Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 122 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 15th March 2013, 12:29 PM   #1211
Telstar is offline Telstar  Italy
GBIV-71 (200) received
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 20th March 2013, 08:16 PM   #1212
mcluxun is offline mcluxun  United States
If there is a GBV
1. jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
2. Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
3. Ceglar : 1x FIFO, 1x Assembled FIFO Isolator, 1x a few extra cables.
4. APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
5. duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
6. chi0001: bIII adapters pcb x4, tps7a4700 x4
7. hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6 double-ended 50 ohm coaxial cable
8. malarkey : 1x Dual XO Clock Board
9. mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
Old 22nd March 2013, 05:13 AM   #1213
casshan is offline casshan  Hong Kong
If there is a GBV
10. casshan : 1 x I2S FIFO KIT v3.8, 1 x Dual XO clock board v3.3, 1 x S/PDIF Interface board, 1 x Si570 Clock board v3.5 (with Si570), 1 x Finished FIFO isolator board v2.5
Old 22nd March 2013, 06:23 AM   #1214
hangguy is offline hangguy  United States
If there is a GBV
7. hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
10. hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
Old 22nd March 2013, 06:37 AM   #1215
If there is a GBV
10. casshan : 1 x I2S FIFO KIT v3.8, 1 x Dual XO clock board v3.3, 1 x S/PDIF Interface board, 1 x Si570 Clock board v3.5 (with Si570), 1 x Finished FIFO isolator board v2.5, 1 x Finished TPS7A4700 low noise regulator board v2.5
11. hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
Old 25th March 2013, 05:02 PM   #1216
If there is a GBV
8. malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator
Old 26th March 2013, 04:25 PM   #1217
nvduybom's Avatar
GBIV_42 arrived, thank you.
http://www.vnav.vn/forum
Old 27th March 2013, 03:30 AM   #1218
If there is a GBV
10. casshan : 1 x I2S FIFO KIT v3.8, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 1 x 10P 1.0mm FFC/FPC cables, 1 x Finished FIFO isolator board v2.5
Old 29th March 2013, 09:21 AM   #1219
vzs is offline vzs  Europe
GBIV79 Received.
Old 30th March 2013, 02:22 PM   #1220
Send a message via Yahoo to kannan_s
Where is the order form located and where can i see the list of all and their use?
When will next GB start ?
kannan
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4354 8th February 2017 09:16 AM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 01:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 08:01 PM
Copyright 1999-2017 diyAudio
