Group Buys Members group buys
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Old 20th February 2013, 01:33 AM   #1091
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by buzzforb View Post
67
Email replied.
Ian
Old 20th February 2013, 07:22 AM   #1092
noizas is offline noizas  Lithuania
Invoice ID GBIV82 paid.
Thank you Ian
Old 20th February 2013, 09:32 AM   #1093
marcus1 is offline marcus1
Default Late entry:
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
5. AR2 2 x Si570 clock board - definitely!
6. wktk_smile
7. hirez69 1 x Si570 clock board, 2 x Isolator board, 4 x TPS7A4700 reg board, 2 x Battery management board
8. CeeVee - you bet!
9. number9 Si570 Clock Board
10. analog_sa - 2 x Si570 clock board, 2 x FIFO isolator, 2 x TPS7A4700
11. edbk
12. atom6422
13. misterrogers 1xI2S FIFO KIT, 3x Si570 Clock board, 3x TPS7A4700 Regulator boards, 1x FIFO isolator, 1x Battery management board
14. NicMac - as usual!
15. Zoran
16. PET-240- SI570 x1, Isolator Board(pre-tested?) x 1.
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
23. Greg Stewart: 1 x Si570, 2 x TPS7A4700 board, 8 x U.FL 2" cable (if they become available)
24. Vitalica (2 x Si570 clock board, 2 x Isolator board, 4 x TPS7A4700 reg board, 2 x Battery management board)
25. spm
26. Fridrik
27. ccliu
28. makumba1966 : 2 x Si570, 2 x TPS7A4700 board, 8 x U.FL 2" cable, 2 x Universal I2S isolator, 2 x Passive Battery Management Adapter Rev2.0, 2 x Isolator board
29. lindamar: 1 x Si570 , 2 x TPS7A4700 board, 1 x Universal I2S isolator, 1 x Passive Battery Management Adapter Rev2.0, 1 x Isolator Rev2.0 board, 1 x I2S backdoor KIT for S/PDIF board (is that an additional board?)
30. Finaxe : 1 x SMT connector package for BIII adapters, 1 x Si570 Clock Board V3.5(with Si570), 1 x Finished FIFO isolator board V2.5, 3 x Finished TPS7A4700 low noise regulator board V2.5 and 2 x SMT finished Battery Management V2.5 Mini KIT
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985 1x Si570 clock board, 1 x TPS7A4700 reg board
37. rsotirov 1x Si570 clock board
38. kvl 1 x Si570 clock board, 1 x Isolator board, 1 x TPS7A4700 reg board, 1 x Battery management board, 1x 1.0mm FFC/FPC cables combo, 1 x back door kit.
39. bkdog - 1 x I2S FIFO KIT, 1 x Si570 clock board, 1 x S/PDIF Interface Board, 1 x Isolator board, 1 x BufalloIII u.fl adapter kit, 1 x BufalloIII Clock adapter kit, I2S backdoor KIT, BIII adapter PCB, SMT connector package for BIII adapters, 1 x FIFO isolator board V1.5 MINI KIT, 3 x battery management pcb
40. necplusultra
41. Nikola Krivorov 2 x Si570 clock board, 3 x I2S to PCM board, 2 x TPS7A4700 reg
42. nvduybom
43. Popolvar - 1 x Si570 clock board, 1 x dualXO clock board, 1 x TPS7A4700 reg board, 1 x Package of Universal SMT XO Adapters, 1 x FIFO isolator board V2.0, 1 x Passive Battery Management Adapter Rev2.0
44. TNT 1 x Si570 clock board, 1 x Isolator board, 6 x TPS7A4700 reg board
45. sidiropa 1x Si570 clock board, 1x isolator 1x 1.0mm FFC/FPC cables combo, 1x battery management pcb,1 x S/PDIF board, , I2S backdoor KIT for S/PDIF board, 2 x TPS7A4700 reg board
46. leejh
47. Alcaudon 1 x FIFO kit, 1 x Si570 clock board, 1 x S/PDIF Interface board, 1 x FIFO Isolator, 1 x Universal I2S/DSD Isolator, 1 x I2S Backdoor kit, 2 x TPS7A4700 Reg. board, 2 x Battery management board.
48. sernikus (all + 2xSi570 )
49. enantra
50. Giordano, FIFO kit + a dual osc.
51. oyvind I2S FIFO KIT, Si570 clock board, S/PDIF Interface Board, I2S backdoor KIT for S/PDIF board, BIII adapter PCB, SMT connector package for BIII adapters, FIFO isolator board V1.5 MINI KIT, battery management pcb
52. duster1 1x Si570 clock board, 1x isolator
53. Blitz Si570 clock, 1x isolator, 3 x TPS7A4700 reg board, 3 x Battery management board, 1 x back door kit, 10 clock adapter for dual clock (2*5), 2 BIII adapters, both sides (incl. 2* Sync.Clock adapters)
54. Josoeff 1 x I2S FIFO KIT V3.80, 1 x S/PDIF Interface Board, 1 x Finished FIFO isolator board V2.5, 2 x BIII adapters PCB, 2 x Finished TPS7A4700 low noise regulator board V2.5, 4 x PCB of TPS7A4700 low noise regulator
55. crobbins5421 1 x FIFO kit, 1 x S/PDIF board, 1 x Si570 Clock Board
56. Regal 2 x Si570 clock , 2x TPS7A4700 reg board, 2 x Battery management board, 2 x back door kit,2x isolator board
57. aos FIFO kit, S/PDIF board, 1 x Si570 clock, 6 x U.FL socket, 3 X 6" U.FL cable, 1 X I2S backdoor kit, 1 X SMT XO adapter package, 1 X BIII adapter, 1 X SMT conn for BIII, 1 X FIFO isolator, 2 X cables combo, 2 x TPS7A4700 reg board
58. dvb-projekt 1x FIFO Kit, 1x Dual XO clock kit, 1X Isolator board kit, 1x S/PDIF interface board kit, 1x Backdoor Kit
59. Tubo 1x si570 clock kit, 1x isolator board, 1x tps7a4700 regulator board
60. bisesik 1xI2S FIFO KIT, 1x Dual XO Clock board (Si570), 1 x S/PDIF Interface Board, 1x I2S backdoor KIT for S/PDIF board, 2x FIFO isolator, 1x Battery management board
61. BDL 1 x Si570 clock board, 1 x Isolator board, 2 x TPS7A4700 reg board, 2 x Battery management board
62. damohpi 1x FIFO kit, 1x Si570 kit, 1x isolator kit, 1x spdif board kit, 1x backdoor kit, 1x TPS7A4700 reg board, 1x batt management kit, 4x4" U.FL, 4x6" U.FL, 4x U.FL socket
63. Overkill Audio - 1xI2S FIFO KIT, 2x Si570 Clock board, 1x FIFO isolator, 1x Battery management board
64. JoeyDD - 1x FIFO kit, 1x Si570 kit, 1x FIFO isolator kit, 3x U.FL 6" cable
65. chi0001 - 1x Si570 clock board, 1 x TPS7A4700 reg board
66. edlinssen Si570
67. buzzforb - 1x FIFO kit, 1x isolator kit, 1x spdif board kit, 1x backdoor kit , accessories
68. hughs
69. ccliu - 2x Si570 Clock board, 1x FIFO isolator, 2x TPS7A4700 reg board, 2x Battery management board
70. mhgawel - 1x FIFO Kit, 1x Dual XO clock kit, 1X Isolator board kit, 1x S/PDIF interface board kit, 1x Package of Universal SMT XO Adapters KIT (lot of 5)
71. Telstar - 4x Finished TPS7A4700 low noise regulator board V2.5 $25.00 CAD/ea + 2x PCB of TPS7A4700 $3.93 CAD + 2x Passive Battery Management Board V2.5 Mini KIT $9.98/ea
72. t27049215 - 1x FIFO Kit, 1x Dual XO clock kit, 1x Si570 clock board, 1X Isolator board kit, 1x S/PDIF interface board kit, 2x TPS7A4700 reg board
73. themystical - 2xTPS7A4700 Regulator boards
74. jtktam - 5x FIFO Kit, 5x Dual XO clock kit, 5X Isolator board kit, 5x S/PDIF, 3x U.FL 4" , 3x U.FL 6" cable, 3x U.FL 12" cable, 3X Isolator board kit, 3x S/PDIF interface board kit
75.mcluxun 1x FIFO Kit, 1x Isolator board kit, 1x S/PDIF, 1x Si570 clock board,
76. unixdeveloper - 1x Package of Universal SMT XO Adapters KIT (lot of 5), 3x U.FL 4" , 3x U.FL 6" cable, 3x TPS7A4700 reg board
77. JamesHill
78. Seavan - FIFO kit, dual xo clock kit (Si570?), s/pdif interface, i2s backdoor kit, isolator board kit, 3xU.Fl 4", 3xU.Fl 12", SMT XO adapter package, BIII adapter, SMT for BIII, FFC/FPC combo, battery management PCB
79. vzs - 1 x Package of Universal SMT XO Adapters; 4x 4 U.FL cable; 6x U.FL socket
80. henry97 - 1 x I2S FIFO KIT, 1 x Si570 clock board, 1 x S/PDIF Interface Board, 1 x Isolator board, 1 x BufalloIII u.fl adapter kit, 1 x BufalloIII Clock adapter kit, I2S backdoor KIT, BIII adapter PCB, SMT connector package for BIII adapters, 1 x FIFO isolator board V1.5 MINI KIT, 2 x battery management pcb
81. TheShaman - TBD
82. noizas 1x I2S FIFO Kit, 1x Dual XO clock kit (Si570), 1x S/PDIF interface board kit, 1X Isolator board kit, 1x Backdoor Kit, 2xU.Fl 4", 2xU.Fl 6", 2xU.Fl 12", 2x Battery management board
84: SSassen : 1x I2S FiFo kit, 1 x Package of Universal SMT XO Adapters, 1 x Si570 clock board, 4x TPS7A4700 Regulator boards, 1x S/PDIF interface board kit
85.hksidney 1x i2s fifo kit, 1 x si570 clock board, 1 x s/pdif interface kit, 1 x isolation board kit.
86. WhiteBull: 2x FIFO Kit, 2x Si570 clock board + TPS7A4700 Regulator board, 10x U.Fl 4" cables, 8x U.Fl sockets, 1x BIII adapter kit, 2x FIFO isolator board, 2x Universal I2S/DSD isolator, 2x FFC/FPC cables combo
87. Karvid: 1x Si570 clock board
88. RSG: 1 x I2S FIFO KIT, 1 x S/PDIF Interface Board.
89. Joonas: 1x Dual clock board, 1x Isolator mini kit
90. TonyB: everything, some things 2x
91. Bemused 6x TPS7A4700 Regulator boards3 x BufalloIII u.fl adapter kit
92. greyrab: 1 x I2S FIFO Kit, 1 x Dual XO Clock board, 1 x S/PDIF interface board, 20 x SMT U.FL socket, 2 x 4" U.FL cable, 2 x 6" U.FL cable, 2 x 12" U.FL cable, 1 x I2S backdoor kit, 1 x SMT XO adapters kit lot of 5, 2 x BIII adapters PCB, 2 x 10P cables combo, 1 x Si570 clock board, 1 x FIFO isolator board, 1 x TPS7A4700 regulator board, 1 x battery management mini kit
93. lll: 4 x TPS7A4700 (V2.5), 2 x FFC/FPC cables combo, 2 x Isolator board (V2.5).
94. vts2006 : I2s FIFO KIT x 2 , DUAL XO CLOCK BOARD x 2 , S/PDIF INTERFACE x 2 , I2S backdoor x 2 , Package of SMT XO Adapters x 2 , Additional BIII adapters x 2 ,
SMT connector for BIII x 2 , Finished FIFO isolator x 2 , Finished regulator TPS7A4700 X 4 , Battery board x 2 .
95. JustinVT: 1. I2S FIFO Kit, 3. S/PDIF Board, 4. I2S Backdoor, qty=1 of each.
96. Miksi 3x TPS7A4700 Regulator boards
97. andrea_mori 20 x SMT U.FL socket, 12 x 4" U.FL cable, 12 x 6" U.FL cable, 4x TPS7A4700 Regulator boards
98. Mravinsky: 1 x finished regulator TPS7A4700 (V2.5), 1 x finished isolator v2.5
99. marcus1: 1 X Si570 Clock Board (with Si570), 1 X finished TPS7A4700 regulator board
Old 20th February 2013, 09:34 AM   #1094
spm is offline spm  United Kingdom
GBIV25 spreadsheet sent.
Many thanks.
Best wishes
Simon
Old 20th February 2013, 10:26 AM   #1095
hirez69 is offline hirez69  Europe
GBIV07 sent.
All the best
hirez69
Old 20th February 2013, 10:27 AM   #1096
oyvind is offline oyvind
Invoice ID GBIV51 has been paid.
Thank you Ian
Old 20th February 2013, 01:11 PM   #1097
Fridrik is offline Fridrik
Invoice GBIV-26 paid
Old 20th February 2013, 02:01 PM   #1098
wktk_smile is offline wktk_smile  Japan
wktk_smile's Avatar
GBIV-06 paid.
Old 20th February 2013, 06:48 PM   #1099
TNT is offline TNT  Sweden
GBIV44 sent. (+ 1 dual CB)
Order as per XL.
Old 21st February 2013, 12:13 AM   #1100
iancanada's Avatar
Default GBIV Shipping status
Shipped Feb. 19.
01,02,10,14,21,24,28,42,47,43,45,53,58,61,69,76,84 ,92,93,96
Shipped Feb. 20
09,13,22,23,30,36,37,41,48,54,55,56,73,75,7,80,86, 91,95,97,98
Tracking number will be sent to your paypal account if applied.
Please let me know if you paid for more than 4 days but not on the shipping list.
Ian
Ian asynchronous I2S and S/PDIF FIFO KIT group buyHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4519 14th November 2017 12:40 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 01:12 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
What speakers are you going to use with your gainclone group buy kit AJ Bertelson Multi-Way 6 2nd March 2004 08:01 PM
Copyright ©1999-2017 diyAudio
