Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 25th July 2012, 07:42 AM   #471
roender is offline roender  Romania
roender's Avatar
Ian,
Sorry for not reading all the specs when I put myself on the waiting list for FIFO, Dual XO and SPDIFF interface, but I have to pass this GB now.
Kind regards,
Mihai
Old 25th July 2012, 07:54 AM   #472
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
and?… where is this 90.3168? like I said I already have 45.1584MHz. its the 90.3168/98.304MHz thats rare, with only the NDK as a standard part. then we face the current lack of 2048x mode. A quad XO board, or a clock that can switch speeds on the fly is what is needed to handle the full 44.1/48->352.8/384kHz sampling rate range.
I have to be clear for those who are reading, its only if you want the full 352.8/384kHz capability while maintaining the 44.1/48kHz that you have a problem; the 176.4/192kHz speeds are well catered for as is.
of course there is another solution; I/we can use puremusic or similar to upsample the 44.1/48kHz content before the signal is sent.
Old 25th July 2012, 09:16 AM   #473
daanve is offline daanve  Netherlands
#6 paid yesterday - no info in paypal notes. Thank you.
Old 25th July 2012, 10:09 AM   #474
roender's Avatar
This is the measured phase noise of SI570 extracted from here: Si570 Kit from K5BCQ
IMHO, not suitable for audio :-)
Old 25th July 2012, 10:51 AM   #475
#21 paid
Old 25th July 2012, 11:43 AM   #476
qusp's Avatar
funny that its already been used pretty successfully in audio. all clocks get worse as the frequency goes down and the crystek is no exception, the crystek is an extraordinarily good XO and has quite a bit better performance down low. It does not come in suitable speeds to solve the very particular problem i've been talking about since the post on the previous page, a problem you have not offered an alternative for. we all have access to the datasheet, posting excerpts from it tells me nothing the thread (anyone whos interested enough), myself or Ian dont know
now unless you are going to post an actual alternative, please leave it alone and do not post on the subject again. I shouldnt even be replying, you are free to not use it.
Old 25th July 2012, 12:16 PM   #477
roender's Avatar
Would you please specify where is used? In which project here at diyaudio or elsewhere?
Please compare it with this:
XO
or, from the same manufacturer but dedicated for audio:
http://www.crystek.com/crystal/spec-...k/CCHD-957.pdf
My point is clear: si570/571 proposed by you isn't suitable for audio. It is just a generic XO with a variable output frequencies.
The alternative is to have a FIFO with software able to accept all DSD and PCM formats. There is something in this forum able to do that but from other perspective - SDtrans384
This doesn't means that this project isn't valuable. It's beautifully conceived but not complete (IMHO)
Old 25th July 2012, 03:17 PM   #478
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
#39 paid
Thanks Ian
Old 25th July 2012, 09:06 PM   #479
iancanada's Avatar
Originally Posted by roender View Post
Ian,
Kind regards,
Mihai
Thanks Mihai for letting me know. You can quit GB II I don't have problem. Come back at any time to me if you want.
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 26th July 2012, 03:57 AM   #480
iancanada's Avatar
Hi Mihai,
Just a kindly discuss with you. I saw that phase noise plot long times ago. But I don’t know if you noticed the testing condition. The guy did the test by a R3463 spectrum analyzer , not a phase noise analyzer. He clearly mentioned that he had limitation on close-in phase noise measurements. That means the close-in phase noise result was not accurate. However the Si570 phase noise floor won all other reference oscillators which was true. So, I list the link of where the plot originally came from just in case there was any misleading by it.
http://www.cliftonlaboratories.com/si570_kit_from_k5bcq.htm
I attached the rated phase noise performance of Si570 from Silicon Labs official documents. It’s -112 dBc/Hz at 100Hz and -150dBc/Hz at 10Mhz, sounds not that bad. At least, among all the XOs with programmable output frequency, it one of the best.
I don’t know what kind of XO you are looking for, as you said, suitable for audio application. Actually I have all of the four XO oscillators you mentioned, CCHD957, Si570, NDK, TentLabs J. I did very careful test and comparing between them. But I would not post the result. Because too much personal preference. I’ll leave this part to other members, as well as the funs. I pay respect to their knowledge and their ears. I don’t think you’ve already experienced Si570 for it need a firmware driver and an evaluate board, but I’m highly suggesting at least doing a comparing test between the other three. The result would be very interesting.
BTW, Si571 is a different story. It has an analog frequency feedback control input Vc which is very easy to introduce phase noise. It results in 30dBc/Hz worse than the Si570 on close-in phase noise performance. So I’ll not take Si571 into account.
Again, it’s just an open discussing. I’m toleranced with different idea. As R&D engineer, I always tend to do something ‘real’ with talking lessJ.
Ian
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 2786 16th May 2013 10:22 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Page generated in 0.22629 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
