Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 36 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 6th July 2012, 09:56 AM   #351
triode_al's Avatar
Default Bitrate shaping
Ian, I take the time now to post something I should have done long ago. I once was part of an R&D project for asynchronous transfer mode communication. The problem we faced was extreme burstiness of the sender (e.g. TV frames). One research fellow from London had the idea of bit rate shaping: by using two buckets with just a shallow bit depth he showed it was possible to accommodate for most burtiness such that the output was near to constant bit rate. Since that time large routers (I remember from Cisco) have a double buffer at the receiving side.
I know you have a big buffer to accommodate for fluctuations. However, it would be fun if this idea of two series buffers would help you.
I hope I'm not completely off track.
albert
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 6th July 2012, 11:10 AM   #352
Hi Ian
Regarding Buffalo III adapter boards...
I'm not sure if You are planing to ship them already fully assembled with u.fl conectors and 2 x 10pin headers..as I can see at Your pictures.
I thing that for Buffalo II owners could be better to have just u.fl sockets and free access to confection pads on the other side of PCB.
Actually just clean PCB and not mounted u.fl conectors that would be OK with me.. There should be some "DIY-handmade" way to connect it to "ancient" BuffaloII ...
Well actually it seems to be perfect!!! for my Duall Mono I2S wiring set-up..
Best Regards
Rosendorfer
Old 6th July 2012, 05:03 PM   #353
iancanada's Avatar
albert
Hi Albert,
Thank you for shareing you idea. It's an interesting method. I'm figuring out the multichannel FIFO now which will need more buffer memory. I'm interested in using smaller memory. Your idea might be help.
I appreciate your experience. Have a nice weekend.
Ian
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 7th July 2012, 02:12 AM   #354
iancanada's Avatar
Originally Posted by Rosendorfer View Post
Hi Ian
Best Regards
Rosendorfer
Soldering those U.FL sockets is not an easy job. I would be more than happy to supply the bare PCB only.
Ian
Old 7th July 2012, 02:34 AM   #355
qusp is offline qusp  Australia
qusp's Avatar
I only need bare PCB, I need mix of u.fl and w.fl
Old 7th July 2012, 04:42 PM   #356
PET240 is offline PET240  Australia
I need soldering practice.......
Old 7th July 2012, 06:47 PM   #357
qusp's Avatar
they really arent that hard, Ian is exaggerating it, or he is too used to having excellent tools or reflow =) w.fl are a bit harder (about 3-4x smaller again) but still totally doable
Old 7th July 2012, 10:36 PM   #358
So your place then?
;-) Thanks for the heads up!
Old 8th July 2012, 02:27 PM   #359
Hi guys
Im waiting for XMOS based converter from Lorien and have few questions regarding FIFO device.
1. Would it be still improvement to add FIFo to chain together with XMOS converter or converter should make its job alone with great results?
2. I use Spencer DAC now with I2S connection but I have plans for AD1865 DAC with SPDiF outputs only and receiver would be WM8804. Spencer uses CS8416 receiver. I assume in such case its better to use Ian SPDiF device for both DACs. Do I loose a lot in SPDiF connection vs I2S or its not that obvious when digital section is well implemented?
3. Is it worth buying dual XO board? What are benefits? Anyone tested?
I still search best solution from PC sound so if anyone tested mentioned above I would appreciate it
Old 9th July 2012, 10:18 AM   #360
Originally Posted by zibra View Post
Hi guys
--------I have one of these.
--------I have these on order, so when Ian is ready I will hope to be as well. I would use the WaveIO isolated outputs into the FIFO then to dac, one less conversion. I'm pretty sure Ian has allowed for your dac in upcoming firmware. Check previous posts for this info.
--------I2S requires impedance matching on the transmission lines to the dac, if not done correctly it will smear and affect the waveform with reflections, google Steve Nugent/empirical audio and you will learn much. if the i2s is done correctly you are much better off. There will be others here that know much more than me.
--------Dual XO board allows for all sample rate multiples of 44.1 and 48kHz. If you listen to anything other than 44.1, you will need the Dual XO.
--------I have the Wave on a Alix 2D2>waveIO>fifo(soon)>Buff III>tube I/v(soon). I run mpdpup on the Alix which is easy to install and tweaks are forthcoming, you can read up here.
Puppy Linux Discussion Forum :: View topic - mpdPup - Simplified MPD Music Server/Jukebox - v0.9.2
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4403 Yesterday 09:22 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2017 diyAudio
