Roender's FC-100 Rev.1 Group-Buy - Page 48 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 29th November 2012, 10:44 PM   #471
Telstar is offline Telstar  Italy
Interesting.
Two things come to my mind regarding bass performance.
First, the psu, it needs to be bigger and stiffer. Double transformers size and capacitors bank. I wouldn't do a CLC, though, because is a class AB.
Second check your amp for some wrong value in the networks that define frequency response, maybe you did some mistake.
Third, you should have tried the amp in your friend'd main system with the Ayre preamp. Apples to apples.
Note that the Ayre is a two stage amp without global feedback.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 29th November 2012, 10:56 PM   #472
evette is offline evette  Canada
Send a message via Yahoo to evette
I would change your power supply make your power transformer at least 250va or better yet 300va and double your total supply to 40,00 uf per rail. This is a great amp so give it the best.. Just my 2 cents worth. Evette
Old 29th November 2012, 11:15 PM   #473
pinnocchio's Avatar
Hi Rudi,
The PGA-2311 is most likely your bottleneck here... It is good but nothing to compare to a good stepped attenuator or high quality pot. I have tried many itterations of PGA-2310 and 2311 and the 2310 is a little better because of the 15V supply it has better swing but it is still a PGA... I would retry this with a better attenuator and it will most likely give justice to the FC-100
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 30th November 2012, 06:35 AM   #474
zsaudio is offline zsaudio  Europe
Thank you Rudi for the interesting test.
I would do the test in a chain where i only change the power amps. The volume control should be the same too.
I use 400VA toroid and added some mor capacitances for my RFI-FC100 and comparing it to my other DIY amps i don't miss the bass, it has a well controlled bass and goes deep in my system.
Thanks again for your findings.
Best Regards,
zsaudio
Old 30th November 2012, 07:27 AM   #475
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Thanks Rudi. Just to keep it in perspective, we are talking about nearly 10K euro worth of hifi, not bad this amp scored even a 9/10 against it.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 30th November 2012, 10:44 AM   #476
Rudi_Ratlos's Avatar
Gentlemen,
thank you for your feedback.
When I drove home yesterday night, I had the same impression that some of you expressed in their feedback: my transformers (2 x 160 VAC)
and reservoir-caps (20.000F per rail) are to small for this kind of music (frequencies < 100 Hz).
I can easily replace the digital PGA2311 attenuator by an ALPS Velvet motorized potentiometer.
But the most important: I will not be able to notice any sonic change, unless I will connect a pair of "adequate" speakers to the FC-100.
The pair of Behringer 2031B Truth that I am currently using, conceil too much of sound-information.
So: this will be my next project: a pair of new speakers (DIY-type?), and then I will "upgrade" my FC-100.
Best regards - Rudi
Old 30th November 2012, 02:13 PM   #477
roender is offline roender  Romania
roender's Avatar
Originally Posted by Rudi_Ratlos View Post
Gentlemen,
Best regards - Rudi
Interesting results. What kind of power capacitors are you using? My fc100 has no problem playing low frequencies and having Nikicon KG Gold Tune capacitors and two 300VA R-Core trafos
Old 30th November 2012, 02:26 PM   #478
It's more likely the transformers than the capacitors brand
Yours are more powerful.
Old 30th November 2012, 02:31 PM   #479
Mihai, I am using 2 Nichicon LQ(M) capacitors, 10.000F/80V, per power-rail.
Best regards - Rudi
Old 19th December 2012, 08:31 AM   #480
atupi is offline atupi  Romania
Rudi,
could you tell me please if the schematic found in build manual FC-100_Eng_V1 is the latest one ?
As i was unfortunate to buy only a part of the entire kit (only pcb's) i will start hunting/collecting the other parts and i need to know the exact parts/values.
Apart those hard to find transistors there are some special/boutique parts recommended ?
I have the emitter resistors (o.1R) only for one channel. Would be a problem to buy 0.12R for the other channel as they are easy to find on ebay ?
Thanks !
Adrian
Sanyo/B&O Icepower 200AC Rev.D, schematic about rev. engin., not complete finished tiefbassuebertr Class D 48 6th June 2017 05:04 PM
Roender's FC-100 prototype and builder's thread Rudi_Ratlos Solid State 1005 8th March 2017 05:34 AM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Online vendors for Panasonic FC 1000/100 caps? analog_sa Parts 2 14th February 2007 02:19 AM
Copyright 1999-2017 diyAudio
