Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 26th July 2012, 06:32 AM   #481
roender is offline roender  Romania
roender's Avatar
Hi Ian,
Thank you for finding some precious time to answer to me.
Regarding oscillators I had tested and my subjective findings:
NDK NZ2520SD (29.4912 MHz) - Very musical, a lot of bass slam and on the same time a lot of information in bass area. This Japanese clock is highly sensitive to power supply. Better to be powered by batteries than ADP151. I have to repeat the tests with my own designed power supply based on a supercapacitor.
CCHD957 (24.576 MHz) - It is more tolerant to power supply. Sound different than NDK, not good or bad, just different but it is not so resolute in bass area.
Generic Kyocera XO (29.49 Mhz) - Resolution is lost with this XO even powered by batteries.
Other generic XOs (29.49 Mhz) - Some of them are pretty good but as long as I can not trace the manufacturer I can not rely on them
All tests were made by changing oscillators and power supply in my own designed DAC based on DSD1792 and AD1896 ASRC. As source I had used SDtrans384 powered by Eneloop batteries followed by a CLC filter.
I've never tested SI570 but comparing the specs with NDK and CCHD957 I've find it inferior.
Kind regards,
Mihai
Old 27th July 2012, 02:00 AM   #482
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by roender View Post
Hi Ian,
Kind regards,
Mihai
Good ear, Mihai. Did you try sync mode with AD1896? I have an ESS9018, it comes with similar internal ASRC architecture than the AD1896. I found it sounds quite different at async and sync mode. Itís kind of different style, although both of the modes sound wonderful. Actually ASRC couldnít eliminate jitter, it only shift the spectrum of jitter. So, I look ASRC upon as a digital filter. Where your MCLK came from? The finial sonic performance of an ASRC based system will not only decided by the local clock, but also combined with factors of MCLK. Thatís why Iím suggesting trying the sync mode. I believe you will get some new discovery from those XOs.
Thank you for sharing your experience. I did too, both async and sync mode. But I wouldnít want to tell how the Si570 programmable XO was compared with CCHD957, NZ2520 and TentLabs, you know the reasonJ. But I have to say Si570 is much much better than that normal Kyocera XO, as well as the regular ones from CW and Fox. Chance to have a 22.5760 one, but donít know if itís as same as yours.
Ian
Old 27th July 2012, 02:22 AM   #483
iancanada's Avatar
Default Status update: GB II will start getting delivery by this weekend.
Loop testing was done. Itís much faster than I thought. All of the finished PCBs are 100% tested and bit perfect confirmed.
The only thing I have to mention is, some of the 11.2896MHz verification oscillators(on the single XO clock board) have bended pins. They just look ugly but function wise no any problem. I should plug them into the sockets by myself at the last stage rather than ask the SMTA supplier. Sorry about that. Please let me know if you couldn't put up with those ugly XOs.
All of GBII items are ready for delivery now. Iím busy processing the orders, will start getting delivery this weekend.
Have a good night.
Ian
Old 27th July 2012, 06:55 AM   #484
roender's Avatar
Ian
Servus Ian,
The MCLK in my DAC is generated locally, not recovered from SPDIFF interface, and is common between DSD1792 and ASRC .
How do you suggest to put the DAC in sync mode with the transport, getting the MCLK from transport and bypassing DAC clock and, also, bypassing the SPDIFF receiver and connecting directly I2S signals to DAC?
Kind regards,
Mihai
Old 29th July 2012, 02:45 AM   #485
iancanada's Avatar
Default Delivery today (July28,2012)
#1,2,3,4,5
Enjoy the Olympic Game.
Ian
Old 30th July 2012, 09:36 PM   #486
iancanada's Avatar
Default Delivery status so far July30, 2012
Delivered July28,2012
#1,2,3,4,5
Delivered July30,2012
#6,8,10,11,12,21,22,23,24,25,26,27,30,32,34,35,36, 38,39,40,42,45,47,48,50
Will refund $10- to #42 for shipping reduced in a envelope
Ian
Old 30th July 2012, 09:48 PM   #487
NicMac is offline NicMac  Italy
NicMac's Avatar
By "Delivered" you mean posted?
Old 30th July 2012, 10:02 PM   #488
roger57 is offline roger57  Canada
roger57's Avatar
#1,2,3,4,5
Ian
Ian,
Great work...thank you for your diligence. Will be very happy to get this completed as the last step in my project.
Gary
Old 30th July 2012, 10:18 PM   #489
iancanada's Avatar
Sorry for the confusion. Yes I mean shipped or posted. They will be delivered soon.
Ian
Old 30th July 2012, 10:23 PM   #490
iancanada's Avatar
Shipped July28,2012
#1,2,3,4,5
Shipped July30,2012
Will refund $10- to #42 for reduced shipping in a envelope
I mean 'shipped', sorry for the confusion in previous post
Ian
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4499 5th September 2017 09:05 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching Ė PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2017 diyAudio
