Nothing to do with High Resolution / DSD in this case. Purely, the Clock only. Clock frequency group 1 @5.6448 MHz.
For DSD @5.6448 MHz, it's considered 1-bit but for Redbook @5.6448 MHz I wonder if it can also be considered 1-bit? It's not documented because it is such a niche use case. Again I never got into Andrea's thread, so I never learned the Math. Something like 5.6448 MHz divided by 178 == 44.1 KHz. That's why bisesik posed the question about 90/98 MHz. Redbook @ 44.1 KHz works best as it's easily multi-pliable and divisible @5.6448 MHz. In this niche use case, 5.6448 MHz and 44.1 KHz play nice with each other with good synergy. For bisesik, his oversampling works best at x16.
Not sure what you mean exactly. AFAIK the official Red Book standard defines CD format only: 44.1 kHz 16-bit stereo.
You get like 5.644 MHz when you have 88.2 kHz 32-bit stereo, but clearly that’s multibit PCM, and happens to be the same bitrate as for two-channel DSD64.
Does that answer your question?
Unfortunately, No. I would have to spend months researching Andrea's thread to find out or possibly I can ask Andrea via e-mail if no luck getting an answer here.
Because this is such a niche use case. Very rare to run a CLK @ 5.6448 MHz just for 44.1 KHz 16-bit.
It's more of an Andrea CLK niche use case than a Universal case, so standards won't have this documentation.
SACD/DSD standards don't apply in this case.
It's only an answer few will know that have deep dived into Andrea's thread. And even then they might not know.
As you can see in the Clock frequency chart, 5.6448 MHz only does 44.1 KHz. Unfortunately, I never got into the Math as to why.
It would really make me happy if confirmed 1-bit because Input would be 1-bit as well as 1-bit Output with the TransportPi AES:
44100 x 16 bit x 2 channels = 1.411 MHz. Make it 32 bit which is a usual I2S word length and you get 2.822 MHz. That’s 64fs. Having a 5.644 MHz master clock allows you to reclock (must be at least double the bit clock to do it with flip-flops) as well as run DACs at a minimum 128fs, typical 256fs master clock.
Please don’t say it was me who was confused with DSD as clearly that’s what your first picture was about. 1-bit 5.644 MHz Red Book is not a thing.
Edit: 1-bit discrete reclock is Ian’s marketing speak for single-gate flip-flops as opposed to multi-gate flip flops. It’s got nothing to do with clock frequency. Having separate single gate ones decreases crosstalk.
Thanks for the Math, but it's never going to get to the bottom if it's considered 1-bit or not? It's a really difficult question to answer so I'll check in with Andrea.
Nothing to be confused about, SACD/DSD Marketing material always mentions 5.6448 MHz. That's the first thing to consider for 99% out there when mentioning 5.6448 MHz. Even in Andrea's thread, 5.6448 MHz is a niche within a niche. Technically, Industry Standard-wise, 1-bit Redbook might not be a thing so that's a 'No' from you on 1-bit. But within the CLK hobby, I'm double-checking that a big maybe that it could possibly be a thing out of curiosity. There's never going to be Marketing for 1-bit Clock Sources @5.6448 MHz as the demand is very low and niche, so "1-bit" would likely never be entertained.
All I know is I'm running 16-bit 44.1 KHz with a 5.6448 MHz clock and today I started to try to get a better understanding of my chain once I learned about 1-bit. So while technically 1-bit Redbook is not a thing straight from the media, I'm wondering if things change when you extract from the media and take the media out of the equation. Because technically, if 5.6448 MHz = 1-bit, then I'm technically running 1-bit Redbook. But 1-bit can be completely out of scope from Clocking.
Yes, Ian's TransportPi AES 1-bit doesn't relate at all to what's discussed above. I'm just giddy discovering 1-bit today, so thanks for the explanation on Ian's TransportPi AES. It gives me more justification to upgrade my TransportPi MKII if it decreases crosstalk. I already pro-actively decrease crosstalk within my chain, so this is welcome news. I support S/PDIF solutions that offer progressive improvements because S/PDIF is also legacy niche, so even if 1-bit is mostly Marketing for TransportPi AES, it's still a progressive improvement.
So I appreciate you taking your time with answers, but I realise now that this 1-bit question is a bit unanswerable unless by the CLK designer. There's no Wiki, no Documentation, No Industry Standard so it's difficult to say a definitive 'No' answer for the clock frequency as a chain not just Redbook media. I'll check back if I get an answer by the CLK designer.
I learned a lot today, it's like a mini crash course on Andrea's thread. Cheers.
1. Iancanada SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, HdmiPiPro*1
2. casshan SC-Pure 45/49 * 1, HdmiPiPro * 1, UcBalancer KIT * 1
3. princeliebe SC-PURE 45/49*1
4. Ben Mah SC-Pure 45/49*1, FifoPiQ7*1, MonitorPi*1
5. WuBai SC-Pure 45/49*1, LinearPiMKIIDual*1, LinearPiMKIISolo*1
6. jiacheng SC-Pure 45/49*1, RFX OCXO*1, MonitorPiPro*1, UCbalancer KIT*2, PurePi*1, GPIO extender*2
7. pyflaw SC-Pure 45/49*1, TransportPi AES*1, FifoPi Q7*1, PurePi*1, UcConditioner 3.3V*1, MonitorPi*1
8. NeoTheOne SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, HdmiPiPro*1, UCbalancer KIT*4, PurePi*1, StationPi Pro*1, ShieldPi Pro/MKII*1, RFX OCXO 45.1584 / 49.1520 MHz, Adapter KIT, SquarePi KIT, MonitorPi Pro, StationPi PCB (free stuff)*1, Linear Pi Dual MkII *1, UcConditioner 5V *1, UCConditioner 3V *1, ReClockPi*1, TransportPiAES*1
9. zapio: SC-Pure 45/49 * 2, TransportPi AES * 1, OPA861 I/V *1
10. WladimirMXP: SC-Pure 22/24*1, FifoPi Q7*1
11. Hires: SC-Pure 22/24*1, UcPureMkIII*1, MonitorPiPro*1
12. BasoFF: SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1, MonitorPi*1
13. smooth dancer: SC-pure 22/24, UCbalancer kit (1)
14. khh:SC-pure 22/24, UCbalancer kit (1)
15. triode4 SC-Pure 45/49*1, UcPureMkIII*2, UCbalancer KIT*4, IsolatorPiII*2, ShieldPi Pro/MKII*2, RFX OCXO 45.1584 / 49.1520 MHz, Adapter KIT, SquarePi KIT, SC-Pure 22/24*1, StationPi PCB (free stuff)*1 MonitorPiPro*1, TransportPi Digi*2
16. puuchan SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1
17. skilion51 SC-Pure 45/49*2, UCbalancer KIT*2, MonitorPiPro*1
18. wlowes SC-Pure 49
19. shoom SC-Pure 45/49*1
20. mikeh2022 SC-PURE 45/49*1, UCbalancer KIT*5, UcConditioner 5v*1, GpioSpacer*1, LinearPi Standoff/Screw Sets*2, MonitorPi Pro*1
21. Shutdown98 SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1
22. Trial and Error SC-pure 45/49*2, FifoPiQ7*1
23. secanbj SC-PURE 45.1584 / 49.1520 MHz x 1
24. SimonJ SC-Pure 45/49*1, UcBalancer KIT*2, MonitorPiPro*1, StationPi PCB (free stuff)*1
25. leviandrose SC-Pure 45/49*1
26. SelektaM SC-Pure 45/49*1
27. walangalam SC-Pure 45/49*1, FifoPi Q7*1, PurePi*1, StationPi PCB (free stuff)*1
28. jims SC-Pure 45/49*1, RFX OCXO*1, MonitorPiPro*1,
29. Canvas SC-Pure 45/49*1
30. Tubo SC-Pure 45/49*1, UCpure mkIII*1
31. AirAir: TransportPi AES*1, UCbalancer KIT*1, UcConditionerMkII 5V, UcConditionerMkII 3.3V, GPIO spacer
32. Photochum1: SC-Pure 45/49*1, FifoPiQ7*1, StationPiPro*1, HdmiPiPro*1, MonitorPiPro*1
33. chi0001 SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, UCbalancer(#41F)*2, HdmiPiPro*1, StationPi PCB (free stuff)*1
34. alecm SC-Pure 45/49*1, FifoPiQ7*1, GPIO extender, HdmiPiPro*1, MonitorPiPro*1, StationPi PCB (free stuff)*1
35. mvaldes SC-Pure 45/49*1, FifoPiQ7*1
36. jrocker SC-Pure 45/49*2
37. stew1234 SC-Pure 22/24*1, UcBalancer KIT*2, HdmiPiPro*1, UcPureMkIII*1, 9038Q2 DAC HAT*1
38. sazzz SC-Pure 45*1, HdmiPiPro*1, GPIO extender, StationPi PCB (free stuff)*1, UcPureMkIII*1
39. Sgaga Sc-pure 22/24*1
40. bisesik SC-Pure 45/49*1
41. spev SC-Pure 45/49*1, MonitorPiPro*2
42. sernikus SC-Pure 45/91*1 MonitorPiPro*1
43. topicreader SC-Pure 45/49*1, FifoPiQ7*1, MonitorPiPro*1, GPIO extender
44. BogdanS SC-Pure 45*1, 49*1
45.Steef SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, UCbalancer KIT*2, TransportPi AES*1
46.KVL: SC-Pure 45/49*2, FifoPiQ7*2, UcPureMkIII*2, UCbalancer KIT*2, MonitorPi Pro*2, ShieldPi Pro MkII*1.
47. sugden : TransportPi AES *1, FifoPi Q7 *1, PurePi II *1, UcConditioner 3.3V *1, MonitorPi *1, SC-PURE 45.1584MHz/49.1520MHz *1, StationPi PCB(free stuff)*1, GPIO spacer*1.
48. mvp: SC-Pure 45/49*1
49. danielu: SC-Pure 45/49*1
50. wcwc: SC-Pure 45/49*1, PurePi*1, LinearPi MKII Dual*1, StationPi PCB (free stuff)*1
51. onepiece01 : SC-Pure 45/49*4
52. drone: SC-Pure 45/49*1,FifoPi Q7 *1, PurePi *1,MonitorPiPro*1,MonitorPi*1,UCbalancer KIT*2,HdmiPiPro*1,shieldPi Pro/MKII*1,OPA861 I/V *1,UCPureMKIII*1,StationPi PCB*1
53. "Drive Shaft": "StationPi Pro MKII (fully finished)*1 (#35B)", "TransportPi AES*1 (#20C)", "StationPi PCB (free stuff)*1"
54. Gabster2000 SC-Pure 45/49*1 StationPi PCB (free stuff)*1
55. Spartacus SC-Pure 45/49*1
56. stephen1212b SC-Pure 22/24 *1 SC Pure 45/49*1
57. MMatt1234: SC-Pure 45/49*1 FiFoPiQ7*1 HDMIPI Pro*1
58. jrhammond95003: SC-Pure 45/49*1, UCbalancer KIT*5
59. rpiaudio SC-Pure 22/24 *1, SC-Pure 45/49*1, FiFoPiQ7*1, StationPiPro*1, MonitorPiPro*1, StationPi PCB (free stuff) *1, ShieldPi PCB (free stuff)*1, RFX OCXO 45.1584 / 49.1520 MHz, Adapter KIT, SquarePi KIT
60. seb2 SC-Pure 22/24 *1, StationPi PCB (free stuff)*1
61. Murdoc SC-Pure 22/24*1, FifoPiQ7*1, HdmiPi Pro*1, TransportPi AES*1, StationPi Pro*1, LinearPi MkII Dual*1, LinearPi MkII Solo*1, UcConditioner MKII 5V*1, UcPureMkIII*2, UCbalancer KIT*4, MonitorPiPro*1, GPIO extender*3, StationPi PCB (free stuff)*1,
62. crm75 SC-Pure 45/49*1, UCBalancer KIT*1,MonitorPiPro*1,StationPi PCB (free stuff)*1
63. isander Sc-pure 22/24*1
64. heathkit SC-Pure 45/49 *1, 23C. ShieldPi Pro Mk II *1, 47A. UcPi Universal Ultracapacitor RPi *1
65. dlucksinger SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*1, HdmiPiPro*1, MonitorPiPro*1, UcConditioner5v*1, ReceiverPi*1, GPIOextender*1
66. flocchini SC-Pure 45/49*1
67. jctong89 SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1, MonitorPiPro*1, UCConditioner MkII 3.3V*1, ReceiverPi *1, StationPi PCB (free stuff)*1
68. mkrasauskas SC-PURE 45/49*1, FifoPiQ7*1, HdmiPi Pro*1, TransportPi AES*1, LinearPi Dual MkII*1, ShieldPi PCB (free stuff)*1, PurePi *1, MonitorPi *1, StationPi PCB (free stuff) *1, UcConditioner MKII 3.3V *1
69. Janosch Simon SC-Pure 45/49*1 StationPi PCB (free stuff)*1
70.Karoly60 SC-Pure 45/49*1,MonitorPiPro*1,UCbalancer kit*2, UcPure MkIII*2
71. MecII SC-Pure 45/49*1
72. Krachluigi SC-Pure 45/49*1, FifoPiQ7*1, PurePi*1
73. MartinJohn SC-Pure 45/49*1, TransportPiAES*1, FifoPiQ7*1, GPIO spacer*1,UcConditionerMkII3.3v*1, LifePO4 Mini 3.3V*1, MonitorPi*1, Universal GPIO Extension Kit*1, StationPiBCP(freestuff)*1
74. Miklau SC-Pure 45/49*1, FifoPiQ7*1, MonitorPi Pro*1, GPIO Extension kit*1, UcHybrid 3.3v*1
75. ichiban SC-Pure 45/49*1, SC-Pure 22/24 *1
76. victhor34 SC-Pure 22/49*1, FifoPiQ7*1, LinearPi MKII Dual*1, StationPi PCB (free stuff)*1
77. J-Ras SC-Pure 45/49*1, FifoPiQ7*1
78.Tamra SC-Pure 45/49*1
79. QZS SC-Pure 45/49*1,FifoPi Q7 *1, PurePi *1,MonitorPiPro*1,UcConditioner3.3V*1,UcConditioner5V*1,UCbalancer KIT*3,HdmiPiPro*1,shieldPi Pro/MKII*1,UCPureMKIII*3,StationPiPro*1,StationPi PCB (free stuff)*1,SquarePi KIT*1,Adapter KIT*1.
80. Batenet SC-Pure 22/24*1,UCbalancer KIT*2
81. yveskoala SC-Pure 45/49*1
82. flohmann SC-Pure 45/49*1, TransportPi AES*1, FifoPi Q7*1, PurePi*1, UcConditioner 3.3V*1, MonitorPi*1
83. Spacejack SC-Pure 45/49*1
84. Smartdriver SC-Pure 22/24 *1, MonitorPiPro *1.
85. qwertyl SC-Pure 45/49*1, FifoPiQ7*1, LinearPi MkII Dual*1, UcConditionerMkII 5V*2, UcPure MkIII*2, UCBalancer KIT*2, MonitorPi Pro*1, StationPi Pro*1, GPIO Extension Kit*1
86. Akasaka SC-Pure 45/49*1, FifoPiQ7*1, MonitorPi Pro*1, UCBalancer KIT*5, UcPureMkIII*5, ShieldPi Pro/MKII*1, LinearPi MkII*1
87. kit0093 SC-Pure 45/49*1, FifoPiQ7*1, HdmiPi Pro*1, UcPureMkIII*1, TransportPi AES*1, StationPi PCB (free stuff)*1
88. geoturbo SC-Pure 24*1, SC-Pure 22/24*1, ReceiverPi Pro (or new DCC..), StationPi PCB (free stuff)*1
89. chih SC-Pure 45/49*1, OPA861 I/V *1, PurePi*1, StationPi PCB (free stuff)*1
90. calebwong SC-Pure 49*1, StationPi PCB (free stuff)*1
91. ChrisMH SC-Pure 45/49*2, FifoPiQ7*1, TransportPi AES*1, UcConditioner 3.3*1, PurePi*1, UcPureMkIII*2, UcBalancer*2, MonitorPiPro*1
92. elfischiso SC-Pure 22/24 *1, StationPi Pro *1, FifoPiQ7*1, TransportPi AES*1, StationPi PCB (free stuff)*1
93. acg SC-Pure 45/49 *1, ReceiverPiRpo *1, TransportPiAES * 1, HDMIPro x 1, FiFoPi Q7 *1, MonitorPiPro * 1, uCPureMKIII x 7, ucBalancer *7, StationPiPro/control cable * 1
94. Subbu K SC-Pure 45/49 *1, MonitorPiPro * 1, UcConditioner MKII 5V * 1, Linear Pi MKII * 1, StationPi Pro SMT * 1
95. harry925 SC-Pure 45/49*1
96. gringo117 SC-Pure 45/49*1
97. Luca72c SC-Pure 45/49*1, LinearPImkIIDual*1, McFIFO*1, McDualXO*1
98. mksung SC-Pure 45/49*1
99. mnichols30030 - FiFoPiQ7*1, 13 mm standoffs*1, 11mm standoffs*1, TransportPiAES*1
100. Michel8 9038Q2Mpi Dual Mono Plus DAC HAT*1, SC-Pure 45/49*1, FifoPi Q7 (1D)*1, PurePi (48A)*1, MonitorPi Pro*1, 18650 3.2v*2, Uc conditionner MKII 3.3V (26B)*1, 2.5mmx11mm metal standoffs lot of 4 sets (12B)*2, Acrylic cap (51A)*1
101. Davidseow SC-Pure 45/49*1 , UcConditioner 3.3V*1 , HDMIPI pro*1 , reclockPi*1 , receiver Pi pro*1 , PurePi*1
102. michaelagiles FiFoPi MA*1
103. CxTurbo RFX OCXO 45/49 *1, SC-Pure 45/49 *1, TransportpiAES *1, ucPureMKIII *3, ucBalancer0*3, GPIOextender1*1, MonitorpiPro*1
104. lorde73 SC-Pure 45/49*1, StationPi Pro *1, FifoPi Q7 *1, TransportPiAES *1, UcPure MKIII *1, ShieldPi PCB *1 (free), UCBalancer *1, LinearPi MKII 5V*1, UcConditioner MKII 5V*1
105. duck552 SC-Pure 45/49 *1, FifoPiMa *1, UcPure MKIII *4, UCbalancer KIT *4, GPIO extender *4
106 iano SC-Pure 45/49 *1, StationPi Pro SMT * 1, FifoPi Q7 *1, PurePi*1, MonitorPiPro * 1, UcConditioner MkII 3.3V*1, TransportpiAES *1, UcConditioner MKII 5V * 1, Acrylic cap (51A)*1, IsolatorPi * 1, DSD/DOP Decoder Board * 1
107. Gsabest: SC-Pure 45/49*1
108. michl2604 SC-Pure 45/49*1, FifoPiQ7*1, StationPiPro*1, DDDAC U.FL input adapter *1, UCbalancer KIT*1, UcPureMkIII*1, LinearPiMKII Solo*1
109. roderickvd SC-PURE 22/24 *2, RFX OCXO 45/49 *1
110. KimBak SC-Pure 45/49*1
111. Igor61 SC-Pure 45/49*2, UcPureMkIII*2, ES9038Q2M DAC MkII*1, TransportPi AES*1, OPA861 I/V*1
112. Spartacus SC-Pure 45/49 * 1
113. Scribble SC-Pure 45/49*1, StationPi Pro *1, FifoPi Q7 *1, MonitorPiPro * 1, StationPi PCB (free stuff)*1, 9038Q2MPi Dual Mono Plus DAC HAT*1, ESS Controller*1, I/V STD MkII standard OPA I/V stage*1, LL1544A Transformer I/V KIT*1, LinearPi Dual MkII*2, UcConditioner MkII 3.3V*1, UcConditioner MKII 5V * 1
114. Misturada SC-Pure 45/49 * 1, FifoPiQ7*1 (1D), HdmiPi Pro (17B)*1, UcConditioner MKII 3.3V * 1 (26B), ShieldPi Pro/MKII *1 (23C)
115. Eddie18: SC-Pure 45/49 * 1, MonitorPi Pro *1, UCBalancer *5
116. kenlaumm SC-Pure 45/49*1, UcPureMkIII*2, UcBalancer*2
117. BMW850 SC-Pure 45/49*1
118. derbraadwurst SC-Pure 45/49 *1, Transport AES *1, GPIO extender *2, UCbalancer kit *1
119. "daniso 96" SC-Pure 45/49*1,MonitorPi Pro*1
120. cps3113 SC-Pure 45/49*1
121. kirks SC-Pure 45/49*1, UcPureMkIII*2, UcBalancer*2
122. fusion360guy SC-Pure 45/49*1, FifoPiQ7*1, PurePi*1, ShieldPiPro*1, MonitorPi*1
123. Sheldonsm SC-Pure 45/49*1, FifoPi Q7*1, 9038Q2mpi Dac*1, OPA861 I/V*1, PurePi*1, TransportPi AES*1
124. Clsidxxl UcPure MK III *1,UcBalancer Kit *1
125. VMRKarnati: UcConditioner 3.3V *1, TransportPiAES*1, FifoPi Q7*1, MonitorPi*1, ShieldPi Pro MkII*1, PurePi*1
126. escutcheon: UcPi *1, FifoPiQ7 *1, SC-Pure 45/49 *1, HdmiPi Pro *1, UcPureMkIII *2, UCbalancer KIT *2, StationPi Pro *1, MonitorPiPro *1
127. mvagusta22: FIFOPiMa*1
128. muralido: SC-Pure 45/49*1
129. bubu200 SC-Pure 22/24*1,UcConditioner 5V*1
130. nounouchet ConditionerPi *1
131. Lorenz0: SC-Pure clocks*1, TransportPiAES*1, FifoPi Q7*1
132. varunach: SC-Pure 45/49*1, HdmiPi Pro*1, FifoPi Q7 *1, PurePi II *1, 4set 2.5mmx11mm standoffs *1
133. fm804: SC-Pure 45/49*1, FifoPiQ7*1, HdmiPiPro*1, PurePi II*1, Monitor Pi*1
I got a little bit over-exuberant yesterday learning about 1-bit and trying to correlate it with 5.6 MHz.
This is what happens when I should be listening instead of researching and discussing Audio.
The answer is a definite "No".
Andrea explained that oscillators are a analogic circuit so it has nothing to do with bit, which is related to a digital circuit.
I'll settle with being happy with a Pure Redbook, 16-bit, 44.1 KHz source @5.6 MHz.
134. sorenm: PurePi II *1, ReceiverPiPro *1, FifoPiQ7*1, I2StoPCM *1
135. JP14: PurePi II *1, ShieldPiPro MKII *1, FifoPiQ7 *1, MonitorPi Pro *1, TransportPiAES *1, Acrylic protection cover KIT *1, 11mm standoffs *1, 13mm standoffs *3, SC-Pure 45/49 *1
136. Joschl: TransportPiAES *1, FifoPiQ7 *1, PurePi II *1, MonitorPi Pro *1
MonitorPi Pro is a powerful integrated control center and universal OLED display panel that works for all kinds of Raspberry Pi audio applications.
MonitorPi Pro is a big step forward upgrade from the MonitorPi with a lot of new additional features. As an integrated controller, it works like a bridge that can link a lot of different boards together for a well accomplished system. MonitorPi Pro can also support RaspberryPi free applications.
MonitorPi Pro User's manual is attached.
Difference between MonitorPi and MonitorPi Pro
MonitorPiPro
FlagShip Full function DDC
Flagship audiophile full function DDC
(1). MonitorPi Pro
(2). TransportPi AES or HdmiPi Pro or both
(3). FifoPiQ7 with upgraded to SC-Pure clocks
(4). GPIO spacer (optional)
(5). ReceiverPi DDC with Amanero USB (optional)
(6). RespberryPi (optional)
(7). PurePi power supply
(8). Apple remote control (optional)
MonitorPiComparison | MonitorPi | MonitorPi Pro |
Suitable applications | Universal Rapberry autio applications | Audio project integration |
OLED screen | 1.3" | 1.54" |
Replace Screen | Need to de-solder and re-solder | Replaceable with FFC connector |
Real Time Music Format Analyzer | Yes | Yes |
FifoPi controller | Yes | Yes |
ESS DAC controller | No | Yes |
DDC controller | No | Yes |
Control Knob | No | Yes |
SYNC charging control | No | Yes |
Apple IR Remote | Passthrough to RPi only | Yes |
Stop OLED power when Dim | No | Yes |
Screen Saver | Yes | Yes |
Brightness adjustment | Yes | Yes |
Mounting holes | No | Yes |
Size | 58mm x 23mm | 73mm x 29mm |
MonitorPiPro
(1). MonitorPi Pro
20. mikeh2022 SC-PURE 45/49*1, UCbalancer KIT*5, UcConditioner 5v*1, GpioSpacer*1, LinearPi Standoff/Screw Sets*2, MonitorPi Pro*1, GPIO 40PIN Extension Kit*1
109. roderickvd SC-PURE 22/24 *1, SC-PURE 45/49 *1, RFX OCXO 45/49 *1
35. mvaldes SC-Pure 45/49*1, FifoPiQ7*1, OPA861IV*1, MonitorPi Pro*1, ES9038Q2MPi*1
Hi @iancanadaMonitorPi Pro is a powerful integrated control center and universal OLED display panel that works for all kinds of Raspberry Pi audio applications.
MonitorPiComparison MonitorPi MonitorPi Pro Suitable applications Universal Rapberry autio applications Audio project integration OLED screen 1.3" 1.54" Replace Screen Need to de-solder and re-solder Replaceable with FFC connector Real Time Music Format Analyzer Yes Yes FifoPi controller Yes Yes ESS DAC controller No Yes DDC controller No Yes Control Knob No Yes SYNC charging control No Yes Apple IR Remote Passthrough to RPi only Yes Stop OLED power when Dim No Yes Screen Saver Yes Yes Brightness adjustment Yes Yes Mounting holes No Yes Size 58mm x 23mm 73mm x 29mm
MonitorPiPro
(1). MonitorPi Pro
Your MonitorPi pro looks really nice😊
You mention in the manual that it also works with the StationPi pro. Is it controlled with a cable to J14 manual control on StationPi pro?
Regards Mikkel
47. sugden : TransportPi AES *1, FifoPi Q7 *1, PurePi II *1, UcConditioner 3.3V *1, MonitorPi Pro *1, SC-PURE 45.1584MHz/49.1520MHz *1, StationPi PCB(free stuff)*1, GPIO spacer*1.
19. shoom SC-Pure 45/49*1.MonitorPi Pro *1
Another small addition.
#19,
If you want to modify, just repeat what you did for post #4,997 minus any comments.
So select and copy all from #1 to #LAST then paste into new post then edit your line number.
I'll try to take care of it, but if there is a next time pls don't hesitate to try again.
19. shoom SC-Pure 45/49*1, MonitorPi Pro *1, BridgePi *1
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
