Group Buys Members group buys
ES9023 / WM8804 S/PDIF DAC Group Buy
Old 4th March 2013, 09:16 PM   #651
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Hi not harsh but in safety we should not go the easy way.
1) Wiring is unsafe because there are uninsulated wires
Comment -
a. No shrink wrap.
b. many 115 V wires that can be touched as they stick out of their connector without sleeve
c. mains carrying wires soldered to each other or to a blank copper wire and then in to the connector without insulating cable pins like the ones on the picture. Bad one.
2) Wires unsuitable for 120v
Comment - Thought it was solid core 90 V PVC wire from the look of it. Sorry if I got it wrong. Flexible cabling breaks a lot less easy than solid core cabling....An IEC receptacle with insulated faston/Amp connectors would be a tad nicer and again less risk for touching mains carrying wiring.
3) Transformer input should be position right next to the AC input.
Comment - DC picks up nasty signals less easy than AC. I would keep AC wiring short so it is away from the PCBs and/or electronics.
4) DC output from PS board is too close to the AC wiring.
Comment - OK if the picture gives a wrong impression. Still I would turn the power supply PCB 90 degrees to the left and I would move the DAC PCB to the left somewhat. You will have both transformers and their primaries close to each other and the IEC receptacle and far away from audio signals carrying wiring and electronics. Less possible hum and a smaller spot where 115 V is around.
5) DACs must be built in a metal chassis for shielding.
Comment - Building electronic devices in a metal casing is not just an idea that can be heard but it is simply good practice in electronics (certainly with an onboard 50 MHz oscillator). I know wooden cases can sound different and in most of the cases better (oops what am I confessing here) but even then I would shield sensitive stuff. Before you know it you will be dipping caps in bees wax !
It's only audio. Member of the non modular PCB design committee
Old 4th March 2013, 10:37 PM   #652
wirewiggler is offline wirewiggler  United States
Jean-paul,
As far as shielding does an aluminum case offer any benifit, or is a case made from ferous materials better?
Bill
Old 5th March 2013, 05:48 AM   #653
jean-paul's Avatar
Tough one and I am no expert in choosing the right material. Aluminum offers little magnetic shielding (it shields RF) but it is the most easy material to work with. Steel is fine too as it shields RF and it offers magnetic shielding. Steel is better than aluminum but it is heavier, tougher to work with and it needs painting. I use aluminum a lot but I shield internal stuff with mumetal when I can. Other metals like copper (one of the best materials for EMI shielding) are too expensive or impractical to work with as they are soft, sensitive to fingerprints, corrosion etc. (for me at least so this is a personal choice).
You can put the electronics in a small metal casing that can be built in a wooden/plastic case. A case in a case so to speak. It gives the advantage that you can make the case exactly like you want it to look and the device is shielded. Wooden cases look very good.
http://en.wikipedia.org/wiki/Electromagnetic_shielding
Old 5th March 2013, 02:39 PM   #654
For my phono circuits with mc inputs with hi gain I have used the thin mu metal on the inside, I wonder if coper screen would be as effective? Maybe some one knows how tight the mesh would have to be to block the wavelength we are looking for.
Bill
Old 21st April 2013, 08:08 PM   #655
terranigma is offline terranigma
terranigma's Avatar
Hello All,
I got one rev 2.6 board for sale ($8+shipping). Anyone who interest can send me a PM.
Thanks.
Old 22nd April 2013, 04:46 AM   #656
viki_v2 is offline viki_v2  India
viki_v2's Avatar
Originally Posted by terranigma View Post
Hello All,
Thanks.
Is this the latest board, Then I will take them.
Old 9th May 2013, 04:45 AM   #657
zany is offline zany  Australia
Hello All,
Thanks.
Hi, pm sent.
Old 16th May 2013, 01:34 AM   #658
Ok, got the board... will start ordering parts soon, but need an ES9023 chip. Does anyone have a spare they are willing to part with?
Old 16th May 2013, 02:43 AM   #659
Nanoloop is offline Nanoloop  Hong Kong
I have four extra es9023. For selling all, I will sell for US$21 including shipping. For selling one, it is US$9 including shipping. Pm to me if you want to buy. There is also on Ebay http://www.ebay.co.uk/itm/TekDevice-...item5af14eaf3e
Old 16th May 2013, 02:55 AM   #660
pm sent.
ES9023 / WM8804 S/PDIF DAC Group BuyHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2506 Today 02:02 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 08:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 09:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
Copyright ©1999-2017 diyAudio
