Group Buys Members group buys
ES9023 / WM8804 S/PDIF DAC Group Buy
Old 17th September 2012, 02:38 PM   #531
GaryB is offline GaryB  United States
Originally Posted by tome View Post
. . . When I close the jumper i hear music from speaker, maybe Skoulike have the same problem. I see on his pic that jumper is open and there is no U7 and 2 other components . . .
I've built 2 dac boards, both of which work, so I'll add my suggestions. First, if one is building a single ended DAC (not balanced) then the parts U7, R10, C30, and JP1 are not needed. I'm not sure why tome had better results shorting JP1.
Tome's comments did make me think that perhaps Skoulike had forgotten about the parts on the other side of the board. Parts R14, R15, and C12 are on the back of the board. In particular, if you don't add R14 and R15 (zero ohm jumpers) then the outputs won't be connected. Please check this.
---Gary
Old 17th September 2012, 02:50 PM   #532
syklab is offline syklab  United States
HI, here is my building report....
I finish my board yesterday. I was following Jan-Paul instructions, first i check voltages from regulators, then i solder 2 IC's and check voltage and curent. Voltages was OK and total curent on 5V is about 50ma. DAC is not working until i close jumper. When I close the jumper i hear music from speaker, maybe Skoulike have the same problem. I see on his pic that jumper is open and there is no U7 and 2 other components.
First sound impression is promising, i try on labaratory power supply and my test speakers, CD is marantz cd52mk2. I'll write more about sound when i receive and finish PSU boards and put everything in metal case after that i'll do more listening tests.
I didn't close the jumper and I have no problem with the DAC. The dot on the crystal should be positioned further away from the analog output. Trace the voltage on the on chip power pin and the Neg pin. Check if there is any Vac from the output pin on the chip while you have digital signal going in.
I still didn't cean up the flux.
Old 17th September 2012, 02:59 PM   #533
Skylab - don't forget to change the polarity of C32. In your photograph, it's shown with the incorrect polarity.
See Korben's great photo for the correct orientation.
---Gary
Old 17th September 2012, 03:09 PM   #534
---Gary
Yep,
Very good eye, that was an old photo, I have changed the polarity already but I have also been testing with a solen MKP in C8(1.5uf) and C32(22uf).
Old 17th September 2012, 03:11 PM   #535
korben69 is offline korben69  France
Thanks GaryB for your informations.
I've mentionned that SE version (Unbalanced) don't need U7, R10, C30, and JP1 to be populated.
The EU Parts GB provides those parts to SE kits buyers while they are useless (my mistake)
For Q2 orientation, check this one attached.
Old 17th September 2012, 06:08 PM   #536
tome is offline tome  Macedonia
Will try to explain
I solder all the components including the U7. There was no music after switch on. When I measured the voltages I accidentally touched U7, then I heard the noise with the music in the background. I closed jumper and I got a clean sound without noise. When I open jumper I get the same as before, there is no sound. Tomorrow I will remove the U7 and seeing what will happen.
Old 17th September 2012, 06:22 PM   #537
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Yep,
Uh oh !
It's only audio. Member of the non modular PCB design committee
Old 17th September 2012, 06:50 PM   #538
skouliki is offline skouliki  Greece
skouliki's Avatar
Hi. I measured the Es9023 pin with 3.58v on Korben's picture and get 0v. R14 R15 and C12 are populated-forgot to mention that. I will finish measurments tomorrow-free time is a luxury the last few days
Old 17th September 2012, 06:56 PM   #539
jean-paul's Avatar
Measure U3 and L4. If the reg puts out 3.6 V and the ES9023 gets none then the bead is defective or badly soldered.
Old 18th September 2012, 05:29 PM   #540
skouliki's Avatar
Some more measurments. Orientation of numbers as per Korben's picture:
U3: 3.57
L4:
3.57
3.56
R13:
3.56 3.52
C13:
0.00 3.52
DAC:
1.58--- ---0.00
1.62--- ---3.52
0.03--- ---0.00
------- ---1.66
------- ---0.00
------- ---(-3.34)
C10:
0.00
3.56
R11:
1.14
0.00
C11:
-1.70
1.73
Q2:
3.25 3.28
0.00 1.66
C9:
1.14
0.00
C32:
-3.34
0.00
C10b:
3.56 0.00
ES9023 / WM8804 S/PDIF DAC Group BuyHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2553 30th December 2017 03:18 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 12:10 PM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 09:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 10:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 01:43 AM
