Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 41 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 16th July 2012, 08:44 PM   #401
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by MisterRogers View Post
No doubt - it's one hell of a piece of kit!
that it is.. sounds superb too! if I could make 2 of them work together in a 4 channel rig i'd be buying a second one. for now i'll just have to wait patiently, giving Ian a friendly Jab in the ribs every now and then to remind him about multichannel
Old 16th July 2012, 09:04 PM   #402
iancanada's Avatar
Thanks qusp, I'll try to keep in mind .....the .... multi-channel FIFO.... .
Ian
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 16th July 2012, 09:21 PM   #403
iancanada's Avatar
Default Please change the color of the order form if it is possible
I found I set wrong foreground colors in some blue cells of the order form. Sorry about the confusing. If it is possible, change it to black when you fill in. Or, just forget about it, any way, I can change them later on.
Ian
Old 16th July 2012, 10:04 PM   #404
qusp's Avatar
Ian
you know, just in case you forgot…do want
pretty easy to forget with this going on, jeebus mate, this things going off!
have you prewarned paypal about the large influx? I would if I were you; sometimes they can be stupid and freeze your account...for your own safety when large amounts of payments from different sources come in
Old 16th July 2012, 10:26 PM   #405
BDL is offline BDL  Romania
1 JamesHill 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
2 chansiukwing
3 lordvader 1*I2S FIFO KIT 1*Dual XO Clock board
4 karvid 1*I2S FIFO KIT 1*Dual XO Clock board
5 Blitz 1*I2S FIFO KIT 1*Dual XO Clock board S/PDIF Interface Board
6 daanve I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
7 Turbon I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
8 slartibartfasstI2S FIFO KIT -Dual XO Clock board
9 merlin2069er 1*I2S FIFO KIT 1*Dual XO Clock board
10 roger57 1*I2S FIFO KIT 1*Dual XO Clock board, confirmed right justified 16/24 support
11 andrea_mori 2 * I2S FIFO KIT - 1 * S/PDIF Interface Board-4 * 6" (need support left-justified format for SM5842)
12 ryanj 1*I2S FIFO KIT 1*Dual XO Clock board
13 Rupor54 I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
14 roenderI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
15 regalI2S FIFO KIT -Dual XO Clock board
16,17 PET-240I2S (FIFO KIT -Dual XO Clock board -S/PDIF Interface Board)*2
18 lwifI2S FIFO KIT -Dual XO Clock board - S/PDIF Interface Board
19 vd-twoI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
20 hochopeperI2S FIFO KIT -Dual XO Clock board
21 necplusultraI2S FIFO KIT -2* Dual XO Clock board
22 lllI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
23 NicMac I2S FIFO KIT - Dual XO Clock board - 2*S/PDIF Interface Board - 6*Universal XO adapters, 2*BIII u.fl and clock adapters - 4*4" double-ended 50 ohm coaxial cable - 4*6" double-ended 50 ohm coaxial cable
24 SPWONG I2S FIFO KIT -Dual XO Clock board
25 MisterRogers I2S FIFO KIT -Dual XO Clock board, 3 x universal XO adapters, 2x BIII u.fl and clock adapters, 3*4" double-ended 50 ohm coaxial cable, 3*6" double-ended 50 ohm coaxial cable.
26 Atom6422 1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x 12” coaxial cable
27 hirez69 1*I2S FIFO KIT, 1*DUAL XO CLOCK BOARD, 1*S/PDIF Board, 3*BIII Adapter PCB INPUT (fully assembled), 3*BIII Clock Adapter (fully assembled), 15*XO Universal PCB Adapter, 8*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable, 4*12" double-ended 50 ohm coaxial cable
28,29 elecon FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
30 Rosendorfer : 1x I2S FIFO KIT - 1x Dual XO Clock board - 1x S/PDIF Interface Board - 1x I2S Backdoor - 1x BuffIII adapter - 3x u.Fl 4"" - 3x u.Fl 6'' - 3x u.FL SMD socket.
31 zinsula S/PDIF Interface Board
32 analog_sa1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x universal XO adapters, 1x BIII u.fl and clock adapters 7 x 4” coaxial cable
33 tjencks 1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4”
34 mravinsky 1 x I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
35 neb001 1x I2S FIFO KIT - Dual XO Clock board kit, 6 x universal XO adapters, 3x BIII u.fl and clock adapters
36 ccliu I2S FIFO KIT x1 Dual XO Clock board x1 S/PDIF Interface Board x1
37 florianderton I2S FIFO KIT, Dual XO Clock board, S/PDIF Interface Board
38 ENSen 1 x I2S FIFO KIT, 1 x Dual XO board, 5 x universal XO adapters, 3x BIII u.fl and clock adapters, 6*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable.
39 CeeVee 1 x I2S FIFO KIT, 1 x Dual XO board, 6 x universal XO adapters, 3x BIII u.fl and clock adapters, 6*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable.
40 kvl 1x I2S FIFO KIT ,1x Dual XO Clock board,1x S/PDIF Interface Board, 3x universal XO adapters, 2x BIII u.fl and clock adapters, 6x 4" double-ended 50 ohm coaxial cable, 2x 6" double-ended 50 ohm coaxial cable.
41 lindamar 2 x Universal SMT XO Adapters set , 3 x Additional BIII adapters PCB , 3 x SMT connector package for BIII adapters , 6 x 6*4" double-ended 50 ohm coaxial cable , 6 x 6" double-ended 50 ohm coaxial cable
42 bigpandahk 10 x SMT U.FL socket, 2 x I2S backdoor KIT for S/PDIF board, 2 x Package of Universal SMT XO Adapters KIT lot of 5, 4 x Additional BIII adapters PCB , 4 x SMT connector package for BIII adapters, (I've returned the FIFO to you for FW upgrade)
43 cracra 1 * I2S FIFO KIT , 1 * Dual XO Clock board ,1 * S/PDIF Interface Board, 4 * 4" double ended 50 Ohms cable, 4 * 6" double ended 50 Ohms cable, 6x universal SMT XO adapters, 3x BIII u.fl and clock adapters, 3 *SMT connector package for BIII adapters, 3 *Additional BIII adapters PCB, 2 * I2S backdoor KIT for S/PDIF
44 Eternalightwith - 1 * I2S FIFO KIT ; 1 * Dual XO Clock board ; 1 * S/PDIF Interface Board, 1 ; I2S backdoor KIT for S/PDIF
45 ruupie - 1 * I2S FIFO KIT ; 1 * Dual XO Clock board ; 1 * S/PDIF Interface Board, 1 ; I2S backdoor KIT for S/PDIF
46 BDL 10 x SMT U.FL socket, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters.
Old 16th July 2012, 11:05 PM   #406
tjencks is offline tjencks  United States
2 chansiukwing
33 tjencks 1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4”, 2x BIII u.fl and clock adapters, 2 *SMT connector package for BIII adapters, 2 *Additional BIII adapters PCB, 4*4" double-ended 50 ohm coaxial cable - 4*6" double-ended 50 ohm coaxial cable
Old 16th July 2012, 11:15 PM   #407
2 chansiukwing
47 edlinssen:1*i2S Fifo Kit, 1*Dual XO Clock Board, 1*SPDIF Interface board,1*i2S Backdoor kit for SPDIF, 1* Connector package forBIII adaptors,4*4'' 50 ohms cables, 6* ufl fem. board connectors, 1*set of universal SMT XO adaptors.
Old 17th July 2012, 02:41 AM   #408
iancanada's Avatar
Thanks qusp for your reminding, just sent email to them, hope there is no any problem.
Have a good night.
Ian
Old 17th July 2012, 02:54 AM   #409
Ian, qusp isn't alone
Old 17th July 2012, 03:04 AM   #410
iancanada's Avatar
I know .
Have a good night.
Ian
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4410 Today 04:14 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2017 diyAudio
