| Group Buys Members group buys |
#421 |
I keep dithering over what to use.
There is the space issue though this is not insurmountable. I initially got some 10uF oil/polypropylene ASC cans to try initially. I am intrigued by the OBBLIGATOs due to their low cost and generally good comments made about them. The 0.33 uF are easier to deal with since there are lots of good choices out there and the size makes them affordable. Has anyone commented on which cap position affects sonics the most? Ironically, I am not obsessing over the resistors. Using the one's TB offered with the boards. How many got good results from the first 2SK117GR they used? As you can tell I have not applied power, yet! (Hope this post is OK within this thread)
Rick McInnis |
#422 |
diyAudio Chief Moderator
The 10uf is most influential followed by the 0.33uF. Obbligato Gold you mention are good value among "boutique" brands. But they are having an exposed metallic shell. Watch out for the two capacitors bodies NOT to contact the extra pads underneath. Also don't touch metallic shell parts with bare hands when the circuit is energized. Those extra pads are there to accommodate for different capacitor sizes and are in circuit. Mount the caps a bit proud for leads length on board. Its good to do that in general even with thin outer wrap plastic shrouded capacitors since this is HV and some distance is good to be maintained to avoid creepage. You can ask for subjective preferences about application and parts some people who had posted builds in the SSHV regs thread, although there should be more who had made and are using such regs by now it seems.
#423 | |
Sounds excellent! |
#424 |
Package arrived, PCB quality is indeed very good.
Thank you Tea-Bag for all your effort. Dick
Music is the best F.Z. |
#425 |
Hi Tea-Bag,
wanted 2 SSHV2 PCB Boards, added name in the spreadsheet. |
#426 |
Hi Teabag,
Being a happy user of the SSHV2 first release, I know would like to get 4 more boards. I presume there is a waiting list, can you please add me on it? Many thanks Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp) http://www.bartola.co.uk/valves/ |
#427 |
#428 |
not politcally affiliated
I added mogliaa regardless.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#429 |
SSHV2 = 30 boards, what's the quantity to make the pcbs?
#430 |
Tea bag, just added myself on the sheet... when should I pay??
PM me the detail please
Mas Penk |
| GB Thread for Salas SSLV1.1 BiB shunt reg | Tea-Bag | Group Buys | 1255 | 14th May 2013 05:31 PM |
| Which Salas HV shunt regulator should I choose? | Tubenstein | Tubes / Valves | 9 | 25th March 2013 02:31 PM |
| GB: Salas Shunt for Squeezebox | mravlca | Group Buys | 8 | 18th July 2011 04:34 PM |
