Ian asynchronous I2S and S/PDIF FIFO KIT group buy
updated mine
1. StuderB67: 2x I2StoPCM
2. hopkins:Ffo and Dual Clok kit
3. mk57:S/PDIF interface board
4. sckramer 2x RPi isolator boards
5. MikeyFresh: 2x RPi Isolator
6. Greg Stewart 3x RPi isolator boards
7. Ben Mah: 1x RPi Isolator
8. bigpandahk : I2S/DSD FIFO
9. brother c : 1x MC FIFO & MC XO, 1x Raspi/Odroid isolator
10. ernesternest: 1x RPi isolator
11. RollE2k: 1x RPI isolator
12. tracer5: 1. Raspberry Pi /ODROID I2S/DSD isolator HAT
13/ diyaudnut: 1x MC FIFO & MC XO
14. tsuntaro: 1x MC FIFO & MC XO
15. jonners: 2x RPi Isolators
16. Yatsushiro: 2x RPi Isolators
17. vzs: 1x RPi Isolators
18. clivem: 10x RPi Isolators
19. supra I2S/DSD FIFO KIT, Raspberry Pi /ODROID I2S/DSD isolator HAT
20. ed linssen: I2S to PCM board (1x), TPS7A4700 reg(or alike) (1x).
21. Morde: 1x RPi Isolator HAT board
22. curryking: 1x SPDIF interfaceboard,1x I2S Isolator,1x I2S FIFO II Kit
23. minio: 1x Rpi Isolator
24. number9 2 X RPI Isolators
25. Oyvind 2xRPI Isolators, dual clock board
26. bobsherman
27. pierantonio: 2 x RPi Isolator boards
28. BarG01: I2S to PCM board (1x), 6" double-ended silver plated U.FL coaxial cable (6x), Package of Universal SMT XO Adapters KIT lot of 5 ,
29. Josoeff: 1 x S/PDIF interface boar
30. superberg: I2S to PCM board (1x) + Raspberry Pi /ODROID I2S/DSD isolator HAT (1x)
31. larsth: 2x RPi isolator boards, 1x finished I2S FIFO board, 1x finished Dual XO Clock Board
32. savvas: I2S to PCM board
33. bommetje: 2x rpi isolator
34. minionas 1x RPI/ODROID isolator HAT; 1x SMT finished Battery Management V2.5 Mini KIT; 5x SMT U.FL socket
35. percival007 (3X) I2S to PCM PCB
36. boulogne75: 2 x RPi/Odroid Isolator Boards
37. Blitz: 1x MC isolator+clock. BBB/Rpi isolatorx1
38. Abartels1965: 1x RPI/ODROID isolator HAT
39. Crom: 1 x FIFO DSD Kit & 1 x RPI isolator hat
40. hires: 1x MC FIFO + 1x MC XO board + 1x Rpi/Odroid isolator
41. mvagusta22: 1x FIFO Isolator and 1x Rpi/Ordoid isolator
42. xaled: 1x MC FIFO + 1x MC XO board + 2x Rpi/Odroid isolator + 1x I2S to PCM board
43. JimS: 1x MC FIFO, 1X MC XO
44. mjensen: 1 x MC FIFO, 1 x MC XO, 1 x RPI isolator
26. bobsherman
45. hileman65: 2x I2S to PCM, 4x TPS7A4700 reg, 6x 6" double ended U.FL coax cable
26. bobsherman
46. marcus1: 1 x R Pi/ODROID: I2S/DSD isolator HAT
26. bobsherman
47. Eldam : 1x low noise TS7A reg for Clock II + 1 x Odroid isolator HAT
Any Odroid + I2S to uf-l PCB planned (or does the Buffalo pcb adaptator good enough) ?
Thanks Ian
26. bobsherman
48. rredline: 1x MC FIFO & MC XO, 1x Rpi Isolator, 6x 6" double ended U.FL coax cable
26. bobsherman
49. rmpfyf: 1x MC FIFO, 1x MC XO, 1x I2S to PCM, 2x isolator
26. bobsherman
48. rredline: 1x Rpi Isolator
26. bobsherman
26. bobsherman
50. hpn5350: 1x RPi Isolator Board, 1x I2S FIFO II Kit, 1x Dual XO Clock Board, 1x I2S Isolator, 1x SPDIF Interface, 1x TPS7A4700 Regulator
26. bobsherman
51. Canvas: 1x MC FIFO, 1x MC XO, 2x I2S to PCM, 1x RPI isolator
26. bobsherman
52.
53. trung224: 1x RPI/Odroid Isolator
corrected
26. bobsherman
52. franz159: interested in two Raspberry Pi I2S isolator HAT
26. bobsherman
54. duster1: 1x I2S/DSD FIFO, 1x XO, 1x RPI/Odroid isolator
26. bobsherman
55. kolossos4730 2x RPi Isolators
26. bobsherman
56. Flyingsparks: 1x MC FIFO, 1x MC XO, 2x RPi Isolator Board, 1x SPDIF Interface
Hi guys,
A lot of friends are still interested in my PCM board, as well as up coming multi-channel I2S/DSD FIFO KIT, the RPi isolator and many other gears.
I would ask you putting your ID and the items that your are interested in on to the list below. I'll send message to you once they are available.
Ian KIT Interesting List 2016:
3. mk57:S/PDIF interface board[
4. tubesguy: RPi isolator/QUOTE]
26. bobsherman
57. tubesguy: RPi isolator
58. tods: 1x MC FIFO, 1x MC XO, 4x RPi Isolator Board
