Ian asynchronous I2S and S/PDIF FIFO KIT group buy Ian asynchronous I2S and S/PDIF FIFO KIT group buy - Page 126 - diyAudio
Group Buys Members group buys
Old 20th May 2013, 06:26 PM   #1251
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by lxiaob View Post
If there were a lot of people have done this in the incorrect way, that means something for the organizer of this thread. Your blaming will not fix this problem in the future, so it is meanness.
its got nothing to do with Ian other than saving him (or others) the hassle of combing through, fixing peoples orders and following up to ask exactly what people want. It was actually explained quite well several times in the thread and its just plain logic as well as paying attention.
as with any GB list you add your name to the end of the list thats included on most pages at least once and include what you want
If you dont do this, somebody else has to fix it. its really not hard, the GB has many different items, just putting your name (twice) says what? you want everything (twice)?
are you seriously trying to lay blame for this on Ian or hochopeper?
wow...
Old 20th May 2013, 07:51 PM   #1252
billyk is offline billyk  United States
billyk's Avatar
Participating in a group buy is not rocket surgery.... If not sure ask someone! These guys that admin these GB are doing us in the community a great and valuable service!
I am not trying to pile on here, but man it just gets to me, if you want to participate it would be to your advantage and the relief of the others to do it correctly.
Thanks,
Billy
Old 20th May 2013, 08:26 PM   #1253
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by hochopeper View Post
The responsibility for a group buy is on the buyer not the seller. In the case of 99% of all GBs on DIYAudio the 'seller' is not making profit (often quite the opposite) and is donating their time already. In this case it is simply a matter of you spending time to help Ian to help you. The list is used by Ian to work out how many boards of each type to get made, a way of gauging demand. He cannot do that unless you tell him what you're after.
Since I am the guy that wrote the FIFO wiki page, I want to point out that it is intended as a way of navigating the development thread to find technical information that was previously buried, it will not include GB FIFO administrative information more than a simple pointer to the most recent GB offering page. The GB is a separate activity and of no interest to me, my interest is on the technical side and application of the equipment that Ian has designed and offered.
Thanks hochopeper,
Yes, It would be better if people list what they want. That will let me know exactly how many BOM I need to order for the next GB. I already have this kind of issues. Some of the KITs run out and many others over stock. I didn't ask for any prepayment, but a lot of my money sill "in stock" .
Again, the list is just a waiting list. I'm trying to supply you all. But for the above reason, I couldn't guarantee making all of you happy. I thank you for you kind understanding and considering.
I'm sorry for those who are new to this thread, I always forget it's a long thread and it's very difficult for you to go through it before you put your name on the list. Please see post of last GB linked below my signature, hope it helps on getting understand how I ran the GB.
Ian
Old 21st May 2013, 12:06 AM   #1254
lxiaob is offline lxiaob
Sorry for making everybody confused to this list. I deleted my name from the 19th of the list, and update the latest GBV list as following:
1. jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
2. Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
3. Ceglar : 1x FIFO, 1x Assembled FIFO Isolator, 1x a few extra cables.
4. APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
5. duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
6. chi0001: bIII adapters pcb x4, tps7a4700 x4
7. hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6 double-ended 50 ohm coaxial cable
8. malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator
9. mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
10. casshan : 1 x I2S FIFO KIT v3.8, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 1 x 10P 1.0mm FFC/FPC cables, 1 x Finished FIFO isolator board v2.5
11. hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
12. luisbock
13. lxiaob
14. koldby: 1x i2s FIFO kitv3.80, 1x finished FIFO isolator board, 1x Package of Universal SMT XO Adapters lot of 5, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT,4x 6 double-ended 50 ohm coaxial cable
15 kazap: 1x i2s FIFO kitv3.80, 1 x PCM1704 board, 1x Dual XO Clock Board, 1x finished FIFO isolator board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x Battery management, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 4x 6 double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 10x SMT U.FL socket
16. iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
17. flowerpot: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board, 5 x SMT U.FL socket, 5 x 4 double-ended 50 ohm coaxial cable, 1 x I2S backdoor KIT for S/PDIF board, 1 x Package of Universal SMT XO Adapters, 1 x Finished FIFO isolator board V2.5, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters
18. audiopassion
19.ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12 double-ended 50 ohm coaxial cable, 1x6 double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters.
20: LOBOONE: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT[/QUOTE]
21. errmoo I2S FIFO KIT V3.80, Si570 Clock Board V3.5(with Si570), S/PDIF Interface Board
22. sernikus I2S FIFO + Dual XO
23. TonB
Old 21st May 2013, 12:21 AM   #1255
qusp's Avatar
but what do you actually want? its not us thats confused
Old 21st May 2013, 01:09 AM   #1256
casshan is offline casshan  Hong Kong
10. casshan : 1 x I2S FIFO KIT v3.8, 1 x Dual XO clock board v3.3, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 1 x 10P 1.0mm FFC/FPC cables, 1 x Finished FIFO isolator board v2.5
12. luisbock
13. lxiaob
18. audiopassion
23. TonB
Old 21st May 2013, 01:28 AM   #1257
I have gotten some cards from Ian by the 13th of this list,so the 13th of this list has been done. I was trying to order the second set by adding myself on 19th of this list, and emailed Ian my needs as well. The excel file is the most important as my understanding.
Because I put myself twice on this list that confused other buyers and Ian, I would like to quit the 19th of this list and wait for the next round.
Old 21st May 2013, 05:43 AM   #1258
hochopeper is offline hochopeper  Australia
Yes the excel list is most important, because that's what Ian uses to pack your order.
However, think about a step before that stage, Ian has to work out what to get made, before you send him the excel order page. Though you may have told Ian by email what you are intending to order, imagine if he has 50+ people emailing him and he has to go through all the emails to work out how many of each PCB and their BOM to order? The point of the list is to have one place where Ian can go to try to work out how many of each he should order/build so that he can avoid being left with $$$ tied up in left over bits that no body ordered because he had to take a wild guess at what to buy. So, we keep a list of what everyone is wanting on the thread so that Ian can save some time on unrewarding administrative tasks.
Old 21st May 2013, 04:56 PM   #1259
koldby is offline koldby  Denmark
koldby's Avatar
For various reasons I have removed my entry to the list
Koldby
[QUOTE
12. luisbock
13. lxiaob
18. audiopassion
23. TonB[/QUOTE]
What is Home Theatre without good sound?
Old 22nd May 2013, 07:29 AM   #1260
korben69 is offline korben69  France
12. luisbock
13. lxiaob
18. audiopassion
23. TonB
24. korben69 : 3 x Bare PCB of TPS7A4700
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4488 Today 07:46 AM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 07:01 PM
Copyright ©1999-2017 diyAudio
