Group Buys Members group buys
ES9023 / WM8804 S/PDIF DAC Group Buy
Old 19th October 2012, 10:12 PM   #611
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by raymondo View Post
Finally built one of my dacs (been unwell). It's fantastic . Have it running straight into my power amp via a penny & giles pot , currently powered by a temporary 5v linear supply . Fed by an original a8t cd player - this dac wipes the floor with the output stage built into the cd player . About to give it a whirl with my squeezebox touch . A massive thank you to Subbu and jean Paul. Superb fidelity at a knock down price . Power amp is a doug self 30w trimodal , which is only ever in class a . Speakers are sd acoustics sd5r , if anyone is interested ! Back to the music ...
Nice build. I am glad you like the design. You used a tad too much solder at some resistors and please clean the board. Enjoy it !
It's only audio. Member of the non modular PCB design committee
Old 19th October 2012, 10:37 PM   #612
raymondo is offline raymondo  United Kingdom
Yes was built in a rush I know . I'm pretty good at smd but had little time and the incorrect solder & tip in my pace iron (too thick). My 2nd one will be perfect :-)
Old 28th October 2012, 11:38 AM   #613
rvrazvan is offline rvrazvan  Romania
rvrazvan's Avatar
Can anyone point me to where i can find some information about the balanced version. i still have 6 board to play with .
Any major benefits from the balanced version?
Old 28th October 2012, 12:54 PM   #614
doors666 is offline doors666  India
deleted. sorry wrong thread.
Old 4th November 2012, 10:29 AM   #615
syklab is offline syklab  United States
I made a small change and relocated the 3 x 51R (R7,R8 and R9) to a small adaptor card to allow unplugging of the s/pdif section when I wanted so I can connect a USB-I2S module here.
Also did anyone try using small value film cap with less than few uF at C9 and C32 ? How's the result ?
Old 19th November 2012, 02:06 AM   #616
grufti is offline grufti  United States
grufti's Avatar
I never replied to this question, sorry.
This is one example of a smaller edge connector / terminal block that would certainly work:
ED555/2DS On Shore Technology Inc | ED1514-ND | DigiKey
This link hopefully leads to a whole page with connectors that fit the bill:
Connectors, Interconnects | Terminal Blocks - Wire to Board | DigiKey
Originally Posted by jean-paul View Post
Edge connectors ? Brand ? Type ?
Old 19th November 2012, 10:09 AM   #617
jean-paul's Avatar
Hi grufti, for the V3 we changed over to Molex KK for SPDIF and L + R out. Screw terminal stayed for the 5 V power connection. Please note that all these changes still might change !
Old 23rd November 2012, 09:44 PM   #618
grufti's Avatar
Those smaller screw type terminal blocks will work for the 5V power connection just fine. The large green monster look so strange on a small smt circuit board.
Old 4th January 2013, 12:08 PM   #619
samoloko is offline samoloko  Bulgaria
I have tantalum caps 4.7/10 In my packet
which ones are these C?
Old 4th January 2013, 01:32 PM   #620
korben69 is offline korben69  France
Hi Samoloko
4.7uF caps are tantalum, they are to be used in C8/19/22/26/29 position.
Be carefull, those are polarised caps
White bar on cap means "+"
Phil
ES9023 / WM8804 S/PDIF DAC Group BuyHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2553 30th December 2017 03:18 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 12:10 PM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 09:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 10:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 01:43 AM
