Group Buys Members group buys
GB for Salas SSHV2 regulator
Old 24th November 2012, 02:05 AM   #391
TerribleT is offline TerribleT  United States
Thanks Teabag for your hard work. Got my package today.
Terriblet
Old 24th November 2012, 02:35 AM   #392
Malvin is offline Malvin  United States
Got mine today. Thank you so much Tea-bag!
Old 24th November 2012, 02:58 AM   #393
roger57 is offline roger57  Canada
roger57's Avatar
Originally Posted by rickmcinnis View Post
And most of all thanks to Mr. Salas for his willingness to use his fine brain for such an absurd but noble hobby.
That's hilarious, well said!!
Old 25th November 2012, 03:10 AM   #394
6L6 is offline 6L6  United States
6L6's Avatar
Received! Thank you very much!
Old 25th November 2012, 10:12 AM   #395
airtangent is offline airtangent  Germany
Default Dimensions of Salas SSHV2 PCB
Hi Tea-Bag,
I might be interested buying 2 such PCB's of the Salas SSHV2 if still available. However can you give me the exact dimensions L * W of the PCB first? Thank you
airtangent
Originally Posted by Tea-Bag View Post
This is a group buy for the purchase of the second generation Salas Shunt High Voltage Regulator.
It's a newer design that Salas did, with CRT brilliant layout work and a bunch of us prototyped over the holiday season. We had a zero percent failure rate of setups amongst us. (Which I consider great, as most of my work , well needs work)
Let's get to the point.
The board is $12 USD.
Shipping is $6 for up to 3 boards
Shipping is $8 for up to 6 boards.
Some may note the increase US has to incur with our local post office. Sorry
Mini-Kits will be available. The cost is higher than I wanted them to be - so I split them in two.
One will include the transistors, diodes and LED, mica and washer. 3 2SK117GRs will be provided for best matching per kit.
The other will include the resistors and the potentiometer Vishay T93YA model which is 100ppm. The rest of the resistors are lower PPM as reasonable. This is $8.00. These of course are optional purchases, and feel free to roll your favorites here, although I recommend a low PPM 68K.
Heatsinks, caps and Molex connectors are not included - although if there is enough strife, we can consider a GB for those as well
Again a disclaimer - this is the most dangerous product I have shipped yet. Failure to respect the high voltage of the product can have deadly consequences. This is not a beginners project!
The full specifications are in the PDF file. (attached as zip)
The google spreadsheet needs to be completed with your username and includes paypal payment details. Please don't post that address here.
The [U]GB ends on ~11/04/12/U]. This will be a quick turnaround GB so those who have been waiting for a while can get there hands on these. Payment can be taken immediately.
Spreadsheet link below.
Google Spreadsheet Round #3 SSHV2
Transistor Minikit 10 USD
3-Toshiba 2SK117's unmatched
3-Vishay 12V .5W Zener
2-20ma Red LED's
2-Supertex DN2540
1-IRF840
2-Fairchild KSA1381ETSU
2-TO-220 Mica Insulator
2-Keystone plastic washers
Resistor Minikit 8 USD
2- Welwyn 68K 2W 50ppm
1-KOA M/F 1/4W 100ppm 1.82R
1-T93YA Vishay/Fernice trimmer 1/2W 100ppm 200R
1-T93YA Vishay/Fernice trimmer - 1/2W 100ppm 1K
3-271 Series Xicon 1/4W 50ppm 100R
1-271 Series Xicon 1/4W 50ppm 10R
1-271 Series Xicon 1/4W 50ppm 1.8k
1-271 Series Xicon 1/4W 50ppm 470R
1-271 Series Xicon 1/4W 50ppm 220R
Old 25th November 2012, 11:56 AM   #396
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I am currently out of the boards. Sorry. I will get measurements for you.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 25th November 2012, 01:42 PM   #397
rickmcinnis is offline rickmcinnis  United States
Default Extra parts in the kit?
I notice there are extra LEDs and some of the small signal FETs.
Are these in case we blow something up?
When it comes to the LED will one of them give a better result for voltage desired?
If this has been explained already please forgive me. But, point me to the thread, please.
Thanks,
Rick McInnis
Old 25th November 2012, 02:00 PM   #398
Tea-Bag's Avatar
For the most part the extra JFETS are match preffered IDSS.
Old 25th November 2012, 03:58 PM   #399
Tea-Bag's Avatar
Dimensions, also listed in build guide, are 135mm x 48mm
Airtangent, if you want me to put you on waiting list for the next round.
Let me know.
Tea
Old 26th November 2012, 03:46 AM   #400
skyraider is offline skyraider  Malaysia
Default Received
Thanks!
GB for Salas SSHV2 regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1666 24th June 2018 05:30 PM
Which Salas HV shunt regulator should I choose? Tubenstein Tubes / Valves 9 25th March 2013 02:31 PM
GB: Salas Shunt for Squeezebox mravlca Group Buys 8 18th July 2011 04:34 PM
