Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Downloaded the gblll zip. Filling it out right now... But before i proceed, will there be benifits in sound quality by using the u. fl connectors instead of the PH connectors?
Thanks hochopeper
Depends on your dac, what frequency clocks you use and a few other things.
If you have u.fl connectors available on your dac, use them, otherwise its a bit of a grey area. I use them.
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 2x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x battery management boards, 4x Isolator board kit
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 1x I2S backdoor KIT, 1x Package of Universal SMT XO Adapters, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x battery management board, 1x isolator board, 1x Si570 clock board
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 3 x battery management board
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
N17. Finaxe 1x I2S FIFO Kit, 2x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 1 x battery management board
N18 Tagheuer 2x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm, 1x isolator board kit , 1 x battery management board
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
N21. marcus1 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT for S/PDIF board, 1x Isolator board kit, 1x battery management kit
N22 Joonas 1 x I2S FIFO kit and 1 x S/PDIF interface board
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4” double-ended 50 ohm coaxial cable
N24 chi0001 1 x I2S FIFO KIT, 6 x 4" Cables, 6 x 6" Cables, 1 x Dual clock board, 1x S/PDIF Interface, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters, 1 x SMT connector package for BIII adapters.
N25 rsotirov 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x Universal SMT XO
Adapters KIT, 8 x 4" coax cables, 1X Isolator board kit, 2X battery management boards
N26. miksi, 2 x BIII Adapters PCB, 2 x SMT Connector for BIII adapters, 20 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
N27 hirez69, 1 x I2S FIFO KIT, 1 x Dual XO Clock Board, 2 x Universal SMT XO Adapters KIT, 8 x BIII Adapters PCB, 1x S/PDIF Interface, 1x I2S backdoor KIT, 4 X battery management boards
N28 hochopeper, 1 x I2S FIFO KIT, 1 x Dual XO clock board, 1 x universal SMT XO ADAPTERS KIT, 8 x 4" coax cables, 1 x isolator board kit, 2 x battery management board
N29 edbk 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 20 x SMT U.FL Socket, 8 x 4" coaxial cable 50ohm, 8 x 6" coaxial cable 50ohm, 8 x 12" coaxial cable 50ohm
N30 andrea_mori 3 x I2S FIFO, 5 x isolator board kit
N31 acko 1x I2S FIFO Kit, 1x Dual XO Clock Board
N32 vitalica 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board ,20 x SMT U.FL Socket, 12 x 4" coaxial cable 50ohm, 12 x 6" coaxial cable 50ohm, 12 x 12" coaxial cable 50ohm;4 x isolator board kit and 4 x battery management board.
33 TV Man 2 x i2s FIFO kit, 2x Dual XO Clock Board - Need other parts too, ie. sockets and cables, but have to sort out which ones.
N34 supra 1xI2S FIFO kit, 1x Dual XO Clock board
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board, 1x Isolator board kit, 1x battery management kit
N36 normundss 1x I2S FIFO KIT, 1x Dual XO Clock board, 1x S/PDIF Interface board, 1x I2S backdoor KIT, 1x BIII adapter KIT, 3x 4” double-ended 50 ohm coaxial cable
N37 AR2 1x isolator board kit and 1 x battery management board
N38 BDL 1 x isolator board kit, 2 x battery management board, 10 x SMT U.FL socket, 4 x 4” double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board
N39 NicMac 20 x battery management boards
N40 leejh 1*I2S FIFO KIT, 1*Dual XO Clock board , 1 x BIII adapter, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 4 x SMT U.FL Socket, 2 x 4" coaxial cable 50ohm, 1 x 6" coaxial cable 50ohm, 1x isolator board kit and 3 x battery management board
N41 necplusultra 1*I2S FIFO KIT,2 x battery management boards
N42 ruupie 1*I2S FIFO KIT, 1*Dual XO Clock board , 2x isolator board kit and 3 x battery management board
N43 crazikid 1x I2S FIFO Kit, 1x Dual XO Clock Board
N44 Odysseas 1xI2S FIFO KIT,2xDual XO Clock board, 1xS/PDIF Interface Board, 2xU.FL coaxial cable connection accessories, 1xI2S backdoor KIT for S/PDIF board, 1xPackage of Universal SMT XO Adapters, 1xAdditional BIII adapters PCB, 1xSMT connector package for BIII adapters, 4xTI boards(if possible), 4xbattery management boards(if possible),1xisolator board
N45 Slartibartfasst 2x battery management board, 2x isolator board
N46 Greg Stewart 1 x isolator board mini kit
N47 DUC985 1xI2S FIFO KIT,1xDual XO Clock board
N48 crobbins5421 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x isolator board kit
N49 MisterRogers 1x I2S FIFO Kit, 2x Dual XO Clock Board, 2x isolator board kit, 2x BIII adaptors 12x 6" U.FL
N50 lwif 1 x isolator board kit, 2 x battery management board ( or more if available)
N51 atom6422 1 x isolator board kit, 2 x battery management board
N52 JamesHill1 x isolator board kit, 1 x battery management board
N53 deanoUK 1x I2S FIFO Kit, 1x Dual XO Clock Board, 26 X SMT U.FL socket, 1 X Package of Universal SMT XO Adapters, 10 x 4” coaxial, 2 x 6” coaxial, 1 x 12” coaxial, 4 X Additional BIII adapters PCB, 5 X SMT connector package for BIII adapters,1 x isolator Board
N54 mravinsky 1x isolator board kit, 5 x battery management board, 8 x 4” double-ended 50 ohm coaxial cable, 4 x 6” double-ended 50 ohm coaxial cable, 10 x SMT U.FL Socket
N55 Popolvar 1 x I2S FIFO KIT, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 2 x battery management boards,1 x isolator board
N56 qusp 4 x 4” double-ended 50 ohm coaxial cable $2 USD/ea, 1 x backdoor kit, 1 x isolator kit
N57 nvduybom 1x I2S FIFO KIT V3.80 $149- USD/ea, 1x Dual XO Clock board V3.3 $59- USD/ea, 1x S/PDIF Interface Board $89- USD/ea, 1x Additional BIII adapters PCB $3.99 USD/ea, 1x MT connector package for BIII adapters $3.99 USD/ea, 1x Battery management PCB free
N58 TUBO 1 X I2S FIFO KIT V3.80, 1X DUAL XO CLOCK BOARD, 1X SPDIF INTERFACE BOARD, 1X SMT XO ADAPTER PACKAGE, 6X 6" U.FL CABLE, 1X BATTERY BOARD.
THANKS AGAIN
I added some items.
