did I miss the power supply group buy?! I hope not. I really wanted 2 of the power supplies.
Old 6th August 2012, 06:48 PM   #308
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
if someone needs two of these with the Sabre chips, I bought too many, and don't think I will get to this for sometime. So I will sell at cost I paid UNIXdeveloper for them. PM if interested.
Old 6th August 2012, 06:50 PM   #309
Reima is offline Reima  United States
I will take them.
RC
Old 6th August 2012, 06:59 PM   #310
diyAudio Moderator Emeritus
jean-paul's Avatar
This was never meant to be a beginners project but I truly admire the strong will to conquer SMD parts for a first project ! I see some soldering tips are needed.
Guys/gals, please do the following if you want your DAC to also look good without overheating parts:
- good old 60/40 leaded quality solder thinner or equal to 0.75 mm. Fluitin is a good quality solder.
- use angled tweezers to place the parts straight and not skewed. You won't burn your fingers as a bonus.
- solder the parts at one side and correct when it is still possible by moving the tweezers and heating the part at the same time.
- solder the other side of the part.
- use desoldering braid to remove excess solder.
You can solder all pins on one side of WM8804 in one turn (yes with some or even all pins shorted by solder!) and then remove excess solder with desoldering braid (also in one turn). Heat up the soldering braid beforehand and when it is hot you can suck all excess solder nicely away while moving the braid quickly over the IC pins with the soldering iron.
And ... please do not forget to give an impression of the sound quality of the DAC.
It's only audio. Member of the non modular PCB design committee
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2375 Today 10:15 AM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 08:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 09:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
Copyright 1999-2017 diyAudio
