Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 24th February 2012, 05:25 PM   #11
pedefede is offline pedefede  Denmark
Originally Posted by pedefede View Post
Hi Ian
will order
- one FIFO kit
- one Dual clock board
peter
and also:
- one spdif-board
- 6 pieces of 4'' double-ended 50 ohm coaxial cable $2 USD/ea
Peter
Old 24th February 2012, 05:32 PM   #12
randytsuch is offline randytsuch
One I2S board, and one dual clock board please
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 24th February 2012, 05:46 PM   #13
Forane12 is offline Forane12  Bulgaria
one of each please
Old 24th February 2012, 05:55 PM   #14
neb001 is offline neb001  United States
One of each for me as well please:
1 x I2S FIFO KIT
1 x Dual XO Clock board
1 x S/PDIF Interface Board
Old 24th February 2012, 11:56 PM   #15
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by necplusultra View Post
Is it possible to purchase an unpopulated kit?
Hi necplusultra
Very good question. I understand what you mean. Just let me explain why I couldn’t just supply the empty PCB and components.
Different from those discrete 74 logic boards which you could test point to point by yourself, the FIFO board has all the logic state machines running at decades of MHz inside the FPGA/CPLD. Even though you could solder those SMT components with perfect, you still have to face the problems of ISP and testing. For example, the on-board FIFO memory has 4 megabit cells, if some of them have reading or writing glitch occasionally, you might be noticed something wrong by listening, but you can’t address it.
Beside the FIFO board, another FPGA based dedicated test board was designed at same time. That test board could takes over all the input and out ports of the FIFO KIT, scan all the functions and cells by performing loop testing to make sure everything is good with bit perfect, as well as the S/PDIF board and the clock board. All of the boards for the group buy have to pass that test before delivery. Otherwise, it would be a big trouble for both of us.
Have a good night! Regards,
Ian
Old 25th February 2012, 07:06 AM   #16
vzs is offline vzs  Europe
Hi Ian,
I would like:
1 x I2S FIFO KIT
4x 4" Cables
thanks
Old 25th February 2012, 02:11 PM   #17
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Awesome!
I would like:
1 x I2S FIFO KIT
Thank you for sharing this!
Old 26th February 2012, 08:32 PM   #18
enantra is offline enantra  Spain
I need:
1 I2S FIFO
1 Dual XO clock
1 6” double-ended 50 ohm coaxial cable
1 12” double-ended 50 ohm coaxial cable
Thanks you
Old 27th February 2012, 09:13 AM   #19
vitalica is offline vitalica  Europe
I would like:
1 x I2S FIFO KIT
4x 6” double-ended 50 ohm coaxial cable
4x 12” double-ended 50 ohm coaxial cable
Thanks you!
Old 27th February 2012, 08:59 PM   #20
Ian please add this
3 6” double-ended 50 ohm coaxial cable (4 total)
3 12” double-ended 50 ohm coaxial cable (4 total)
thanks
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4661 7th June 2018 08:35 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
