Group Buys Members group buys
Roender's FC-100 Rev.1 Group-Buy
Old 10th September 2012, 04:57 PM   #191
zsaudio is offline zsaudio  Europe
Maybe it's time to buy the last pieces from the market.
Old 10th September 2012, 04:58 PM   #192
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Patrick,
the max. grid of the input DC-blocking input capacitor is 15mm.
Everybody has to decide by himself, if he needs an input-cap at all.
If he is sure that all of his music - sources are AC-coupled, he doesn't need.
If not:
I recommend to use of MKT1822 bypassed by MKP1837.
I use this combination myself: I "glued" the MKP on the solder-side and then soldered it.
The value: max. value with a grid of 15mm.
Do you have any other recommendation?
Best regards - Rudi
Old 10th September 2012, 05:17 PM   #193
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
At a dutch forum someone is offering Vishay-Roederstein 1820/10F MKT's for a fair price.You always can bypass them with the MKP1837
Old 10th September 2012, 06:10 PM   #194
julius20 is offline julius20  Germany
I used this one: IT-Tronics - 5x MKT Kondensator radial 10uF 100VDC RM27,5 ; RoHS ; 1822610015
they will be 5 for five pieces ( Roederstein MKT1822/100V )
Old 10th September 2012, 06:43 PM   #195
10y is offline 10y  Italy
Hi Rudi,
I am in for one set output transistors, shunt pcb, speakers protection and turn on delay pcbs.
Count on me for any support you need for this GB.
Thank you !
Anto
Old 10th September 2012, 11:31 PM   #196
jprco is offline jprco  Canada
Rudi, can this version of the F100 use the NJL1302DG/NJL3281DG pair without any modifications?
Old 11th September 2012, 08:04 AM   #197
R.I.P.
If you can find an old stock polycarbonate folded film (rather than wound) then it is almost as good as polypropylene at half the price and half the size.
I think the carbonates are better than the various esters and terephthalates.
Polyethylene terephthalate (sometimes written poly(ethylene terephthalate)), commonly abbreviated PET, PETE, or the obsolete PETP or PET-P,
regards Andrew T.
Old 11th September 2012, 08:39 AM   #198
Julius, the 10F MKT1822 has a grid of 27.5mm , whereas the PCB offers space for a 15mm grid capacitor only.
The input capacitor C15 blocks DC; together with resistor R26 it defines a highpass - filter.
It is not essential to use a 10F on this position. I myself use a 2.2F MKT1822.
And, please remember: "The best filter is no filter at all!" Mihai does not use this capacitor in his original schematics!
Maybe all of your music-sources are already AC coupled: then you need not install C15 but use the jumper.
For me, it is a "Must have", because I am DIYing all kind of music-sources (Pre-AMPs, DACs, ...), and maybe that one of my builds is not working properly.
Anto: you are very welcome!
Jean: maybe, I never tested this, but I would not use the NJL1302D/NJL3281D pair of transistors.
The reason why: the output capacitance (COB) of the pair of NJL1302D/NJL3281DG is much higher (600pF) compared to the COB
of a pair of NJL0302D/NJL0281D, which is 400pF.
The drivers have to load/unload this excess of capacitance, and I am afraid that this will affect the overall operation.
Perhaps somebody else knows it better.
Best regards - Rudi_Ratlos
P.S. Andrew: thank you for your hint.
Old 11th September 2012, 08:48 AM   #199
R.I.P.
Don't make the input cap too big.
The filter, if you decide to fit it, must set the LF bandwidth.
That bandwidth MUST be properly amplified by the Power Amplifier.
That requires all the following filters to be wider band than the input filter.
Even the PSU filter must be wider than the input filter.
Your sch shows 10uF and 22k+2k for a 240ms time constant.
That gives a F-3dB = 0.66Hz.
That would require that the amplifier can handle frequencies down to that level.
A 3u9F or 3u6F would suit me. Try it. Even 3u3//22n might be good enough.
regards Andrew T.
Old 11th September 2012, 09:03 AM   #200
Andrew, I will correct the schematics im my "Builder's Manual".
I will send this manual to all participants of this group-buy at the time, the group-buy is closed.
Best regards - Rudi
Roender's FC-100 Rev.1 Group-BuyHide this!Advertise here!
Sanyo/B&O Icepower 200AC Rev.D, schematic about rev. engin., not complete finished tiefbassuebertr Class D 50 12th April 2018 09:11 AM
Roender's FC-100 prototype and builder's thread Rudi_Ratlos Solid State 1007 30th July 2017 05:57 PM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Online vendors for Panasonic FC 1000/100 caps? analog_sa Parts 2 14th February 2007 02:19 AM
