Group Buys Members group buys
Roender's FC-100 Rev.1 Group-Buy
Old 6th November 2012, 12:26 PM   #441
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Marjohn, I have a sufficiently big quantity of 2SK170BL at hand, all of which have an IDss of > 9mA!
My little test-rig (see attached image) confirms this.
If you like to have the EAGLE-files of this small test-rig, I will send them to you - no problem: "We are DIY."
I will also be able to offer you well matched pairs of 2SK170BL (...must have the same Vgs +/- 1mV at Id=6.25mA),
once I know how to adjust my LTSpice model.
Best regards - Rudi_Ratlos
Old 6th November 2012, 12:38 PM   #442
R.I.P.
Roender.
I have a problem.
I have added a separate regulated supply to the FC100.
The FC100 PCB in this GB uses a single bridge rectifier. That limits the Main Audio Ground to be connected to the Centre tap of a dual secondary transformer. That ground line runs right along the middle of the PCB and does the same on your original PCB.
I am working with the original PCBs at the moment.
I have a choice of where to connect the auxiliary PSU Zero Volts to the main PSU.
a.) At the Zero Volts on the wires from the centre tap
b.) at the Power input connector on the PCB.
c.) at the hole for the ON board Ground at the left end (next to spk out)
d.) at the hole for the ON board Ground at the right end (next to the NFB tapping solder point).
The "problem":-
If I connect the regulated output with a twisted triplet to the three points at the right hand end, I get an ~4V offset in the regulated output voltages. i.e. the regulated +-50Vdc becomes +46Vdc and -54Vdc. Even the 4 smoothing caps on the reg PCB have offset voltages. They change from +-58Vdc, to +54Vdc and -62Vdc.
If I connect instead the INPUT ground of the regulator to any of the first three listed above the offset becomes zero as near as I can measure. I see a very few millivolts of difference depending at what ends of the long Ground line I measure at.
I cannot see why connecting the OUTPUT from the reg to the right most ground creates this offset. I have puzzled for a few days repeating the experiment with different regulators and different transformers and different wiring and I cannot eliminate the offset.
It makes the cascode in the LTP sink run hotter. I will probably increase the size of the sink from 30C/W as I have done with the first of the Rudi PCBs.
I will hand draw what I have described and post a pic later today, or at the latest tomorrow.
regards Andrew T.
Old 6th November 2012, 12:51 PM   #443
R.I.P.
Originally Posted by roender View Post
I second that. It's not an easy job and took many hours to closely match jfets.
And that is why I respect the Euvl team in the way they matched the output mosFETs of the F5x.
They developed a machine curve tracer that automatically logged the results and then used some software to select the matches from those many thousands of results.
A similar system could be used to these jFETs, but having read their testing procedure I think the resources they brought to the table would probably exceed the cost of all the F5Xs that are being built (about 50 so far).
regards Andrew T.
Old 6th November 2012, 04:32 PM   #444
R.I.P.
The grounding scheme with regulator for the front end Vcc/Vdd
There is no chassis and as a result no complications with extra connections to PE.
regards Andrew T.
Old 6th November 2012, 06:08 PM   #445
jprco is offline jprco  Canada
If it's not one thing - it's another!
Any reason why the links to the Reichelt BOM's for the FC100 components don't work anymore???
Old 6th November 2012, 07:53 PM   #446
Jean, I had to rebuild the carts!
Here they are again:
FC-100_Speaker Protection (needed 2 times):
https://secure.reichelt.de/index.htm...07;PROVID=2084
FC-100_Soft-Power-On (needed 1 time):
https://secure.reichelt.de/index.htm...09;PROVID=2084
FC-100_Shunt-Regulator (needed 2 times):
https://secure.reichelt.de/index.htm...04;PROVID=2084
FC-100_Amplifier (needed 2 times):
https://secure.reichelt.de/index.htm...39;PROVID=2084
FC-100_Backend-PSU (needed 2 times):
https://secure.reichelt.de/index.htm...41;PROVID=2084
Old 6th November 2012, 08:30 PM   #447
mj777 is offline mj777  Australia
Thanks for sharing the test rig Sir, yeah sure sir just pm me when you have already matched pairs of this transistors.
regards,
marjohn
Old 7th November 2012, 05:16 AM   #448
roender is offline roender  Romania
roender's Avatar
Hi Andrew,
You should connect A with E. Your topology is not suitable for ground separation between front end and power stage because there is only one common AC central tape.
Kind regards,
Mihai
Old 7th November 2012, 09:12 AM   #449
R.I.P.
How do the Roender PCBs connect together with dual bridges instead of single bridges?
This will not apply to the Rudi PCBs because the amp PCB has on board single bridge.
But I will probably use a common transformer arrangement for all the Roender and Rudi PCBs.
regards Andrew T.
Old 7th November 2012, 09:15 AM   #450
roender's Avatar
Do you mean dual bridge per channel? I had never use that configuration.
Roender's FC-100 Rev.1 Group-BuyHide this!Advertise here!
Sanyo/B&O Icepower 200AC Rev.D, schematic about rev. engin., not complete finished tiefbassuebertr Class D 50 12th April 2018 09:11 AM
Roender's FC-100 prototype and builder's thread Rudi_Ratlos Solid State 1007 30th July 2017 05:57 PM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Online vendors for Panasonic FC 1000/100 caps? analog_sa Parts 2 14th February 2007 02:19 AM
