Group Buys Members group buys
ES9023 / WM8804 S/PDIF DAC Group Buy
Old 27th August 2012, 10:38 PM   #421
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by korben69 View Post
So the parts concerned by Tantalum replacement are :
1 - C19, C22, C26, C29 and C8 for SE
Would this one be a good candidate : 293D475X9010B8T Vishay/Sprague | Mouser
Please confirm Jean Paul
Phil
PS : Yes, changes in BOM, schematic and build guide are welcome as those parts are polarized.
Good candidate. Can't comment on the balanced version but 4.7 F tantalium for all used 4.7 F caps after the regs and for C8. Simple. Effective.
I see the difficulty in keeping things in sync Subbu and I being on 2 different continents with different timezones and different lives and work etc. and how to publish changes/improvements along the way ? Should be a central point that can change dynamically. Yeah a website, heard your thoughts. I can't do it as I don't have that experience and the time and I simply don't want to do it as I better devote my time to designing a new DAC. Job description was: design DAC, design PCB, build it, test it, improve it. That's what I was hired for
It's only audio. Member of the non modular PCB design committee
Old 27th August 2012, 10:55 PM   #422
korben69 is offline korben69  France
Jean Paul, you answer was awaited as I'm managing the EU Parts GB...
I'm trying to do my best in this project, and as there are some money left, I'll place the order ASAP to Mouser's - SE & BAL - for all DIYer's who subscribed to the EU GB.
Could you please check it twice
Next project : USB to I2S... sorry, I've forget you aren't a USB guy
Old 27th August 2012, 11:14 PM   #423
jean-paul's Avatar
Can't tell much but it will be USB + SPDIF + I2S + DAC and the PSU on one single board with connectors all on the PCB so only 115 V/230 V wiring. It will not be a Group Buy effort, sorry.
While I don't like USB the rest of the world does so I will adapt. Off to bed now, will check twice tomorrow.
Old 27th August 2012, 11:21 PM   #424
Marlowe is offline Marlowe
Originally Posted by dw1narso View Post
Marlowe, why don't you put the diodes inside the same box with the DAC? so that from the PSU Box to the DAC Box the power transmission is in AC...
Is there advantage of carry it in DC over AC? I thought carry electricity in the longer cable would be beneficial in AC, since AC do not induce electro magnetic stray....?
Hi dw1narso,
In fact, the cable is a long cable. The length is only 25cm.
I did not try to carry the power over AC. I found most power separated commercial productions transmission the power over DC (filtered or non-filtered).
Here's looking at you, kid.
Old 27th August 2012, 11:49 PM   #425
Originally Posted by 6h5c View Post
I would recommend to put the smoother cap in the PSU box. The way you have it now, the charging pulses to the smoother cap are carried over the long PSU cable. Feed the DAC the raw DC and regulate it locally.
Ray
Originally Posted by jean-paul View Post
Marlowe I missed your post. Neat build again but Ray has a very good point regarding the charge pulses. Either go for a one box solution or make a separate DC supply. AC does pick up RF more easy than DC IMHO. So DC is the way to go. As a sidenote: switching DC is not favorable for known reasons. And I would not put my money on SC transformers. You were telling that the EUVL DAC and ours sound alike with all these nice parts on the EUVL DAC ? That is a positive message. Will you be tweaking our DAC too ? Please let us know how things develop.
And Syklab is called Syklab not Skylab but that can have been an error on his part
Hi Ray and jean-paul,
Yes, filtering the DC in the power box may be good, but the power box is too small to fit additional capacitors.
In my other projects, I compared filtering the DC in the power box with filtering the DC in the load box. The difference is insignificant.
By the way, there is no smooth capacitors in 47 Lab power modules as well.
I ordered two sets of the WM8804/ES9023. My plan is to tweak on one set and keep the other set on "default setting" for reference.
Hi Syklab,
I am sorry I misspelled your name.
Old 28th August 2012, 07:22 PM   #426
ByronInPortland is offline ByronInPortland  United States
ByronInPortland's Avatar
Unhappy My power supply isn't
I threw together a PS and hooked everything up last night and got no sound. I found the voltage from the PS started at just below 5V, then dropped quickly. The decrease slowed as it approached 3V. Checked it with the scope there's no oscillation. It's a super simple design: An LM7805 with a 0.22uF ceramic cap to ground on the left pin and a 0.1uF polyester film cap to ground on the right pin. Power is a 9V battery. Regulator is well heatsinked and gets warm, but not hot. I've tried a few batteries, and the problem is not a dead battery.
So do I blame the lack of sound on the DAC or the PS? or maybe my TOSLINK module? Will the DAC work at all with 3V to 4V? I've ordered the Velleman kit, which should arrive by the end of the week.
Old 28th August 2012, 07:33 PM   #427
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Does the input voltage stay 9V or does it also drop?
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 28th August 2012, 10:22 PM   #428
jean-paul's Avatar
Blame yourself This is not a project for SMD beginners. If you want to build it then build it as recommended which is not with a 9 V battery. I think the current is too much for a 9 V battery (this would be the best error of all as it is reversible easily) or there are shorts on the PCB or defective/overheated parts. Could be anything. TOSLINK module ? How is it connected ? To one of the onboard regs ? (oh no). The DAC can't work with 3 V as the regs need to deliver 3.3 and 3.6 V. But 4 V is no problem.
Pics would help considering all possibilities.
Old 28th August 2012, 10:26 PM   #429
Hi Jean Paul, I'm back with this point
Parts concerned by Tantalum replacement are :
2 - C19, C22, C26 and C8 for BAL
Would this one be a good candidate : http://fr.mouser.com/ProductDetail/V...U2mVu6qTaAc%3d
Verdict your Emeritus ?
Old 28th August 2012, 10:40 PM   #430
jean-paul's Avatar
Hi that cap is OK too.
Confirmed but I have to tell I did not adapt the design for balanced use. Never built one but it seems OK to me.
To all: the output caps for MIC5205 should be not too low ESR so no PPS or ceramic but please use tants 4.7 F 10 or 16 V. Same for C8.
ES9023 / WM8804 S/PDIF DAC Group BuyHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2529 Yesterday 01:47 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 12:10 PM
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 09:13 PM
Twisted Pear S/PDIF WM8804 Transceiver Module on TDA1541A problem dvb projekt Digital Source 17 21st May 2011 10:24 PM
FS: Twisted pear audio Dual COD DAC and WM8804 S/PDIF free2dev Swap Meet 4 24th July 2010 01:43 AM
Copyright ©1999-2017 diyAudio
