Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 21 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 26th April 2012, 03:33 AM   #201
iancanada's Avatar
Originally Posted by spm View Post
I snapped 3 O-rings just trying to gently stretch them to fit over the pegs. I gave up after that. The dental band idea seems good, or something more deformable...I was hoping to find silicone bands somewhere but haven't yet had the chance to look.
More important to me are the little SMD boards to mount the eg CCHD XOs. Any chance they're going to be available?
Hi spm,
That's a good suggestion. I'll make more. Any one from GB will have one for free if didn't receive any.
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 26th April 2012, 03:55 AM   #202
Try the O-rings that are used for disc brakes or oil ram seals - PBR in Brisbane will have a whole wide selection including some thin, soft, but strong ones - other hydraulic repair people have these sort of things - also, can make your own out of old turntable belts, etc with some superglue - workd like a charm.
Old 26th April 2012, 04:03 AM   #203
qusp is offline qusp  Australia
qusp's Avatar
thanks James, i'll check that out. Ian wondering with those XO adapters, what would you suggest for the cap positions on the underside for a crystek there, did you scope out an optimal value?
Old 26th April 2012, 08:10 PM   #204
iancanada's Avatar
Default Possible O-ring solutions
Originally Posted by qusp View Post
correct thats what I meant, I havent seen anyone else from the GB use them with the fifo, i've only seen it still in the frame, but I thought I should post the warning, because it has the potential to be a real bummer if the dac is on at the time.
of course there has been all sorts of mad attempts to isolate from vibrations, this one probably does make a difference, its sometimes used for isolating clocks in instrumentation too.
Yes, Iíve noticed this o-ring problem. The one Iím using was originally for sealing valves, and itís might be a bit smaller to hook up the clock board. So, itís very easy get snapped by the sharp edges of the PCB.
To find out suitable ones, Iím thinking about the following solutions:
1, Try to find some rubber hoses originally for medical applications (my major J ), with similar or bit bigger section size than the current o-ring. For example, from a stethoscope, or from the rubber ribbon for a sphygmomanometer, or the rubber ribbon for intravenous injection. Usually medical grade comes with best material. Cut the sections by each 1.5-2mm. That should be perfect o-rings for clock board suspension.
2, Or, you may try the heat shrink tubes with suitable section size. I suspect you all have it. Hook up the clock board to the frame on the corners, than heat it with hot air or something else by a hot gun, a smt soldering station or even a soldering iron.
3, Or, like me, trying to find out another bit bigger o-ring for sealing the valves. Here in Canada, I can go to Homedepot, Rona or any store with plumbing stuffs.
You may have some better ideas finding out the o-rings. Good luck.
Old 26th April 2012, 09:34 PM   #205
qusp's Avatar
wow, how did you edit/repost so late haha? yes I thought of using heatshrink and I have just about every size known to man due to my work, I thought I may even try these ones one last time after buffing the edges with abrasive cloth to get rid of any burrs (like that used for buffing scratches out of aircraft cockpits) I have grades from 200-20000grit.
I think I may do this regardless of what I use for the ring, because I like you; figure its as much about the sharp edges.
see I would have used some from my sphygmomanometer, but I left it at the GF's place
Old 30th April 2012, 10:19 AM   #206
Hi Ian,
Many thanks for running the GB a second time.
I understand you my be making some software revisions for the second run.
Is there any possibility of 32/384kHz support with this version?
I would like to future proof for use with my buffalo 2 DAC. Also I am considering tapping I2S from my Lin DS, which has internal up sampling to this speed.
Best Regards,
James.
Old 30th April 2012, 10:50 AM   #207
just another
wintermute's Avatar
It's the new perpetutal first post edit function being used for exactly what it was intended for!
Also good for project threads for posting links to the latest schematic (which is often difficult to find in a thread with thousands of posts) etc.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 30th April 2012, 01:55 PM   #208
qusp's Avatar
Tony.
hard day at work Tony? i'm aware of this function and thanked Jason for its activation on the day it was enabled, as I was starting the LPUHP GB thread and had been vocal about this need. I have put it to very good use; however we are not talking about the first post, but rather post #204. Perhaps it was edited directly after I read the post the first time and then when I came back the next day appeared to have been done much later.
Old 30th April 2012, 02:03 PM   #209
Not just you mate, I think I even got an email update from the forum for the new post and when I read the older post had dissapeared and the one you refer to seemingly in its place with no edit timestamp and seemingly far more than the usual 30min edit window had lapsed. I just assumed ian's skills extended further than FIFO design and construct
Old 30th April 2012, 02:58 PM   #210
qusp's Avatar
aha so it wasnt my mind playing tricks, I thought it was a completely different post too, but I thought that was just too mad to be reality. I came into the thread, saw the first one, but didnt reply and then came back to see a different post and no edit stamp, so assumed either as you did that Ian has supernatural powers, or that he had contacted the mods to get the post changed to a more detailed one
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4357 6th April 2017 06:02 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching Ė PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2017 diyAudio
