Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 9th August 2012, 12:36 AM   #531
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by sernikus View Post
just finished my FIFO . it`s integrated with dual-mono Opus Dac .... and with these generic XO`s (i`m waiting for 1ppm , -135dB phase noise TCXO`s from ebay...) it sounds unbelievably good (my setup is : PC based linear powered CMP player , BAT VK30 +VK200 and Audio Physic New Tempo) and i must say again : THANK YOU VERY MUCH ,IAN !!!! BTW : where are my rubber rings ?! )))
Congratulations Sernikus! You will get more surprise if you run the FIFO with really nice low jitter clocks.
I didn't supply rubber rings this time. Beacuse the ones I sourced were not good enough, very easy to be broken. Here are some possible solutions, just for reference:
http://www.diyaudio.com/forums/group...ml#post3002222
Good luck to your projcet.
Ian
Old 9th August 2012, 04:10 PM   #532
Rosendorfer is offline Rosendorfer  Poland
Hi Ian
After spending some time on Spidf board and finally opening The I2S Backdoor, well that was really pretty small bit of soldering...
Have some questions regarding SPIDF board, hope that OK for GB thread.
Would You advice way of "moding" SPIDF board TTL input to adapt Coax Level Spidf , preferably with PE Trafos ...
Specially that at the moment I do not have any need for Spidf Ouptut, so can use PE separation trafos from output part.
Hope than not only for me having second Coax In is more interesting than TTL IN.
Rosendorfer
Old 9th August 2012, 04:35 PM   #533
Hi Ian
Do You have free just Duall Clock board, I'm thinking about buying second one.
It is that good that having just one is not enough.
Rosendorfer
Old 9th August 2012, 06:04 PM   #534
iancanada's Avatar
Originally Posted by Rosendorfer View Post
Hi Ian
Rosendorfer
yes, I still have some dual xo clock boards available. I can ship it in a envelope, the shipping would be much less. Just send me the order form if you want.
Ian
Old 9th August 2012, 08:43 PM   #535
Hi Ian
Thanks, I will...
Rosendorfer
Old 10th August 2012, 01:30 AM   #536
iancanada's Avatar
Hi Ian
Rosendorfer
Good to know you made it. Actually it's not that difficult, if you do a second one .
TTL input and coaxial input are different. Coaxial comes with a AC coupled RF amp, while TTL is just a LVTTL input with schmitt trigger. TTL S/PDIF input is usefull to interface with device such as a CD/DVD ROM. I remember TP has a hi-speed comparator solution which could converte coaxial S/PDIF into TTL signal, if I'm not wrong. It might be a good reference.
Ian
Old 10th August 2012, 03:20 AM   #537
Regland is offline Regland  Canada
N3 has arrived safely.
Thanks again.
Old 10th August 2012, 10:23 AM   #538
lll is offline lll
#22 has arrived.
Thanks a lot Ian
Old 11th August 2012, 03:43 PM   #539
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
Hi Ian,
While I'm waiting to receive FIFO buffer, just a clarification using it with I2S input from CD-PRO2 and feeding SM5842/PCM63:
- jumper TP48 open, so MCLK is 256*fs, 11.2896 MHz
- jumper TP43 short to ground, left justified to feed SM5842
- jumpers TP41 and TP42 open, I2S 16/32 bit feeding from Philips CD-PRO2
Is that right?
A few questions:
- I'm building a low phase noise oscillator to use as external clock for FIFO buffer. Is 11.2896 the right frequency to synchronize I2S from CD-PRO2 with FIFO buffer and then SM5842?
- SM5842 system clock (XTI pin): it accept 256fs or 348fs, so I have to use 256fs directly external clock, right?
- SM5842 input bitclock (BCKI pin): need 64fs (2.8224) as the I2S signal clock, so I have to connect SCK of the I2S output cable from the FIFO buffer, right?
- SM5842 data input (IW1L/DIL and IW2N/DIR pin): I think I have to configure input data as "LR alternating, leading data" with INF1N pin high and DI/INF2N pin low, so I can connect SD of the I2S output cable from the FIFO buffer to both L/R data input, right?
- SM5842 sample rate clock (LRCI pin): need fs clock, so I can connect WS of the I2S output cable from the FIFO buffer, right?
- no other connections from FIFO buffer to SM5842, right?
Thanks for the great job.
Andrea
Old 11th August 2012, 10:33 PM   #540
lindamar is offline lindamar  Spain
Location: Madrid - Capital of the Kingdom of Spain / European Union
Hi Ian,
I was in the GBII list but did not make the payment yet (I have been just outside of the country for business).
Do please let me know if I still can fulfill my payment and have everything sent. (my order contains only BuffIII adapters and some other connectors).
Best regards
Pepe
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4519 14th November 2017 12:40 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy heartwinter Group Buys 26 19th January 2012 01:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 08:01 PM
Copyright ©1999-2017 diyAudio
