Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 34 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 28th June 2012, 10:12 PM   #331
iancanada's Avatar
Originally Posted by lindamar View Post
Hi everyone,
could somebody please give me some light about those clock adapter and buffaloIII boards ?. I have a Buffalo III DAC as well.
There has been a couple of months since I bought the FIFO a dual XO clock and it seems that I am missing something hot in here.
cheers
Pepe
First order lost by DHL. Re-ordered again. Will arrive next week. Including universal SMT XO adapter, U.FL to BIII input adapter and BIII async mode adapter. If you are GB I user and did get, you still have chance to get one for free.
Ian
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 1st July 2012, 10:21 AM   #332
I'm interested in 2 BIII adapter PCBs
Old 2nd July 2012, 09:23 PM   #333
roger57 is offline roger57  Canada
roger57's Avatar
Originally Posted by iancanada View Post
1 JamesHill 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
2 chansiukwing
3 lordvader 1*I2S FIFO KIT 1*Dual XO Clock board
4 karvid 1*I2S FIFO KIT 1*Dual XO Clock board
5 Blitz 1*I2S FIFO KIT 1*Dual XO Clock board S/PDIF Interface Board
6 daanve I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
7 Turbon I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
8 slartibartfasstI2S FIFO KIT -Dual XO Clock board
9 merlin2069er 1*I2S FIFO KIT 1*Dual XO Clock board
10 roger57 1*I2S FIFO KIT 1*Dual XO Clock board, confirmed right justified 16/24 support
11 andrea_mori 2 * I2S FIFO KIT - 1 * S/PDIF Interface Board-4 * 6" (need support left-justified format for SM5842)
12 ryanj 1*I2S FIFO KIT 1*Dual XO Clock board
13 Rupor54 I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
14 roenderI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
15 regalI2S FIFO KIT -Dual XO Clock board
16,17 PET-240I2S (FIFO KIT -Dual XO Clock board -S/PDIF Interface Board)*2
18 lwifI2S FIFO KIT -Dual XO Clock board
19 vd-twoI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
20 hochopeperI2S FIFO KIT -Dual XO Clock board
21 necplusultraI2S FIFO KIT -2* Dual XO Clock board
22 lllI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
23 NicMacI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
24 SPWONG I2S FIFO KIT -Dual XO Clock board
25 MisterRogers I2S FIFO KIT -Dual XO Clock board
26 Atom6422 1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x 12 coaxial cable
27 hirez69 FIFO KIT, Dual XO Clock board, S/PDIF Interface Board,6 X SMT U.FL 4 X 6 and 2 X 4 double-ended U.FL cables (and 14 XO adapter PCBs)
28,29 elecon FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
30 Rosendorfer I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
31 zinsula S/PDIF Interface Board
32 analog_sa1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4 coaxial cable
33 tjencks 1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4
34 mravinsky 1 x I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
35 neb001neb00135 neb0011x I2S FIFO KIT - Dual XO Clock board kit
36 ccliu I2S FIFO KIT x1 Dual XO Clock board x1 S/PDIF Interface Board x1
37 florianderton I2S FIFO KIT, Dual XO Clock board, S/PDIF Interface Board
Please let me know for any question.
Ian
Hi Ian,
I have a question. I'm not sure what you mean by "confirmed right justified support"? I don't recall asking for any particular format, just indicating I have a TDA1541A. The TDA1541A is left-justified, correct?
Please clarify.
Thanks,
Gary
Old 2nd July 2012, 09:37 PM   #334
PET240 is offline PET240  Australia
I also want to run on TDA1541. Do I need a FW change or are these all set by jumper?
Thanks Ian, hope all is going well!
Your efforts are appreciated!
Old 2nd July 2012, 09:46 PM   #335
roger57's Avatar
Originally Posted by roger57 View Post
Hi Ian,
Please clarify.
Thanks,
Gary
I just checked my schematic and the TDA1541A datasheet. I'll have pin 27 of the TDA1541A tied to VCC, indicating it's I2S (mux'd 2's compliment)
Not sure if that means a firmware or jumper change on the board...
Thanks,
Gary
Old 2nd July 2012, 11:36 PM   #336
iancanada's Avatar
Thanks,
Gary
With PIN27 connected to Vcc,TDA1541 works at I2S mode. You don't need setting any jumpter. FIFO default output format is I2S.
Ian
Old 3rd July 2012, 01:37 AM   #337
roger57's Avatar
Ian
OK, thanks Ian.
If not too late (I imagine you're swamped with requests too) can you add a couple of 6" coaxial cables to my order?
Gary
Old 5th July 2012, 03:26 AM   #338
iancanada's Avatar
OK, thanks Ian.
Gary
That's no problem.
Ian
Old 5th July 2012, 03:38 AM   #339
iancanada's Avatar
Default Got PCB today
Got those adapter PCBs today finally! I made right decision, re-ordering the PCB immediately after found lost. The DHL investigating still under going, I don't think they could find anything.
I'll do some test and let you know the result tomorrow.
Have a good night
Ian
Old 5th July 2012, 07:35 AM   #340
karvid is offline karvid  Sweden
karvid's Avatar
Hi everyone out there!
I have ordered a FIFO kit and dual clock board. But since I have been reading about a BIII converter/adapter I wounder if this is needed for my BII dac?
Havn't seen any schematic so I do not really know which signal I get out from the FIFO, but is some signal missing that I need for my BII dac?
Thanks!
/ Kenneth
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4355 5th March 2017 07:47 AM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright 1999-2017 diyAudio
