Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Thanks guys. All invoices were sent for today’s order from. Please let me know if you didn’t receive it.
I’m working hard on preparing the packages and hopefully I can get them shipped in a week.
Price of #37A fully finished SinePi could be more expensive than you expected. It’s true. I’m also worried about that. The reason is that the production quantity is too small. I was trying my best but I really can not sell it at a lower price while covering the cost. I’m sorry about that.
That’s why I offer the #36A SinePi SMT finished KIT as a lower price option, as well as the 10% discount.
If you really care about the price, I would suggest you order the #36A for less expensive. I could be wrong, but based on my real listening experiences, there was no noticeable SQ difference between Omron RF relay and the signal relay.
The only thing I’m worried about is the quality of soldering of the pins and the SMA connectors.
SinePi has a four layers PCB. The inner layers are the whole pieces of ground/shield plates which could be a bit difficult to solder. You will need a high power (60W or higher) solder iron doing that job. Please make sure you have no problem with it.
Again, the sine to square wave converter is very significant to the final SQ of good sine clocks. And SinePi is also very sensitive to the power supply of it. A great power supply for SinePi can bring you more surprises.
Ian
One can experiment with taping copper foil on the non rf relay to see (hear) if there is any difference with rf shielding.
Don’t forget to connect to the ground tab on pcb.
1. Iancanada 1*SiniPi fully assembled, 1* UcPure, 1* LifePO4 Mini 3.3V, 1*Oven KIT, 2*6” and 2*10” SMA cable
2. Cerole 1*SiniPi fully assembled, 1* UcPure and 1*Oven KIT
3. A123 1*SinePi fully assembled with RF relay (SiniPi fully assembled), 1*UcPure, 1*LifePo4 Mini 6.6V
4. hires 1 * UcPure
5. pz1 1* siniPi fully assembled, 1* LifePO4 mini 3,3V
6. schiirn 1*SinePi KIT
7. linh0983 1* RelockPi, 1* LifePO4 Mini 3.3V
8. terry22 1*SinePi fully assembled, 1*Ucpure 15v, 1*Oven KIT
9. Narukas 1*SinePi fully assembled, 5* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
10. Raj1 2*UcPure
11 Eduard 1* SinePi fully assembled
12 SimonJ 1* SinePi fully assembled (can be kit if needed), 2* UcPure, 1* Oven KIT, 1* LifePO4 Mini 3.3V
13 Oyvind 1* LifePO4 mini 3,3V
14. kunlun121 1*SinePi fully assembled, 4*UcPure, 2*Oven KIT
15. Tubo- 2 SinePi fully assembled, 2*UcPure, 2* Oven kit, 2*6” and 2*10” SMA cable
16. wlowes 1*SinePi NOT assembled
17. AirAir 1*UcPure
18. trial and error 1*SinePi fully assembled, 1* Oven Kit, 1*LifePO4 Mini3.3V, 2*10" SMA Cable 2* StationPi Pro
19. jrocker 1*SinePi fully assembled, 2* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
20. ernesternest 1* UcPure, 1* LifePO4 Mini 3.3V, 1*Oven KIT
21. puuchan 1*SiniPi fully assembled
22. M_Balou 1* SinePi fully assembled, 1* Oven KIT
23. Atom6422 2* SinePi fully assembled, 2* Oven KIT, 2* LifePO4 Mini 3.3V, 2* ReClockPi, 1*StationPi
24. Photochum1 1 x SinePi fully Assembled, 2 x ReClockPi, 1 x StationPi Pro, 1 x UcPure, 1 x Oven Kit, 1 x HDMI Transmitter MK II
25. jimk04 1x sinepi assembled 1 x oven kit. 2 x LifePO4 Mini 6.6V, 2 x LifePO4 Mini 3.3v , 1 x StationPi/ pro if available
26. Paul M 1x SinePi fully assembled with RF relay, 2x Oven kit
27. efrank 1x SinePi Fully Assembled w/Relay, 1* LifePO4 Mini 3.3V
28. Ilgavro 2x sinepi not full assembled
29. mksung 1*SinePi SMT finished KIT, 1* UcPure
30. Morde 3* LifePO4 Mini 3.3V
31. casshan 1*SiniPi fully assembled with RF relay, 1* LifePO4 Mini 3.3V
32. Supersurfer: 1x UcPure, 2x LifePO4 Mini 3.3V
33. igor61> 2x LifePo4 Mini 3.3V, 1x UcPure
34. Subbu K: 2*LifePo4 Mini 3.3V, 1*LifePo4 Mini 6.6V
35. Greg Stewart 2x SinePi fully assembled with RF relay, 2x Oven KIT for SC-cut crystal, 2x 6" SMA coaxial cables
36. blue9527 1*UcPure, 1*FiFoPi Q3, 1*ReClockPi, 1*HDMIpi MkII, 1*CCHD957 XO adapter, 4*6" uFl cable, 2*4" uFl cable
37. Mobilux 1*SinePi fully assembled with RF relay, 1*UcPure 3.3v
38. jiacheng 1* SinePi SMT finished KIT, 6* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
39. byun3652 4* UcPure, 2*LifePO4 Mini 3.3V
40. AudioDAC 1*ReclockPi, 1*SinePii fully assembled with RF relay, 1* UcPure, 1*Oven KIT,2*10” SMA cable
41. Rrbs 1x SinePi fully assembled with RF relay, 2x 6" SMA coaxial cables
42. Sebbyp 3x SinePI fully assembled with RF relay (can take the finished kit too), 10* UC Pure 4x Oven Kit for SC-Cut Crystal 2x 6" SMA Cable
43. Stephen1212b 2*SinPI fully assembled with ref relay, 2* Lifepo4 mini, 2* oven kit, 4 * 6” sma cable
44. triode4 2 x SinePi fully Assembled, 2 x ReClockPi, 1 x StationPi Pro, 1 x UcPure, 1 x Oven Kit, 2 x HDMI Transmitter MK II,1 x FIFOPI Q2, 2*6” and 2*10” SMA cable
45. S610adam 2x UcPure
46. Aguaazul: 2 * 1* SinePi fully assembled (can be kit if needed), 3 * UcPure, 2 *10" SMA coaxial cables, 4 * 6" SMA coaxial cables. 1 * StationPi Pro,
47. sumire 1*SiniPi fully assembled, 2*Oven KIT, 4*6” and 2*10” SMA cable, 1*ReClockPi,1*StationPi Pro,
48. geoturbo 1* reclockpi, 1* sinepi kit, 2* 6" sma cable, 2* ucpure, 1* stationpi pro
49. bferg 1*reclockpi 1*sinepi fully assembled (kit ok if needed) 1*fifopi 1* transport pi 1* Stationpi pro
50. duster1 1*SinePi SMT finished KIT
51. JanVeg 1x SinePi fully assembled with RF relay and 2*6” and 2*10” SMA cable and 1 UcPure
52. rowli 3 x UcPure
53. ibraino 1*SiniPi fully assembled, 1* UcPure, 1* RelockPi, 1* LifePO4 Mini 3.3V
54. Michl2604, 1*ReclockPi, 1*LifePO4 Mini 3.3V, 1*LinearPi Solo, 4*6" uFl cable
55. seatrope, 2* Oven Kit.
56. Rullex 1*SinePii fully assembled with RF relay, 2* UcPure, 2*6” and 2*10” SMA cable, 1*ReciverPi
57. drone 1*SinePi fully assembled, 2*LifePO4 Mini 3.3V, 3* UcPure, 2*6” SMA cable, 1*LinearPI-Dual, 4*2" uFl cable
58. Myint 67 life po4 mini 3.3v
59. JimS 1*SiniPi fully assembled, 1* UcPure, 1* RelockPi, 2* LifePO4 Mini 6.6V
60. acg 3 x UcPure
61. matjazsket 1*SiniPi fully assembled, 1*SinePi SMT finished KIT, 1* UcPure, 2* LifePO4 Mini 3.3V, 4*Oven KIT
62. sebmck 1* SinePi fully assembled, 1* SinePi fully assembled with RF Relay, 2* LifePO4 Mini 3.3V, 2* 6" SMA cable, 2* 10” SMA cable, 1* StationPi/ pro if available, 2* Buffalo I/V board Adapter KIT, 1* LifePo4 Mini 6.6V
63. namlee 1 * SinePi fully Assembled, 1 * ReClockPi, 1 * HDMI Transmitter MK II,1 * FIFOPI Q3
64. deanoUK 2*SiniPi fully assembled
65. Thermio 2*SinPi finished kit, 2*Oven KIT, 2*6” and 2*10” SMA cable, 1*LifePO4 Mini 3.3V
66. calebwong 1*FifoPi Q3, 1*ReClockPi, 1*HDMIpi MkII HDMI transmitter, 1*HDMIpi HDMI to I2S/DSD/DoP receiver, 1*No.24A, 1*BridgePi USB streamer adapter, 1*SinePi fully assembled with RF relay, 1*No.27
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
18. trial and error 2*LifePO4 Mini3.3V, 2*battery holder assembled
60. acg 3 x UcPure
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60. acg 3 x UcPure
67. rpiaudio 1*LifeO4 pure power supply MkIII, 1*ESS controller, 1*9038Q2Mpi Dual Mono Plus DAC HAT, 1*I/V STD MkII standard OPA I/V board, 1*ESS controller extension kit, 2*2.5mm metal standoffs for RPI lot of 4 sets, 1*GPIO I2S/DSD terminator KIT (SMD finished), 1*Free I/V STD board finished untested for parts (limit 1 per order, OPA not included), 1*StationPi PCB KIT, 10*26650 battery holder with assembling service.
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60. acg 3 x UcPure
68. bogdandascalu87 1*SinePi SMT finished KIT, 2* SMT XO socket replacement for FifoPi, 1* CCHD957 XO adapter kit lot of 2, 1* NDK 2520 XO adapter KIT 4 in package
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60. acg 3 x UcPure
69. josephus-69 - SinePi SMT finished KIT
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60. acg 3 x UcPure
70 lindamar 1*SinPi fully assembled with RF relay, 2*Oven KIT, 2*6” and 2*10” SMA cable, 1*LifePO4 Mini 3.3V, 1*LifePO4 Mini 6.6V
