Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 66 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 17th October 2012, 01:52 AM   #651
qusp is offline qusp  Australia
qusp's Avatar
exactly, ive kept out of that thread for that reason.... I think its funny that the armchair experts here are poo pooing this idea when its currently one of Ian's preferred clocking methods, presumably he has other options.... all this commentary while having NO experience of their own with the part.
but hey who needs facts when you have conjecture?
perhaps i'll go bump the Si570 thread, maybe I should go rubbish the NOS thread while i'm at it? I dont really do nos dacs, but instead of criticising it, I actually posted my support in there because regardless of my views I think its a good solution to the problems at hand
Old 17th October 2012, 06:24 AM   #652
roender is offline roender  Romania
roender's Avatar
Originally Posted by qusp View Post
indeed it seems some are a bit slow on the uptake around here.... numbers are in fact better than cchd950
Do you have some proof, measurements? I will change my opinion if this is true!
Old 17th October 2012, 06:38 AM   #653
Please move further technical discussion to the other thread - Si570 based 2ps RMS low jitter universal audio clock project
Ian has discussed the performance of these clock chips in the posts that I have linked here - if you can read about Ian's impressions/experiments that might give a better starting point for discussions.
Old 17th October 2012, 02:18 PM   #654
andrea_mori's Avatar
Seems there is a little confusion...
The matter is not NOS or not NOS, the matter is good or not good clock.
What problem to build a 49.152 or 80 MHz clock in the simpler way like a crystal and an active device?
Overtone crystal go easily over 100MHz..
From the other Ian's thread:
Disadvantages:
1. Close-in phase noise performance is not as good as CCHD957 or sc-cut oscillators.
My comment: CCHD957 does not excell in phase noise, and high Q AT-cut crystal oscillator perform better than CCHD957 or SI570, at lower cost.
This is my last post about SI570 in this thread, more comments rightly in the specific thread.
Andrea
Old 17th October 2012, 03:24 PM   #655
N02. spm I2S FIFO,Dual XO Clock board,S/PDIF Interface Board,2x SMT U.FL,8x 6",4x 12”,I2S backdoor KIT, 2xXO Adapters lot of 5,2xBIII adapters,2x SMT connector package
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
N17. Finaxe 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N18 Tagheuer 1x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
N21. marcus1 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N22 Joonas 1 x I2S FIFO kit and 1 x S/PDIF interface board
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4” double-ended 50 ohm coaxial cable
N24 chi0001 1 x I2S FIFO KIT 6 x 4" Cables 1 x Dual clock board
N25 rsotirov 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x
N26. miksi, 2 x BIII Adapters PCB, 2 x SMT Connector for BIII adapters, 20 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
N27 hirez69, 1 x I2S FIFO KIT, 1 x Dual XO Clock Board, 1 x Universal SMT XO Adapters KIT, 4 x BIII Adapters PCB, 1x S/PDIF Interface, 1x I2S backdoor KIT
N28 hochopeper, 1 x I2S FIFO KIT, 1 x Dual XO clock board, 1 x universal SMT XO ADAPTERS KIT, 8 x 4" coax cables
N29 edbk 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
Old 17th October 2012, 03:33 PM   #656
N02. spm I2S FIFO,Dual XO Clock board,S/PDIF Interface Board,2x SMT U.FL,8x 6",4x 12,I2S backdoor KIT, 2xXO Adapters lot of 5,2xBIII adapters,2x SMT connector package
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4 double-ended 50 ohm coaxial cable
N30 andrea_mori 2 x I2S FIFO
Ian,
any news about I2S to PCM daughter board?
Old 17th October 2012, 11:21 PM   #657
iancanada's Avatar
Originally Posted by andrea_mori View Post
Ian,
I opened a new thread for the I2S to PCM daughter board. You can take a look at there. For NOS guys .
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
Ian
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 21st October 2012, 05:49 AM   #658
acko is offline acko  Australia
N30 acko 1x I2S FIFO Kit
AckoDAC Project
Old 21st October 2012, 06:06 AM   #659
qusp's Avatar
haha finally! took your time mate, its pretty awesome
Old 21st October 2012, 07:21 AM   #660
Yeah mate, the penny dropped!
AckoDAC Project
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4354 8th February 2017 09:16 AM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 01:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 08:01 PM
Copyright 1999-2017 diyAudio
