Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 123 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 30th March 2013, 06:59 PM   #1221
APK is offline APK  United Kingdom
Order form not yet issued.
List of all there use - see wiki and read the thread
Next GB, there may never be another dependant on Ian's goodwill and gentle cajoling
Old 7th April 2013, 02:06 AM   #1222
Ceglar is offline Ceglar  Australia
Banned
Hi Ian,
Is there any update on the proposed GBV status, and numbers required etc.
Thank you,
Shane
Old 9th April 2013, 08:53 AM   #1223
Happy to report GBIV 41 landed in perfect shape
Old 12th April 2013, 09:15 AM   #1224
If there is a GBV
1. jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
2. Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
3. Ceglar : 1x FIFO, 1x Assembled FIFO Isolator, 1x a few extra cables.
4. APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
5. duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
6. chi0001: bIII adapters pcb x4, tps7a4700 x4
7. hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6 double-ended 50 ohm coaxial cable
8. malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator
9. mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
10. casshan : 1 x I2S FIFO KIT v3.8, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 1 x 10P 1.0mm FFC/FPC cables, 1 x Finished FIFO isolator board v2.5
11. hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
12. luisbock
Old 17th April 2013, 04:02 PM   #1225
If there is a GBV
12. luisbock
13. lxiaob
Old 18th April 2013, 08:35 AM   #1226
koldby is offline koldby  Denmark
koldby's Avatar
If there is a GBV
12. luisbock
13. lxiaob
14. koldby: 1x i2s FIFO kitv3.80, 1x finished FIFO isolator board, 1x Package of Universal SMT XO Adapters lot of 5, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT,4x 6 double-ended 50 ohm coaxial cable
What is Home Theatre without good sound?
Old 19th April 2013, 04:47 AM   #1227
kazap is online now kazap  Australia
kazap's Avatar
If there is a GBV
7. hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
12. luisbock
13. lxiaob
14. koldby: 1x i2s FIFO kitv3.80, 1x finished FIFO isolator board, 1x Package of Universal SMT XO Adapters lot of 5, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT,4x 6” double-ended 50 ohm coaxial cable
15 kazap: 1x i2s FIFO kitv3.80, 1 x PCM1704 board, 1x Dual XO Clock Board, 1x finished FIFO isolator board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x Battery management, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 10x SMT U.FL socket
Old 20th April 2013, 01:19 PM   #1228
Banned
3. APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
4. duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
5. chi0001: bIII adapters pcb x4, tps7a4700 x4
6. hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6 double-ended 50 ohm coaxial cable
7. malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator
8. mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
9. casshan : 1 x I2S FIFO KIT v3.8, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 1 x 10P 1.0mm FFC/FPC cables, 1 x Finished FIFO isolator board v2.5
10. hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
11. luisbock
12. lxiaob
13. koldby: 1x i2s FIFO kitv3.80, 1x finished FIFO isolator board, 1x Package of Universal SMT XO Adapters lot of 5, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT,4x 6 double-ended 50 ohm coaxial cable
14 kazap: 1x i2s FIFO kitv3.80, 1 x PCM1704 board, 1x Dual XO Clock Board, 1x finished FIFO isolator board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x Battery management, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 4x 6 double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 10x SMT U.FL socket
Old 21st April 2013, 05:56 AM   #1229
iskwon is offline iskwon  South Korea
iskwon's Avatar
Default GB
If there is a GBV
12. luisbock
13. lxiaob
15 kazap: 1x i2s FIFO kitv3.80, 1 x PCM1704 board, 1x Dual XO Clock Board, 1x finished FIFO isolator board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x Battery management, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 4x 6 double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 10x SMT U.FL socket
16. iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
Old 21st April 2013, 02:10 PM   #1230
12. luisbock
13. lxiaob
17. flowerpot: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board, 5 x SMT U.FL socket, 5 x 4 double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Finished FIFO isolator board V2.5, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4355 5th March 2017 07:47 AM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright 1999-2017 diyAudio
