Group Buys Members group buys
Roender's FC-100 Rev.1 Group-Buy
Old 20th October 2012, 01:46 AM   #411
evette is offline evette  Canada
Send a message via Yahoo to evette
P.S. I,ll send you something in a day or soon for your review,,I,m sure your going to like it . Evette
Old 20th October 2012, 11:40 AM   #412
wendell c is offline wendell c  United States
Got the PCB today along with transistors, thanks. Now will wait for tx and emitter resistor. Thanks
Sent from my Galaxy Nexus using Tapatalk 2
Old 24th October 2012, 08:49 AM   #413
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Gentlemen, I received the 4x34VAC shunt transformers today and will immediately send them to you.
Please keep in mind the image showing the colours of the primary and secondary windings.
Best regards - Rudi_Ratlos
Old 24th October 2012, 09:19 AM   #414
Sorry, Gentlemen, the transformers do not fit into the coated letters that I have. I have ordered suitable cardboards.
The shipping of the transformers is therefore delayed by 2-3 days.
Old 24th October 2012, 04:06 PM   #415
R.I.P.
use a bulb tester to save your transformer from damage. Determine the phasing of the primaries and mark the wires accordingly.
Determine the phasing of the secondaries and mark accordingly.
regards Andrew T.
Old 25th October 2012, 10:08 AM   #416
Fabrizio72 is offline Fabrizio72  Italy
Andrew,
can You better explain your last post? Why do I need to know the phase of the primary and the phases of secondaries? For grounding issues?
And how can I determine that? Relative polarity of secondaries can be detected quite easily: if I put two secondaries in series, "counter-phase alignement" will yield 0 Vac, while "equi-phase alignement" will yield 68 Vac...
I imagine that should exist a better method, isn't it?
Fabrizio
Old 25th October 2012, 10:17 AM   #417
R.I.P.
the two tappings for each winding are the same colour.
You must find which of the two ends match the corresponding ends of all the other windings. That is where we usually see a . (dot) used on the labeling and a colour code identifying that . (dot)
Take for instance a dual primary transformer without any phase coding.
For 110/120Vac mains power:
Wire the two windings in parallel but out of phase and the mains sees the primary winding resistance in parallel with the other primary resistance and when mains is powered on the transformer primaries draws hundreds of amps and instantly goes into NASA mode. The only thing that saves your transformer is the breaker back at the distribution board.
For 220/240Vac mains power:
Similarly wire the two secondaries in series but out of phase. The damage scenario is the same.
Use a bulb tester. The bulb will light if you wire the primaries wrongly. No damage. re-wire correctly, bulb stays off.
Now move to wiring the secondary. The out of phase secondaries when wired together will appear as a short across the two coupled windings. That again will damage the transformer if the distribution board circuit breaker does not come to your aid.
Use the bulb tester to prove you have wired the 4 secondaries correctly.
Why do we see so many not doing the research on the safe handling of transformers connected to mains power?
The information is spread around this Forum and repeated almost as often on ESP and yet we see Members asking the same questions "what are you talking about?"
regards Andrew T.
Old 25th October 2012, 10:59 AM   #418
Gentlemen, the coloration - as is - of the transformer's leads has been requested by me.
Please have a look at the attached image.
You can see two secondary windings, with green and blue leads, labelled 1/2 and 3/4.
If you take a closer look, you can see that lead 2 starts as a blue wire ending in "green" and lead 3 starts as a green wire ending in "blue".
Connect the "blue-starting" leads 2 and 4 together resulting in 68VAC between the the green leads.
The same applies to the red and brown leads.
Connect the "red-starting" leads together resulting in 68VAC between the the brown leads.
Of course: use a bulb-tester before applying voltage to the transformer.
Old 25th October 2012, 12:29 PM   #419
Dear AndrewT,
You are right! My ignorance is evident...
And surely I will fill this gap quickly! I had never used bulbs in the past, despite I've read something about. But, for sure, I will, in the future. (Rudi describe it at page 7 in builder's manual)...
But don't worry that I never play with mains. I don't enjoy myself in taking risk by guessing. Safety is the first thing!
That's why I always use a fused and isolated variac (with Amp-meter) to power everything I start to build, and put extra fuses along wires during first startup.
Now, looking now at the shunt PCB I can see that two taps are connected together and connected toground (i.e. they are not "floating"). So When recognized that, my first question should be: how to connect the transformer correctly so that at "the opposite sides" of diode bridge flows 68Vac and not 0 Vac?
I can also understand that connecting two secondaries counter-phase will produce magnetic field cancelation, so that the coils behave like a short copper wire with catastrophic effects...
I promise that before start to working on I will be engaged with bulbs!
Kind regards
Fabrizio
Old 25th October 2012, 01:41 PM   #420
Fabrizio, have a look at my post #418.
The attached image shows you how to attach one shunt-regulator to the "green" and "blue" secondary windings.
Do not forget to manually solder the pink wires on the solder-side after you have finished the Shunt PCBs.
Roender's FC-100 Rev.1 Group-BuyHide this!Advertise here!
Sanyo/B&O Icepower 200AC Rev.D, schematic about rev. engin., not complete finished tiefbassuebertr Class D 50 12th April 2018 09:11 AM
Roender's FC-100 prototype and builder's thread Rudi_Ratlos Solid State 1007 30th July 2017 05:57 PM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Online vendors for Panasonic FC 1000/100 caps? analog_sa Parts 2 14th February 2007 02:19 AM
