Group Buys Members group buys
ES9023 / WM8804 S/PDIF DAC Group Buy
Old 19th September 2012, 06:26 PM   #541
tome is offline tome  Macedonia
Hi
I cleaned the PCB from flux and remove U7 and R10, now it's Ok, I think that flux or some dirt make me troubles.
Old 19th September 2012, 06:33 PM   #542
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
At last somebody that proves me right
Some points as it seems you missed some info:
- C32 should be the other way around because an error was made. Please do this before using the DAC. It will sound better and the cap will last longer. So the - should be orientated where the + is printed on the PCB.
- Output caps of the regs should be tantalum 4.7 F (C19, C22, C26 and C29) as the regs don't like too low ESR of ceramic caps
- a tantalum 4.7 F tantalum for C8 is a bit better.
BTW nice build ! Nice soldering skills and, if I am not mistaking, even with lead free solder. Correct the stuff and you'll have the best DAC around Lake Ohrid !
It's only audio. Member of the non modular PCB design committee
Old 19th September 2012, 07:00 PM   #543
Dufus is offline Dufus
Dufus's Avatar
A+ build Tome!
Old 19th September 2012, 07:58 PM   #544
korben69 is offline korben69  France
Very nice soldering skill Tome
Old 19th September 2012, 08:54 PM   #545
Thanks guys for good words about my build with special thanks to J-P for his suggestions and assistance.
I checked previous posts and it's true i missed the post with J-P explanation about C32, i'll fix this tomorow.
About tantalum, i like to build one board with ceramic and one with tanatalum caps and hear the diference.
Solder is multicore 0.5mm 60/40
Old 19th September 2012, 09:00 PM   #546
jean-paul's Avatar
Promise to tell how it sounds.
Old 19th September 2012, 11:04 PM   #547
necplusultra is offline necplusultra  Canada
Nice build Tome.
I have a question about balanced version:
The schematic shows the data signal going through R9 and R10 on the second board.
Should R9 be populated or not on the second board?
Old 20th September 2012, 06:33 AM   #548
pchw is offline pchw  United States
Originally Posted by syklab View Post
Yep,
Very good eye, that was an old photo, I have changed the polarity already but I have also been testing with a solen MKP in C8(1.5uf) and C32(22uf).
Did you mean C9 instead of C8?
- Fred -
Old 20th September 2012, 06:57 AM   #549
syklab is offline syklab  United States
Yes, typo, I meant C9.
Old 20th September 2012, 01:22 PM   #550
skouliki is offline skouliki  Greece
skouliki's Avatar
I cleaned the flux from pcb but still silence. I posted the voltage ratings earlier in this thread. Does anybody have any ideas?
ES9023 / WM8804 S/PDIF DAC Group BuyHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2507 8th November 2017 03:56 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 12:10 PM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 09:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 10:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 01:43 AM
Copyright ©1999-2017 diyAudio
