Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 23rd February 2014, 07:40 AM   #1561
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
jbercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
roger57: 1x I2S FIFO KIT V3.80
mhgawel: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x I2S backdoor KIT, 1x SMT XO Adapters KIT, 1x Finished FIFO Isolator Board, 3x SMT finished Battery Management KIT, 2x I2S to PCM converter, ##x U.FL Cables
nanocamp: pcm
lordvader : 1x I2S to PCM converter
flowerpot: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board.
4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
Gogi x1 PCM board
JustBuildLspkAS x4 finished FIFO i2s isolator Board , x2 Si570 Clock Board V3.5(with Si570) to play 24/384 Material
clsidxxl:1x finished Battery Management kit
kokonut : 1x I2S to PCM converter
casshan: 1 x I2S FIFO KIT v3.8, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board V2.5
fordgtlover: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x pkg Universal SMT XO Adapters
curryking: 10 x Dual XO clock board,5 x 6" double-ended U.FL coaxial cable,6 x package of universal SMT XO adapter kit
bisesik: 1x I2S to PCM converter
MadKid: 1 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
dant100: 1x I2S FIFO kit, 1x Dual XO Clock Board, 1x Pack of SMT XO Adapters, 1x Finished FIFO isolator board, 1x Finished Battery management board
Phi: 5x I2S FIFO kit, 3x Dual XO Clock Board, 3x Pack of SMT XO Adapters, 5x Finished FIFO isolator board, 5x Finished TPS7A4700 Regulator board, 2x Finished Battery management board , 5x I2S to PCM converter, 1 x Si570 Clock Board (at least this)
zz1969: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
kenneth_obee: 2 x I2S FIFO Kit, 2 x Finished FIFO Isolator Board, 1 x Dual XO Clock board, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board, 2 x adapters for Crystek if you still have them
SomekPoland: 1x I2S to PCM, 1x S/PDIF Interface Board
henry97: 1x I2S FIFO KIT, 1x Dual XO Clock Board
nopants: 1x I2S FIFO Kit, 1x SPDIF Kit, 3x SMT XO Adapters, 6 x 6" double-ended U.FL coaxial cable
GhostMM : 1xFIFO board, 1xIsolator Board V2.5, 1XDuax XO clock board, 1xI2S to PCM board, 1X10P 1.0mm FFC/FPC cables, 1xPackage of Universal SMT XO Adapters
vertigen: 1xPackage of Universal SMT XO Adapters
zjerneic: 1x S/PDIF Interface Board
tame:1xI2S to PCM board
lbamda: 1* I2S FIFO KIT ; 1* Dual XO Clock board ; 1* S/PDIF Interface board ; 4* SMT U.FL socket ; 1* 4" U.FL doublr ended coax cable ; 1* 6" U.FL doublr ended coax cable ; 1* I2S backdoor kit for S/PDIF board ; 1* Universal SMT XO adapter kit ; 1* Si570 clock board V3.5(with Si570) ; 1* Finished FIFO Isolator board ; 1* Finished TPS7A4700 low noise regulator board V.2.5 ; 1* SMT Finished Battery management mini kit V.2.5
johnmarkp: 1 x BIII adapter PCB, 1 x SMT connector package for BIII, 4 x 4" double ended silver U.FL
nautibuoy: 1 * I2S FIFO Board; 1 * Dual Clock board; maybe other stuff when I've read all the information!
Old 23rd February 2014, 07:48 AM   #1562
dant100 is offline dant100  United Kingdom
Originally Posted by JustBuildLspkAS View Post
Dear dant100 (and johnmakp)
You must using copy information from the last post on #1556 by flowerpot.
Hi JustBuild,
I did copy flowerpot's post in my post at #1557. Then johnmarkp posted but must have used an old one as my changes had been removed.
I then copied johnmarkp's post to re-enter my changes.
I was about to edit my post but nautiboy has just posted so I will have to copy his and check all the changes since post #1556 and re-enter them for everyone.
Cheers
Dan
Old 23rd February 2014, 07:54 AM   #1563
nanocamp: pcm
Gogi x1 PCM board
JustBuildLspkAS x4 finished FIFO i2s isolator Board , x2 Si570 Clock Board V3.5(with Si570) to play 24/384 Material , x8 I2S to PCM converter , x2 spdif interface
Old 24th February 2014, 06:29 PM   #1564
nautibuoy's Avatar
Hi Ian. Please don't take this question the wrong way as there is no intention to pressure anyone and I'm quite able to do patience....
What is the trigger point for progressing the requests in the current waiting list?
Ray
Old 25th February 2014, 11:16 AM   #1565
GhostMM is offline GhostMM  France
GBVFIFO69 well received, thank you !
Old 1st March 2014, 05:30 AM   #1566
zapio is offline zapio  Poland
nanocamp: pcm
Gogi x1 PCM board
zapio : 3x Dual Clock board
Old 2nd March 2014, 02:53 PM   #1567
malarkey is offline malarkey  Germany
nanocamp: pcm
Gogi x1 PCM board
Old 3rd March 2014, 01:25 AM   #1568
Joonas is offline Joonas  Finland
nanocamp: pcm
Gogi x1 PCM board
Joonas: 1*I2S FIFO kit, 1*S/PDIF interface board, 1*Si570 clock board, 1*Finished isolator 2*I2S to PCM converter, 1*Finished Battery management kit
Old 3rd March 2014, 09:25 AM   #1569
SomekPoland is offline SomekPoland  Poland
nanocamp: pcm
Gogi x1 PCM board
Old 6th March 2014, 08:13 AM   #1570
henry97 is offline henry97  United States
nanocamp: pcm
Gogi x1 PCM board
henry97: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished isolator, 1x I2S to PCM converter.
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4492 27th July 2017 06:22 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2017 diyAudio
