Group Buys Members group buys
ES9023 / WM8804 S/PDIF DAC Group Buy
Old 4th January 2013, 01:22 PM   #621
samoloko is offline samoloko  Bulgaria
Phil
thank you for useful reply
you have done fabulous job with that GB
I see that there Is MLCC Taio Yuden caps for C19/22/26/29
are these replacement upgrade
also C8 In original BOM Is 1 uF and tantalum Is 4,7 uF
Old 4th January 2013, 01:30 PM   #622
korben69 is offline korben69  France
You're welcome
You're right, first qualified parts were MLCC caps.
As specified in MIC5205 specs, Tantalum are prefered to avoid oscillations at the output.
Don't worry about C8, put 4.7uF, it's fine and gives better results.
Phil
Old 4th January 2013, 01:47 PM   #623
thank you
are you happy with your build
how does sound
do you use original PSU or something exotic
Old 4th January 2013, 02:18 PM   #624
Yes very happy, but I've to move house soon, so packing my DIY stuff is on the way.
It sounds very very good, I've compared V2.6 with an Opus DAC, and to me in my configuration, it's a real improvement.
I've used both the original PSU and Gold Minireg, but can't tell the one which is the best.
More to come soon I hope
Old 5th January 2013, 08:27 AM   #625
has anyone measured how much mA Is actual consumption of dac pcb v2.6
Old 6th January 2013, 07:34 PM   #626
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
BTW with that number of buyers, if you need any help with distribution - let me know. Would be happy to help.
Probably can take UK as an area.
How to find time to finish my projects ?
Old 7th January 2013, 05:55 AM   #627
dw1narso is offline dw1narso  Indonesia
Default Impression about JP and Subbu ESS9023 DAC
I owe this impression to JP since I got this DAC 3+ months ago. Since then I feel guilty almost every day for not able to give the impression sooner. Really is the nature of my day to day work does not allow me easily to spare a time to work on it. On the week end, I feel guilty if I used it for my own fun and neglect my family after they missed me the whole week. Then my father in law health problem in the past 3 months also contribute as well to this situation. Anyway..., after such a long time, last week end I managed to build the chain and try. So JP, the impression is... ...
Old 7th January 2013, 05:56 AM   #628
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
50 to 70 mA depending on the type of XO used. So you will need a 200 VA transformer for the power supply
dw1narso, family comes first so don't feel sorry. I am glad you like the DAC. AFAIK I sent you my own DAC then. It should be a very good sounding version with BG caps ?!
It's only audio. Member of the non modular PCB design committee
Old 7th January 2013, 05:58 AM   #629
OK..., it is not supposed to be that short actually... , but my post above really show what I feel about this JP and Subu's DAC.
Currently I have no speaker (stereo speaker I mean) after my two speaker systems each have one channel dead; too bad I know... but unfortunately they could not be mixed... to differ on sensitivity with one 93db and 86dB on the other one. So, the best I could use is my headphone system below:
WinXP with Fidelizer with Foobar 0.8.3 -> Luckit WaveIO async USB to S/PDIF -> JP/Subbu's DAC -> HiFiMe T2 (rev 1) Tripath Tk2050 -> HeadDirect/Hifiman HE-5LE orthodynamic/planar headphone.
The Wave IO and JP DAC is powered through SLA battery (12V, LM317 regulated to 5V). The Wave IO is also conencted to my PC only using the USB data pins, the power is taken directly from the regulator.
The T2 is powered by Meanwell S-350-36 36Volt.
This modest system (except the headphone) acquisition actually happen since I made known each of them from DIYAudio forum. So, thank you DIYAudio forum for enable me to get this very high quality audio in very limited budget. The HE5LE headphone was in heavily used condition with one arm already broken and replaced with DIY metal rod. This HE5LE is the very unit that is reviewed on headfonia.com; it has traveled to many hands before settled down to me 6 month ago.
I compare JP DAC with Monica II (NOS TDA1545A, async reclocked, with blackgate N coupling caps). Monica has a smooth, a little laidback and non-intrusive sound, but with [big] compromise in dynamic; thus sometimes it sounded reserved, a little dull and flat. Monica has been my main DAC in the past 8 years. JP DAC on the other hand sounded dynamic, powerfull, not-laid back but also not-that-forward, lively, while still being smooth. JP DAC also able to retreive much more details and sound definition (body of sound) without having to sound analytical.
With JP DAC now, I could easily discern Foobar 0.8.3 and the later versions (0.9.x, 1.1.x, etc.) and finally could understand why some people said that Foobar 0.8.3 is still considered as the best Foobar. The difference is not small..., with JP DAC, Foobar 0.8.3 really show its class on showing smallest nuance that was only noticable with newer Foobars (newer foobar sound more veiled, mufled and sound separation is inferior to 0.8.3). With Monica, I could hear the difference between Foobar versions, but not as this contrast/much as with JP DAC. I supposed that JP DAC is much more transparent compared to Monica. JP, your DAC win my heart now and would become my reference DAC from now on.
One more closer picture showing the DAC and the other parts...
I haven't yet try to connect WaveIO to JP DAC using I2S. That would be my next target; I supposed it would take me next few weeks before I could make it.
One last note... One may think that the old CS8414 reciever and TDA chipset on on Monica cannot be compared to the modern WM8804 on JP DAC. But in my experience, Monica respond/show only little difference between different transport. The async relocker on Monica almost always sucessfully hide jitter difference between different transport. Monica is well executed and always sound smooth to me. But I supposed JP implementation of ESS9023 is also well thought and the modern DAC now is taking the lead. Besides, JP DAC that I have is his 1st version with some blackgate caps in the board, build by himself. So, this is the very unit that JP himself know how it should be build and tuned to sound.
Old 7th January 2013, 06:55 AM   #630
just realized that the pictures did not come up properly....
ES9023 / WM8804 S/PDIF DAC Group BuyHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2587 18th April 2018 09:45 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 08:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 09:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
