Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 14th November 2012, 11:50 AM   #721
hochopeper is offline hochopeper  Australia
Originally Posted by Odysseas View Post
Thanks!
No, not yet at least!I'm catching up! Ok, I'm adding myself! Woooohaaaaa!
I feel I may have lead you astray a little.
The Si570 and Ti regulator will not be available in time for this GB, Ian has stated this categorically. There is an interest list in the R&D thread for the Si570, should be on the last page or two of that thread. Ian has said that he'd like ~50 people interested to make a GB of that viable so if you want it, you'll need to be on that list rather than having it noted here, as its too hard to keep track of new items in amongst this GB thread.
I really recommend reading the docs Ian has written for the FIFO, see the post linked in his signature
Old 14th November 2012, 11:55 AM   #722
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
οοοοh boy, I'm at page 120 now....I'll sync myself with the pdfs before my eyes start bleeding from all this time in front of my screen.
Old 14th November 2012, 12:40 PM   #723
rsotirov is offline rsotirov  Canada
N08. mfrimu 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface
N09. makumba1966 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 2x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x battery management boards, 4x Isolator board kit
N10. LuisMCP - 1 x I2S Kit + 1 x Dual XO
N11. number9 - 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 1x I2S backdoor KIT, 1x Package of Universal SMT XO Adapters, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x battery management board, 1x isolator board, 1x Si570 clock board
N12. Fridrik 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 3x isolator board kit , 3 x battery management board
N13. jwkim 1 * I2S FIFO KIT 1 * Dual XO Clock board 1 * S/PDIF Interface Board 1 * I2S backdoor KIT for S/PDIF
N14. dsdjoy, 3 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 12 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm
N15. hangguy 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 5x SMT U.FL socket, 3x 6" coxial cable, 1x Universal XO adapters, 1x SMT connector package for BIII adapters
N16. Sachi 1 * I2S FIFO KIT 1 * Dual XO Clock board 2*BIII adapter and connectors
N17. Finaxe 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 1x isolator board kit , 1 x battery management board
N18 Tagheuer 2x I2S FIFO Kit, 1x Dual XO Clock Board, 2 x BIII Adapters PCB, 3 x SMT Connector for BIII adapters, 1x Universal XO adapters, 12 x 4"double-ended U.FL coaxial cable
N19. palmito 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x I2S backdoor KIT for S/PDIF board, 4 x 4" coaxial cable 50ohm, 1x isolator board kit , 1 x battery management board
N20. Keith Taylor 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x SPDIF Interface Board
N21. marcus1 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT
N22 Joonas 1 x I2S FIFO kit and 1 x S/PDIF interface board
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4 double-ended 50 ohm coaxial cable
N24 chi0001 1 x I2S FIFO KIT, 6 x 4" Cables, 6 x 6" Cables, 1 x Dual clock board, 1x S/PDIF Interface, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters, 1 x SMT connector package for BIII adapters.
N25 rsotirov 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x Universal SMT XO
Adapters KIT, 8 x 4" coax cables, 1X Isolator board kit, 2X battery management boards
N26. miksi, 2 x BIII Adapters PCB, 2 x SMT Connector for BIII adapters, 20 x SMT U.FL Socket, 4 x 4" coaxial cable 50ohm, 4 x 6" coaxial cable 50ohm, 4 x 12" coaxial cable 50ohm
N27 hirez69, 1 x I2S FIFO KIT, 1 x Dual XO Clock Board, 2 x Universal SMT XO Adapters KIT, 8 x BIII Adapters PCB, 1x S/PDIF Interface, 1x I2S backdoor KIT, 4 X battery management boards
N28 hochopeper, 1 x I2S FIFO KIT, 1 x Dual XO clock board, 1 x universal SMT XO ADAPTERS KIT, 8 x 4" coax cables, 1 x isolator board kit, 2 x battery management board
N29 edbk 1x I2S FIFO Kit, 1x Dual XO Clock Board, 1x S/PDIF Interface, 2x Universal SMT XO Adapters KIT, 1x I2S backdoor KIT, 20 x SMT U.FL Socket, 8 x 4" coaxial cable 50ohm, 8 x 6" coaxial cable 50ohm, 8 x 12" coaxial cable 50ohm
N30 andrea_mori 3 x I2S FIFO, 5 x isolator board kit
N31 acko 1x I2S FIFO Kit, 1x Dual XO Clock Board
N32 vitalica 1*I2S FIFO KIT, 1*Dual XO Clock board , 1*S/PDIF Interface, 4 x BIII adapter, 1x I2S backdoor KIT for S/PDIF board, 2x Package of Universal SMT XO Adapters KIT lot of 5, 4x Additional BIII adapters PCB, 4x SMT connector package for BIII adapters Board ,20 x SMT U.FL Socket, 12 x 4" coaxial cable 50ohm, 12 x 6" coaxial cable 50ohm, 12 x 12" coaxial cable 50ohm;4 x isolator board kit and 4 x battery management board.
33 TV Man 2 x i2s FIFO kit, 2x Dual XO Clock Board - Need other parts too, ie. sockets and cables, but have to sort out which ones.
N34 supra 1xI2S FIFO kit, 1x Dual XO Clock board
N35 koldby 1x1s2 FIFO kit, 1x DUAL XO clock board, 1x Isolator board kit, 1x battery management kit
N36 normundss 1x I2S FIFO KIT, 1x Dual XO Clock board, 1x S/PDIF Interface board, 1x I2S backdoor KIT, 1x BIII adapter KIT, 3x 4 double-ended 50 ohm coaxial cable
N37 AR2 1x isolator board kit and 1 x battery management board
N38 BDL 1 x isolator board kit, 2 x battery management board, 10 x SMT U.FL socket, 4 x 4 double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board
N39 NicMac 20 x battery management boards
N40 leejh 1*I2S FIFO KIT, 1*Dual XO Clock board , 1 x BIII adapter, 1 x Package of Universal SMT XO Adapters KIT lot of 5, 4 x SMT U.FL Socket, 2 x 4" coaxial cable 50ohm, 1 x 6" coaxial cable 50ohm, 1x isolator board kit and 3 x battery management board
N41 necplusultra 1*I2S FIFO KIT,2 x battery management boards
N42 ruupie 1*I2S FIFO KIT, 1*Dual XO Clock board , 2x isolator board kit and 3 x battery management board
N43 crazikid 1x I2S FIFO Kit, 1x Dual XO Clock Board
N44 Odysseas 1xI2S FIFO KIT,1xDual XO Clock board, 1xSi570 clock board, 1xS/PDIF Interface Board, 2xU.FL coaxial cable connection accessories, 1xI2S backdoor KIT for S/PDIF board, 1xPackage of Universal SMT XO Adapters, 1xAdditional BIII adapters PCB, 1xSMT connector package for BIII adapters, 4xTI boards(if possible), 4xbattery management boards(if possible),1xisolator board
Additions to my original order.
Old 14th November 2012, 04:18 PM   #724
slartibartfasst is offline slartibartfasst  United States
N23 Stasiope 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Package of Universal SMT XO Adapters, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters, 3x 4” double-ended 50 ohm coaxial cable
N36 normundss 1x I2S FIFO KIT, 1x Dual XO Clock board, 1x S/PDIF Interface board, 1x I2S backdoor KIT, 1x BIII adapter KIT, 3x 4” double-ended 50 ohm coaxial cable
N38 BDL 1 x isolator board kit, 2 x battery management board, 10 x SMT U.FL socket, 4 x 4” double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board
N45 Slartibartfasst 1xSi570 Clock Board, 2x isolator board
Old 14th November 2012, 08:49 PM   #725
qusp is offline qusp  Australia
qusp's Avatar
hochopeper, give up....
@ slartibartfast (love that book) as hochopeper just finished saying, the Si570 clock board is not ready and the list for it isnt in this thread, its in the main fifo thread
Old 14th November 2012, 11:05 PM   #726
sigh ...
Old 14th November 2012, 11:23 PM   #727
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
My understanding was that Ian mentioned he has only 20 battery management boards, and I see people are ordering more than one. Is it appropriate at this time to order more than one? I for sure would love to have more, but did not feel it was right to do so at this time. If by any chance there are more than 20 available, please let me know so that I could increase my order.
www.burningamp.com
Old 15th November 2012, 12:05 AM   #728
You are correct AR2, I had missed that. Quote below with emphasis added:
Originally Posted by iancanada View Post
As well as the passive battery management board PCB, I still have 20 of them, will supply for free, first arrive first serive .
Old 15th November 2012, 12:24 AM   #729
Master Burner
AR2's Avatar
Ohhh look at that now. I did not get this info that it is free, I just recall that it was limited quantity. I do not need to get that, I will wait for the paid order.
I do not know if I should mess with the list, so let this be record / reminder for Ian, or if anyone adds the name, please deduct my battery board please.
www.burningamp.com
Old 15th November 2012, 01:54 AM   #730
iancanada is offline iancanada  Canada
iancanada's Avatar
Si570 clock board is still under developing. So it will not be included in this GB. Now it's V2.0. After V3.0 being confirmed, I will start a GB for it.
Ian
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4660 17th May 2018 07:28 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
