Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 142 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 19th October 2013, 02:58 AM   #1411
iancanada's Avatar
Default GBV Shipping status Oct.18
Please send the order form back to me as soon as possible if you still didn't, a lot of orders are on hold waiting for the priority arrangement of the limited FIFO KIT. Thank you.
Please note, the max insurance value for a bubbled envelope is USD60-, have to use box if need more insurance.
Tracking number will be sent to your paypal account if applied.
For those letter mails, please keep your fingers crossed .
Shipped on Oct. 16:
GBVPCM 09,10,12,13,14,24,36,58,65,79,85,89,92
GBVFIFO 06,34,51,57
Shipped on Oct. 17:
GBVPCM 03,15,37,56,93,
GBVFIFO 02,04,08,15,20,30,19,59,61
Shipped on Oct. 18:
GBVPCM 34,82
GBVFIFO 09,25
Ian
Old 19th October 2013, 02:01 PM   #1412
spm is offline spm  United Kingdom
GBVPCM65 received today!
Thank you
Old 20th October 2013, 12:47 PM   #1413
andrea_mori's Avatar
Originally Posted by iancanada View Post
Hi andrea_mori,
For TDA1541/A accepts I2S input, I thought TDA1541 doesn’t need the PCM board before I did some real try on its simultaneous offset-binary mode. Now it seems PCM mode (simultaneous mode) is a better solution for TDA1541/A than the I2S mode. I too was wondering why.
Please correct me if I’m wrong for the following possible reasons:
1. I2S is not the finial analog to digital conversion timing for multi-bit DAC, but the PCM timing (simultaneous offset-binary for TDA1541/A) is. So, if TDA1541 is working at I2S mode, it has to enable an internal logic circuits doing the similar I2S to PCM convention job as the PCM board does. The problem would be that TDA1541/A doesn’t have a MCLK input, so the internal generated PCM timing couldn’t be re-clock at finial stage hence additive jitter might be introduced. That means even with the same jitter level, PCM mode could still have better performance because of no any addition logic is needed to perform D/A convention inside TDA1541/A.
Another thing is that a synchronized logic design (the I2S to PCM board) doesn’t care about how many stages it was going through. For there is a re-clock at finial stage,as well as intermediate stages, any accumulated jitter will be clock out, no matter how many stages in front of it. At this point, digital logic is totally different from analog.
2. PCM timing stops clock after left and right data shifted (at same time) into TDA1541/A, which theoretically can lower the overall noise level introduced from digital section into analog section.
3. I2S transmits left and right data sequentially which will half the maximum performance of TDA1541/A, that's why TDA1541 can’t achieve 384KHz with I2S input format.
Some reports could also be found to support my analyses.
TDA1541A simultaneous data mode - Audial online topic
For a simple DAC such as TDA1541/A, I2S mode may already be good enough. But to get the last drop of juice, simultaneous (PCM) mode is really worth giving a try.
regards,
Ian
Hi Ian,
your hypothesis could be right, but any re-clocking circuit adds jitter itself.
I have never seen a detailed schematic of the TDA, but from its block diagram I presume it acts the data splitting starting from the BCK (6.4 MHz max).
Well, if all the system works at BCK frequency the TDA have its MCLK input, the BCK itself, and so its logic operates at MCLK.
Maybe I'm wrong, but I cannot find any evidence that the TDA internal logic works worse than any other external logic when operates at the same MCLK.
Of course, it needs a very clean MCLK close to its pin, but this is another story.
As you know I ordered some I2S to PCM boards, so I'll do a comparison between the two operation mode and I'll report my impressions (I cannot do a measurement)...
... when I'll find the time to do that
Andrea
Old 20th October 2013, 07:31 PM   #1414
Marek is offline Marek  Poland
Originally Posted by andrea_mori View Post
Hi Ian,
Andrea
Its not true. Synchronous reclocking used by Ian greatly lowers jitter of I2S signals. Ofcourse I2S after synchronous reclocking isn't jitter free - it has jitter of XO acumulated with jitter generated by FF, thats why Ian uses POTATO Ghz FF which has one of the lowest induced jitter available.
Other thing is asynchronous reclocking with clock not related to any of I2S signals - it adds jitter but it can be compared to dithering used in computer graphics or in audio and depending of used reclocking frequency can bring some relative improvement (output jitter character not related to source jitter, to content of binary audio signal etc)
Marek
Old 20th October 2013, 11:24 PM   #1415
Dear Ian,
if it is not sold out yet, I would like to order a I2S FIFO KIT and a Dual XO Clock board.
Greets,
Franz
Old 20th October 2013, 11:53 PM   #1416
Marek
Synchronous reclocking used by Ian is essential since the FPGA adds some jitter to the I2S signal, regardless from the quality of the original signal.
POTATO's FF has a propagation delay around 2ns, so maybe a low jitter but not jitter free.
IMHO, when the BCK is also the MCLK the DAC can be fed directly with I2S signal, without any additional stage that still injects jitter, since the internal logic of the 1541A operates at MCLK frequency.
Andrea
Old 20th October 2013, 11:59 PM   #1417
Gents, would you mind moving the tech discussion to the main forum thread so that people who're interested can discuss?
Old 21st October 2013, 12:07 AM   #1418
GBVFIFO01 : jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
GBVFIFO02 : Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
GBVFIFO03 : APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
GBVFIFO04 : duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
GBVFIFO05 : chi0001: bIII adapters pcb x4, tps7a4700 x4
GBVFIFO06 : hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
GBVFIFO07 : malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
GBVFIFO08 : mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
GBVFIFO09 : casshan : 1 x I2S FIFO KIT v3.8,2 x Finished FIFO isolator board v2.5,2 x Si570 Clock Board V3.5 (with Si570),2 x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO10 : hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO11 : luisbock
GBVFIFO12 : kazap: 1x i2s FIFO kitv3.80, 1x Dual XO Clock Board, 1x finished isolator, 1x TPS7A4700, 1x Battery management, 1 x S/PDIF , 1 x I2S backdoor KIT, 4x 6” 50 coaxial cable, 1x XO Adapters, 10x SMT U.FL socket
GBVFIFO13 : iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
GBVFIFO14 : audiopassion
GBVFIFO15 : ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12” double-ended 50 ohm coaxial cable, 1x6” double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters.
GBVFIFO16 : LOBOONE: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO17 : errmoo I2S FIFO KIT V3.80, Si570 Clock Board V3.5(with Si570), S/PDIF Interface Board
GBVFIFO18 : sernikus I2S FIFO + Dual XO
GBVFIFO19 : TonyB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface, Board, 1 x Package of Universal SMT XO Adapters, 1 x PCM1704 board, 1x I2S backdoor
GBVFIFO20 : korben69 : 4 x Bare PCB of TPS7A4700
GBVFIFO21 : Billyk: 14x SMT U.FL socket, 2x 6” double-ended 50 ohm coaxial cable, 4x 4” double-ended 50 ohm coaxial cable
GBVFIFO22 : pavelal: I2S FIFO KIT V3.80, Dual XO Clock board V3.3,S/PDIF Interface Board, 10 x SMT U.FL socket, 8 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable, Package of Universal SMT XO Adapters lot of 5, Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, Passive Battery Management Board V2.5 Mini KIT
GBVFIFO23 : JustBuildLspkAS: 2 sets with optimize SQ/ minimize board qty for TDA1541 and PCM1704/63
GBVFIFO24 : crobbins5421: 1 x Finished FIFO board, 1 x Dual XO Clock Board, Universal SMT XO Adapters lot of 5
GBVFIFO25 : Iancortez: 4 x SMT UFL socket, 2 x Additional BII adapter pcb, 2 x SMT connector package for BII adapters
GBVFIFO26 : LuisMCP: 4 x BIII Adapter PCB.
GBVFIFO27 : TNT: 1 FIFO board (no clock). 3x Finished TPS7A4700
GBVFIFO28 : clsidxxl :1x I2S FIFO KIT V3.80,1xDual XO Clock board V3.3,1x Package of Universal SMT XO Adapters,1x Finished FIFO isolator board V2.5,1x Finished TPS7A4700 low noise regulator board V2.5,3 x 6" coax cable and 3 x SMT U.FL socket
GBVFIFO29 : Ryelands: 1 of I2S/FIFO kit; 1 of finished isolator board; 1 of Dual-XO Clock board; 2 of finished TPS7A4700 board; asstd cables.
GBVFIFO30 : jcga: 2 x TPS7A4700 finished boards; 3 x TPS7A4700 PCB only; 2 x passive Bat management minikit; 2 x U.FL socket kit; 1 x xoadaptator kit
GBVFIFO31 : canvas: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board
GBVFIFO32 : sidiropa:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO33 : hochopeper: 2 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 2 x finished FIFO isolator, 1 x Si570
GBVFIFO34 : zapio : 1 x Si570 , 2 x finished FIFO isolator
GBVFIFO35 : fregones : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x Si570
GBVFIFO36 : fukinspud : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1xfinished Battery management, 1x finished I2S backdoor, 1x finished SMT XO Adapters Kit
GBVFIFO37 : nedi: 1x FIFO Kit v3.80, 1x Dual XO clock board v3.3, 1X Finished FIFO Isolator board v2.5, 1x S/PDIF interface board, 1x I2S backdoor kit for S/PDIF board, 1x Passive Battery management board v2.5 mini kit
GBVFIFO38 : manolo2001: 2x finished I2S FIFO board, 2x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 2x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570,1x Package of Universal SMT XO Adapters lot of 5, 2xFinished TPS7A4700 low noise regulator board V2.5, 10 x SMT U.FL socket, 10 x 4” double-ended 50 ohm coaxial cable, 6 x 6” double-ended 50 ohm coaxial cable
GBVFIFO39 : Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
GBVFIFO40 : Tony_T: 1x I2S FIFO KIT V3.80, 1x 10P 1.0mm FFC/FPC cables combo, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO41 : Heffa: 1 x Package of Universal SMT XO Adapters lot of 5, 2 x Additional BIII adapters PCB, 2 x SMT connector package for BIII adapters, 4 x 4” double-ended 50 ohm coaxial cable
GBVFIFO42 : curryking 1 x Dual XOClock Board,2 X Package of Universal SMT XO Adapters Kit,1 x Si570 Clock Board V3.5(wuth Si570),1 x Finished TPS7A4700 low noise regulator board V2.5,1 x SMT finished Battery Management V2.5 Mini Kit, 2 x 6" double-ended coaxial cable
GBVFIFO43 : vanwykca: 3 x additional BIII adaptor PCB, 3 x SMT connector package for BIII adaptors, 5 x finished TPS7A4700 low noise regulator board V2.5
GBVFIFO44 : Joonas: 1x fifo kit, 1x dual clock board, 1x spdif board, 1x finished isolator boards, 2x adapters for crystek if you still have them, 1x nos pcm add-on from the other thread
GBVFIFO45 : wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
GBVFIFO46 : _oxygen: 1x FIFO Kit, 1x Si570 Clock Board (with Si570), 2x Finished FIFO isolator board, 1x SPDIF Interface Board, 1x i2s Backdoor Kit, 3x Finished TPS7A4700 low noise regulator board, 1x SMT finished Battery Management Mini Kit, 10x SMT U.FL socket, 6x 4” double-ended 50 ohm coaxial cable, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO47 : frd__: 10x Bare PCB of TPS7A4700 low noise regulator
GBVFIFO48 : palmito: 1 FIFO board, 10 PCB of TPS7A4700 low noise regulator
GBVFIFO49 : brettlb: 2 x FIFO board, 2 x Isolator board, 1 x Si570 with Si570, 4 x finished regulator boards.
GBVFIFO50 : davej: 1 x FIFO kit, 1 x dual XO, 1 x finished isolator board, 1 x finished TPS7A4700 regulator
GBVFIFO51 : flowerpot: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator
GBVFIFO52 : Bennyboyvg: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 1 x additional BIII adapters PCB's, 1 x SMT connector package, 6 x 4" coax cable, 7 x SMT U.FL socket
GBVFIFO53 : Popolvar: 1 x FIFO board, 1 x dual XO
GBVFIFO54 : necplusultra: 1 fifo board,1 x Si570 board (with Si570), isolator board, 5 TPS7A4700 boards
GBVFIFO55 : crowlie: 1x I2S FIFO KIT V3.80, 1x Dual XO Clock board V3.3, 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5, 4x Passive Battery Management Board V2.5 Mini KIT, 10x SMT U.FL socket, 8x 4" double-ended 50 ohm coaxial cable, 6x 6" double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO56:curryking: 4 x Dual XO Clock Board,4 x 6" double-ended U.FL cable,2 X Package of universal SMT XO Adapters Kit
GBVFIFO57 : Alcaudon: 1 x Dual XO Clock Board, 5 x BIII Adapters PCB, 3 x SMT connector package for BIII adapters, 10 x SMT U.FL socket, 3 x 4” double-ended 50 ohm coaxial cable, 3 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable.
GBVFIFO58 : ruupie: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 2 x BIII Adapters PCB, 2 x SMT connector package for BIII adapters, 10 x SMT U.FL socket, 3 x 4” double-ended 50 ohm coaxial cable, 3 x 6” double-ended 50 ohm coaxial cable
GBVFIFO59 : tofurky : 1x finished TPS7A4700 regulator, 2x TPS7A4700 bare pcb
GBVFIFO60 : MarcellD : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1x I2S to PCM converter board
GBVFIFO61 : Marek : 1x Dual XO Clock Board (if available), 1x Finished FIFO isolator board V2.5, 1x Package of Universal SMT XO Adapters KIT lot of 5, 21x SMT U.FL socket, 9x 4"double-ended U.FL coaxial cable
GBVFIFO62 : 4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
GBVFIFO63 : normundss : 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x SMT finished Battery Management V2.5 Mini KIT, 1x Finished TPS7A4700 low noise regulator board V2.5
Old 21st October 2013, 01:14 AM   #1419
GBVFIFO64 : Greg Stewart : 1 x i2s FIFO kit
Everything matters!
Old 21st October 2013, 01:28 AM   #1420
iancanada's Avatar
Thank you
Thanks for your good news, it seems UK post service is the winner .
Ian
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4448 Today 02:12 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2017 diyAudio
