Group Buys Members group buys
GB for Salas SSHV2 regulator
Old 22nd October 2012, 06:30 PM   #351
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Originally Posted by Tea-Bag View Post
I think that's too much current for a BIB, they are more appropriate for solid state power supply re-engineering. But Salas might be able to say more.
Can it do 3A at 5V? It's OK if not. I have a DAC and its analog section that can make use of it, as well as a 40W power amp.
Old 22nd October 2012, 06:35 PM   #352
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You should use high power very well sinked Mosfets, not the standard ones. Rather the IRF640 & 9640 variety. Thermally inefficient especially on the CCS Mosfet that will have to run the Ih current plus some margin across a minimal 7V in-out drop.
Old 22nd October 2012, 06:40 PM   #353
Salas's Avatar
If you need go near 3V with a Mosfet you should use a logic level shunt position part. The likes of FQP50N06L.
Old 22nd October 2012, 06:43 PM   #354
Thanks Salas! I will try it when I get my boards.
Old 23rd October 2012, 04:41 PM   #355
rickmcinnis is offline rickmcinnis  United States
Default Sent my money and a request
THANKS very much to you and of course to the sainted Mr. Salas for this!
Would you show a picture of a suitable heatsink for the project? I have no idea how to size a heatsink and would like a baseline of what I need to get.
Take care,
Rick McInnis
Old 23rd October 2012, 04:47 PM   #356
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Got the payment Rick, do you have a target voltage and current? It will depend on that to a degree. I would think a 3 x 4" one with 1 1/2 fins would be a good guess. Bigger is better here. The one I used in post one was too small.
Most Salas Boards In stock, Private Message | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Available, PM
Old 23rd October 2012, 04:55 PM   #357
Tea-Bag's Avatar
I also have the following for .50 USD each shipped, one per board allowed if you guys are interested in them. People who previously paid, let me know if your interested.
I have not used it personally, other than using a mass of them to tune a speaker cross over.
.33uf GE cap
If you want them, put it in the paypal notes. Thanks.
Old 23rd October 2012, 05:26 PM   #358
Default Application detail
Michael,
Now that I know your name from the PAYPAL payment!
My application will be 280 to 300 volts out - 15 mA for the "tubes" plus the 20 mA required.
What do you think?
Thanks, again,
Rick McInnis
Old 23rd October 2012, 08:06 PM   #359
Tea-Bag's Avatar
Rick, I don't feel confident enough using the calculators to give totally reasonable advice,
but 300v @ .035A gives 10.5Watts. So assuming a bunch of thermodynamics I never took in college, I would guess something that can shed 15 watts or more.
Volts Watts Amps Converter Tool Calculator
The heatsink calculators I have not figured out yet - but it would be nice to include some calculations in a revised build guide, or in Post 1 for example (which I can edit)
I often use CPU heatsinks from Surplus dead servers, and if it requires more than that, I use the Arctic Thermal epoxy to bind them together.
Old 24th October 2012, 05:14 AM   #360
Salas's Avatar
The 20mA part will burn on the output sink, the 15mA part will go to the tubes. That 20mA will multiply by the output voltage to give the Watt to burn.
Natural convection heat sink
GB for Salas SSHV2 regulatorHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1661 31st January 2018 01:53 AM
Which Salas HV shunt regulator should I choose? Tubenstein Tubes / Valves 9 25th March 2013 03:31 PM
GB: Salas Shunt for Squeezebox mravlca Group Buys 8 18th July 2011 05:34 PM
