Roender's FC-100 Rev.1 Group-Buy - Page 35 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 30th September 2012, 09:28 AM   #341
Rudi_Ratlos's Avatar
Gentlemen: as I told you, I will close the "Shunt-Transformer" group-buy tomorrow early morning and will order from BADEL then.
Find attached the current order list.
Two of you have payed already, and I have accepted their payments (my risk?, their risk?).
But: please wait with your payments, until I can give you the exact price (on Monday or Tuesday).
I have also been asked to quote a price for a transformer with the following sepcifications:
115 - 115 VAC / 4 x 25 VAC / 500W transformer, magnetically shielded, encapsulated, ..., with any option that you like,
to be used for both 117VAC and 220VAC primary voltage, suitable to drive both backend-PSUs of Mihai's FC-100.
The advantage: you do only need 1(!) transformer for the FC-100, and you will have "channel - independent - power" as well.
I will tell you the result of my request tomorrow / on Tuesday.
Best regards - Rudi_Ratlos
Old 30th September 2012, 09:49 AM   #342
@JethroTull: I updated my order list.
Old 2nd October 2012, 07:45 AM   #343
Default PAYPAL Time for Shunt Transformers
Gentlemen, I am able to offer you the FC-100 Shunt-transformers:
Primary: 115 + 115 Vac (suitable for 110, 115, 120, 220, 230 & 240 Vac primaries)
Secondary: 4 x 34 Vac / 20VA
Option: Magnetic Shielding
for 20€ per piece.
The lead-time is 3 weeks.
Find attached the resulting EXCEL sheet.
You can PAYPAL me now. My PAYPAL-ID is: RRozek@t-online.de
@Those, who ordered FC-100 PCBs and components as well:
I would like and include the transformers in your FC-100 letters (I will use a small parcel instead).
The shipping costs are the same for both alternatives (separate FC-100 letter / separate transformer letter vs. small parcel).
The parcel will be sent to you as "registered mail".
P.S. I will now go on matching the PNP - NJL transistors.
I have already matched the NPN types.
Old 2nd October 2012, 01:39 PM   #344
Gentlemen, thank you for your PAYPAL-transfers.
Old 2nd October 2012, 05:30 PM   #345
Gentlemen,
find attached the coloration of the Shunt-Transformers - windings and the current EXCEL sheet.
Old 2nd October 2012, 06:08 PM   #346
pinnocchio's Avatar
Payment sent
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 4th October 2012, 01:27 AM   #347
Default Parts Order
I got in late for the group buy but Rudi kindly helped out and I’m on the list for PCB’s, but not for the majority of “hard to get” parts.
For the transistors, I’m about to place an order for the BOM with Reichelt and Mouser but am not sure what quantity’s to order to ensure I get a good chance of correct matching.
From the Rudi’s PDF builder’s manual it gives the following transistors (below) that require matching as close as possible. Could someone please help and estimate the number of individual transistors I should order to have a good chance of matching for the relevant pairs (per PCB).
If this info is already in the threads, I apologise I just haven’t found it yet!
(Hfe) of the following pairs of transistors should be as close as possible
Q21-Q18 (type: 2SC3423Y)
Q11-Q13 (type: BC560C)
Q6-Q7 (model: BC550C)
Q14-Q16 (type: 2SA1360Y)
Q19-Q20 (type: 2SC3423Y, 2SA1360Y)
Q1-Q3 (type: MJE15034, MJE15035)
J1 and J2 must have the same Idss> = 9 mA and must have the same Vgs + / - 1 mV at Id = 6.25mA
J1-J2 (type is: 2SK170)
Each triple of NJL0281DG and NJL0302DG should have the same (as close as possible) Hfe and VBE .
Q2, Q12, Q25 (type NJL0281DG)
Q4, Q5, Q27 (type NJL0302DG)
Old 4th October 2012, 01:36 AM   #348
Rudi sent payment for the tx, really looking forward to this build. Thanks again.
Can someone post the BOM and build manual, thanks
Sent from my Galaxy Nexus using Tapatalk 2
Old 4th October 2012, 05:19 AM   #349
Hi marcus1,
in case of the NJL0281/0302 I ordered 10 each and I was able to find triples less than 1% Hfe. SC3423/SA1360 I ordered 25 each and enough to make two amps. At the MJEs it was not possible to match PNP/NPN for me. I think you have to buy a lot of these to match them as described. There was a discussion about this at a german board and there was nobody able to match PNP/NPN. Rudi told me, he only matched right and left channel.If anybody want to buy original Toshiba sc3423/sa1360 it will be possible at this shop: BG-Electronics and the price is also good. BC transistors I had enough at home. In case of the SK170 matching is possible, but to get the Idss>=9 may be not so easy. Perhaps you can ask one of the diyaudio-members who sell these jfets to get the special Idss. ( fetaudio.com ). There is also an ebay shop ( Resistors, Capacitors Artikel im AudioFET Shop bei eBay! )who sells them very good matched, you have to ask... and the price is also good <3€for 2 pairs. The SK170 I bought from him, were really very well matched....
greetings Arno
Old 4th October 2012, 06:43 AM   #350
Wendell, I received your payment. Thank you.
In the meanwhile I have measured all NJL-transistors (Hfe, Vf of thermal-track diode) and will now select (match) suitable triples.
Thanks to EXCEL this is not a big job.
P.S. Wendell: I have sent the Builder's Manual to you.
Roender's FC-100 prototype and builder's thread Rudi_Ratlos Solid State 1005 8th March 2017 05:34 AM
Sanyo/B&O Icepower 200AC Rev.D, schematic about rev. engin., not complete finished tiefbassuebertr Class D 47 22nd January 2017 04:46 PM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Online vendors for Panasonic FC 1000/100 caps? analog_sa Parts 2 14th February 2007 02:19 AM
Copyright ©1999-2017 diyAudio
