Group Buys Members group buys
ES9023 / WM8804 S/PDIF DAC Group Buy
Old 15th September 2012, 04:23 PM   #521
korben69 is offline korben69  France
skouliki have you remove flux ?
From the pic, I suspect R1 and U3 solders, can't see C2.
Check voltage on MIC's 3.3 & 3.6v.
Old 16th September 2012, 02:36 AM   #522
pchw is offline pchw  United States
Originally Posted by skouliki View Post
Hi Korben.
My psu is a Salas V1.0 and my source is a Pionner PD D6 J. I have attached a pic. Any suggestions are welcome
Check the orientation of Q2 (the 50Mhz oscillator). If you parts is identical to the BOM, it looks like oriented wrong. You can take a look at my picture in post 303.
- Fred -
Old 16th September 2012, 05:57 AM   #523
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Razorsharp eyesight !
It's only audio. Member of the non modular PCB design committee
Old 16th September 2012, 07:07 PM   #524
Hi Skouliki and All
As previoulsy told, the pic with voltages on my working DAC (no SPDIF and Output connexions).
Measures taken from my built, they could be close to yours.
Hope this helps
Old 16th September 2012, 07:45 PM   #525
No comments ?
Old 16th September 2012, 09:19 PM   #526
skouliki is offline skouliki  Greece
skouliki's Avatar
Hi korben and all
Thanks again guys for all the suggestions. Unfortunately i didnt had time to troubleshoot the dac today. Hopefully i'll do it tomorrow
Old 17th September 2012, 03:32 AM   #527
ekidnah09 is offline ekidnah09  Australia
Default Pioneer D6
Don't forget to take the Pioneer D6 out of pure audio mode it does not output SPDIF in pure audio mode.
I hope this helps.
Old 17th September 2012, 07:24 AM   #528
skouliki's Avatar
Hi all.
Did some voltage measurments using the very useful picture posted by korben:
c29=3.30
c26=3.23 (low?)
c22=3.57
c19=3.29
c8=3.28
c1=1.60
c7=3.22
c5=3.30
c28=1.93
c25=1.88
c2=3.22
c21=2.23
c3=0.53
c4=0.82
c10=3.56
c13=3.52
I have pure mode off in PD D6 and for Q2 orientation i attached a picture showing the dot on the surface.
Im using lm7805 to feed the dac
Old 17th September 2012, 11:37 AM   #529
Hi skouliki
Q2 is in right position as shown in your pic.
Measures seems to be Ok from those you've measured.
Could you please test voltage on : Q2 - C10 - C10b - C11 - C32 - C9 - R11
Carrefuly check pins from ES9023.
WM8804 seems Ok, but check it too.
How much DC offset at the output ?
Hope this helps
Phil
Old 17th September 2012, 12:47 PM   #530
tome is offline tome  Macedonia
HI, here is my building report....
I finish my board yesterday. I was following Jan-Paul instructions, first i check voltages from regulators, then i solder 2 IC's and check voltage and curent. Voltages was OK and total curent on 5V is about 50ma. DAC is not working until i close jumper. When I close the jumper i hear music from speaker, maybe Skoulike have the same problem. I see on his pic that jumper is open and there is no U7 and 2 other components.
First sound impression is promising, i try on labaratory power supply and my test speakers, CD is marantz cd52mk2. I'll write more about sound when i receive and finish PSU boards and put everything in metal case after that i'll do more listening tests.
ES9023 / WM8804 S/PDIF DAC Group BuyHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2506 25th September 2017 02:02 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 08:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 09:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 12:43 AM
Copyright ©1999-2017 diyAudio
